Confused about the Mega 3MP tutorial
  1. Where did you get the camera module(s)? Online Shop on Amazon
  2. Model number of the product(s)? Arducam Mega 3MP SPI camera B0400
  3. What hardware/platform were you working on? Raspberry Pico and Raspberry Pico W
  4. Instructions you have followed. (link/manual/etc.) https://www.arducam.com/docs/arducam-mega/arducam-mega-getting-started/packs/example/PICO.html
Hi, im having issues trying to connect the arducam with an raspberry pi pico (w), i followed the instructions and downloaded the latest github examples (3.0.0 if im not wrong). it compiles but when im trying to use the arducam app it shows an paser timeout error.
i already tried the camara module with an arduino uno and it worked fine but with both raspberries it gives out the same error.
i have tried searching for solutions but only get videos based on the tutorial on the arducam page, and im also quite confused since the page is already a couple years old and i dont know if some elements are outdated like the hardware conections, since its based on a older version of Arduinos mbed os rp2040 boards and an older version of the github.
hope i didnt rambled a lot, thanks in advance
Since the camera works correctly with the Arduino Uno, this indicates that the Arducam Mega hardware itself is most likely working properly.
The issue may be related to the Raspberry Pi Pico/Pico W software environment or the SPI wiring/configuration.
Could you please provide the following information?
  1. Which version of the Arduino Mbed OS RP2040 Boards package are you using?
  2. Please share your current wiring connections between the Arducam Mega and the Raspberry Pi Pico/Pico W, including the SPI pins you are using.
Once we have this information, we can help check whether there is any compatibility or pin-configuration issue with the current library/examples.
