The gui achieves various control effects by changing the configuration files, and you can change the related configuration files to achieve the effect.
Thanks for the quick reply. I changed the number behind 'DEF = ’ in the code you took in your screenshot. If I then open the GUI it indeed opens the camera with the focus I set in the config file. However, changing this number does not change the pictures I take with my python script using the below script. Should this have changed my focus/any idea what I am doing wrong? I’ve double-checked and I am changing the right .cfg file which the python script also uses.
Thanks again for the rapid response. I looked up on these registers but I still don’t understand them and can’t find much documentation. From what I understand, the final numbers are the ones I should change. How should I change them? e.g. could you give 2 examples of different DEF values and corresponding high and low bit registers?
