I am working on trying to get the 4 port multi camera board to work with just a single camera at the moment but I can’t seem to make it work in any way. I am using a Raspberry pi 4B 8GB running 64Bit Raspberry Pi OS Bookworm.
I am following this quick start guide:
The one difference I am making is that I am updating my /boot/firmware/config.txt file instead of /boot/config.txt because they appeared to have moved it for Bookworm.
I am running a clean install of Bookworm, I have turned on I2C, I have set camera_auto_detect=0
, I added the line
dtoverlay=camera-mux-4port,cam0-ov5647
I have the camera connected to the Camera A slot on multi-camera board.
I have checked that the camera works without the multi camera board and that it works with both of the CSI ribbon cables.
It seems that I just can’t get the 4 port driver to load no matter what I do. After rebooting and I run sudo dmesg | grep arducam
I get nothing and if I run libcamera-hello --list
it says no cameras found, if I do ls /dev/video*
there is no /dev/video0.
Any help or advice would be much appreciated.
Additionally, I want to know that once I get this camera working will I be able to change the camera with python over i2c and gpio like I used to do on buster?
Thanks,
Zak
