Can't launch to camera
tried TWO same hawkeye cams, and both ports- cam0 and cam1, every try gets error.
os - bookworm, just flashed new OS for clarity of result
hardware- raspi 5
errors:
dmesg (on cam1 same):
dmesg | grep -Ei 'pivariety|cfe|sensor'
[ 0.056990] /axi/pcie@1000120000/rp1/i2c@88000/arducam_**pivariety**@c: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/csi@110000
[ 0.057015] /axi/pcie@1000120000/rp1/csi@110000: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/i2c@88000/arducam_**pivariety**@c
[ 0.057128] /axi/pcie@1000120000/rp1/i2c@88000/arducam_**pivariety**@c: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/csi@110000
[ 0.057154] /axi/pcie@1000120000/rp1/csi@110000: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/i2c@88000/arducam_**pivariety**@c
[ 0.441991] /axi/pcie@1000120000/rp1/i2c@88000/arducam_**pivariety**@c: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/csi@110000
[ 0.457112] /axi/pcie@1000120000/rp1/i2c@88000/arducam_**pivariety**@c: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/csi@110000
[ 0.457129] /axi/pcie@1000120000/rp1/csi@110000: Fixed dependency cycle(s) with /axi/pcie@1000120000/rp1/i2c@88000/arducam_**pivariety**@c
[ 2.359772] rp1-**cfe** 1f00110000.csi: bcm2712_iommu_of_xlate: MMU 1000005280.iommu
[ 2.359783] rp1-**cfe** 1f00110000.csi: bcm2712_iommu_probe_device: MMU 1000005280.iommu
[ 2.361232] rp1-**cfe** 1f00110000.csi: bcm2712_iommu_device_group: MMU 1000005280.iommu
[ 2.361244] rp1-**cfe** 1f00110000.csi: Adding to iommu group 2
[ 2.361250] rp1-**cfe** 1f00110000.csi: bcm2712_iommu_attach_dev: MMU 1000005280.iommu
[ 2.361629] rp1-**cfe** 1f00110000.csi: DW dphy Host HW v1.20
[ 2.361641] rp1-**cfe** 1f00110000.csi: PiSP FE HW v0.1
[ 2.362851] rp1-**cfe** 1f00110000.csi: found subdevice /axi/pcie@1000120000/rp1/i2c@88000/arducam_**pivariety**@c
[ 2.389796] arducam-**pivariety** 10-000c: probe failed
utility from repo also error:
sudo ~/cam/Arducam_tof_camera/build/example/cpp/preview_depth
**[WARN]** Could not open device node /dev/video0. Please check for permissions.
Failed to open camera
can it be a hardware problem? can It be a problem with raspberry pi ports? what are my options here?
Could you plz post some pictures of your hardware connections?
Thank you for the photos.
The problem is that both sides of the hardware connections are upside down. You need to reverse the cable on both sides.
