Amazon
B0278
Ubuntu 20.04 amd64
I am unable to set the absolute exposure on the imx477 camera using the uvc carrier board on ubuntu 20.04 via v4l or opencv.
I’ve tried setting the value using cap.set(cv2.CAP_PROP_EXPOSURE, exposure). as well as with v4l.
the following script works for my built in webcam but does not work for the arducam. any help is appreciated!
the output of the v4l settings is shown here:
cos@cos-thinkpad-yoga:~/projects/camstuff/cam4$ v4l2-ctl -d /dev/video2 -l
User Controls
brightness 0x00980900 (int) : min=-64 max=64 step=1 default=0 value=0
contrast 0x00980901 (int) : min=0 max=64 step=1 default=32 value=32
saturation 0x00980902 (int) : min=0 max=128 step=1 default=64 value=64
hue 0x00980903 (int) : min=-40 max=40 step=1 default=0 value=0
white_balance_automatic 0x0098090c (bool) : default=1 value=1
gamma 0x00980910 (int) : min=72 max=500 step=1 default=100 value=100
gain 0x00980913 (int) : min=0 max=100 step=1 default=0 value=0
power_line_frequency 0x00980918 (menu) : min=0 max=2 default=2 value=2 (60 Hz)
white_balance_temperature 0x0098091a (int) : min=2800 max=6500 step=1 default=4600 value=4600 flags=inactive
sharpness 0x0098091b (int) : min=0 max=6 step=1 default=3 value=3
backlight_compensation 0x0098091c (int) : min=0 max=2 step=1 default=1 value=1
Camera Controls
auto_exposure 0x009a0901 (menu) : min=0 max=3 default=3 value=1 (Manual Mode)
exposure_time_absolute 0x009a0902 (int) : min=1 max=5000 step=1 default=157 value=110
exposure_dynamic_framerate 0x009a0903 (bool) : default=0 value=1
focus_automatic_continuous 0x009a090c (bool) : default=1 value=0
Here is the python code I am using to build a HDR image:
import cv2
import time
import numpy as np
import subprocess
def merge_hdr(images, exposure_times):
exposure_times = np.array(exposure_times, dtype=np.float32)
exposure_times /= 10
alignMTB = cv2.createAlignMTB()
alignMTB.process(images,images)
# Estimate camera response function (CRF)
calibrateDebevec = cv2.createCalibrateDebevec()
responseDebevec = calibrateDebevec.process(images, exposure_times)
# Merge images into an HDR linear image
mergeDebevec = cv2.createMergeDebevec()
hdrDebevec = mergeDebevec.process(images, exposure_times, responseDebevec)
# Tone map the HDR image to 8-bit channels
tonemap = cv2.createTonemap(2.2)
ldr = tonemap.process(hdrDebevec)
# Convert to 8-bit and save
ldr_8bit = np.clip(ldr*255, 0, 255).astype('uint8')
cv2.imwrite('./images/hdr_image.hdr', ldr_8bit)
merge_mertens = cv2.createMergeMertens()
fusion = merge_mertens.process(images)
cv2.imwrite('./images/fusion.png', fusion * 255)
return
def main():
cap = cv2.VideoCapture(2)
#cap.set(cv2.CAP_PROP_AUTO_EXPOSURE, 0.75)
width = 1920
height = 1080
cap.set(cv2.CAP_PROP_FRAME_WIDTH, width)
cap.set(cv2.CAP_PROP_FRAME_HEIGHT, height)
exposure = 0.1
count =0
images=[]
exposures=[]
while cap.isOpened():
# Grab frame
ret, frame = cap.read()
if ret:
#cv2.imshow('Frame', frame)
output_path = './images/output_-'+str(exposure)+'-.png'
cv2.imwrite(output_path, frame)
images.append(frame)
exposures.append(exposure)
# Set exposure manually
command = "v4l2-ctl -d 2 -c auto_exposure=1 -c exposure_time_absolute="+str(exposure)
output = subprocess.call(command, shell=True)
# Increase exposure for every frame that is displayed
exposure += 20
if count >=20:
break
else:
count+=1
# Close everything
cap.release()
cv2.destroyAllWindows()
merge_hdr(images, exposures)
main()
