UCTRONICS
MT9J003/UC-425
Raspberry Pi
Online & readme
Streaming works, need single images
I have successfully run the streaming demo code, but when I try to run ArduCam_Ext_Trigger_Demo I see the following error:
device num:1
index: 0 Serial:AU3S-2042-008
Found 1 devices.
Serial: AU3S-2042-0008
Usb board firmware version not support single mode
I found this post that looks like someone else was able to take single mode with a similar issue but I do not understand how this worked.
How can I take single images with this camera? Can you provide a config file for this?
Thank you,
cb
Code to take single images with MT9J003/UC-425
