UCTRONICS
B0265R Arducam 12MP*2 Synchronized Stereo Camera Bundle Kit for Raspberry Pi, Two 12.3MP IMX477 Camera Modules with CS Lens and Camarray Stereo Camera HAT
Raspberry Pi 4B 4gb
online
yes, intermittently
I’ve run into a curious problem in executing capture.py in the MIPI_Camera/RPI/python folder.
The first time I run it after a reboot the program works great and captures an image, with a “Close camera” message at the end (as expected). Consistently, this works after a reboot.
However, if I attempt to run the script a second (or more) time it invariably hangs and ends with a message of “NULL pointer access”. This message presents right after it enables AWB, and right after the normal system return of “mmal: Enable JPEG encoder.” However, no file is created on the second and subsequent runs. A reboot is required to make it work again, but it only works again once after the reboot.
After I get the NULL message, the command ‘arducamstill’ does not work from the command line either. Arducamstill either hangs right after trying to set the autofocus, or it returns an error code 'init camera status = 4100".
The NULL message is being thrown by capture.py when it commands ‘frame.as_array.tofile(name)’ in calling line 269 of arducam_mipicamera.py (the ‘def as_array(self)’ statement).
It is as if the camera is never fully released with the ‘camera.close_camera()’ command the first time I run capture.py, and the when I run it the second time (or when I try to run arducamstill) the script cannot initiate/access the cameras. I think this is causing the NULL error as there is no data in ‘frame’ to pass to the ‘as_array’ module since there is no data coming from the still open/frozen cameras in the second and subsequent attempts to run the script.
Since capture.py runs well so consistently AFTER a reboot, I do not think it is related to the data ribbons - though I have re-seated all of them.
Is there any way I can overcome this? If my theory is correct, is there another way to make sure that the cameras are fully closed/released at the end of capture.py?
various hardware and software troubleshooting changes/steps
Guidance on how to be able to run capture.py more than once between reboots
