[ 0.000000] Linux version 5.15.32-v8+ (dom@buildbot) (aarch64-linux-gnu-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1538 SMP PREEMPT Thu Mar 31 19:40:39 BST 2022
[ 0.000000] Machine model: Raspberry Pi 4 Model B Rev 1.4
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000001ac00000, size 320 MiB
[ 0.000000] Zone ranges:
[ 0.000000] DMA32 [mem 0x0000000040000000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x00000001ffffffff]
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000037ffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x00000001ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000001ffffffff]
[ 0.000000] percpu: Embedded 28 pages/cpu s77144 r8192 d29352 u114688
[ 0.000000] pcpu-alloc: s77144 r8192 d29352 u114688 alloc=28*4096
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 2015744
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=E4:5F:01:4C:1B:69 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=7f866caa-02 rootfstype=ext4 fsck.repair=yes rootwait
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] software IO TLB: mapped [mem 0x0000000034000000-0x0000000038000000] (64MB)
[ 0.000000] Memory: 7617412K/8192000K available (11456K kernel code, 1962K rwdata, 4144K rodata, 3776K init, 964K bss, 246908K reserved, 327680K cma-reserved)
[ 0.000000] ftrace: allocating 37889 entries in 149 pages
[ 0.000000] ftrace: allocated 149 pages with 4 groups
[ 0.000000] random: get_random_bytes called from start_kernel+0x510/0x6f8 with crng_init=1
[ 0.000001] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000256] Console: colour dummy device 80x25
[ 0.000797] printk: console [tty1] enabled
[ 0.000879] Calibrating delay loop (skipped), value calculated using timer frequency… 108.00 BogoMIPS (lpj=216000)
[ 0.000920] pid_max: default: 32768 minimum: 301
[ 0.001064] LSM: Security Framework initializing
[ 0.001295] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.001426] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.002674] cgroup: Disabling memory control group subsystem
[ 0.005199] rcu: Hierarchical SRCU implementation.
[ 0.006349] EFI services will not be available.
[ 0.006912] smp: Bringing up secondary CPUs …
[ 0.008026] Detected PIPT I-cache on CPU1
[ 0.008107] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
[ 0.009271] Detected PIPT I-cache on CPU2
[ 0.009321] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
[ 0.010445] Detected PIPT I-cache on CPU3
[ 0.010495] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
[ 0.010644] smp: Brought up 1 node, 4 CPUs
[ 0.010736] SMP: Total of 4 processors activated.
[ 0.010758] CPU features: detected: 32-bit EL0 Support
[ 0.010777] CPU features: detected: 32-bit EL1 Support
[ 0.010799] CPU features: detected: CRC32 instructions
[ 0.042031] CPU: All CPU(s) started at EL2
[ 0.042122] alternatives: patching kernel code
[ 0.044288] devtmpfs: initialized
[ 0.055223] Enabled cp15_barrier support
[ 0.055292] Enabled setend support
[ 0.055490] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.055539] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.066204] pinctrl core: initialized pinctrl subsystem
[ 0.067068] DMI not present or invalid.
[ 0.067557] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.071184] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.071498] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.072432] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.072542] audit: initializing netlink subsys (disabled)
[ 0.072842] audit: type=2000 audit(0.072:1): state=initialized audit_enabled=0 res=1
[ 0.073352] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.073574] cpuidle: using governor menu
[ 0.073880] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.074077] ASID allocator initialised with 65536 entries
[ 0.074248] Serial: AMBA PL011 UART driver
[ 0.085692] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.108324] raspberrypi-firmware soc:firmware: Attached to firmware from 2022-03-24T13:20:19, variant start_x
[ 0.112343] raspberrypi-firmware soc:firmware: Firmware hash is e5a963efa66a1974127860b42e913d2374139ff5
[ 0.163874] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.168095] vgaarb: loaded
[ 0.168578] SCSI subsystem initialized
[ 0.168794] usbcore: registered new interface driver usbfs
[ 0.168861] usbcore: registered new interface driver hub
[ 0.168948] usbcore: registered new device driver usb
[ 0.169297] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.169776] pps_core: LinuxPPS API ver. 1 registered
[ 0.169802] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti [email protected]
[ 0.169840] PTP clock support registered
[ 0.171273] clocksource: Switched to clocksource arch_sys_counter
[ 0.259810] VFS: Disk quotas dquot_6.6.0
[ 0.259940] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.260121] FS-Cache: Loaded
[ 0.260365] CacheFiles: Loaded
[ 0.271141] NET: Registered PF_INET protocol family
[ 0.272148] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.278147] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.278271] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.278762] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.279847] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.280198] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.280363] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.280777] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.281845] RPC: Registered named UNIX socket transport module.
[ 0.281878] RPC: Registered udp transport module.
[ 0.281898] RPC: Registered tcp transport module.
[ 0.281917] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.281947] PCI: CLS 0 bytes, default 64
[ 0.284713] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.285085] kvm [1]: IPA Size Limit: 44 bits
[ 0.286257] kvm [1]: vgic interrupt IRQ9
[ 0.286535] kvm [1]: Hyp mode initialized successfully
[ 1.185615] Initialise system trusted keyrings
[ 1.185994] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 1.192802] zbud: loaded
[ 1.194613] FS-Cache: Netfs ‘nfs’ registered for caching
[ 1.195329] NFS: Registering the id_resolver key type
[ 1.195385] Key type id_resolver registered
[ 1.195406] Key type id_legacy registered
[ 1.195523] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 1.195550] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 1.196722] Key type asymmetric registered
[ 1.196750] Asymmetric key parser ‘x509’ registered
[ 1.196842] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.197115] io scheduler mq-deadline registered
[ 1.197142] io scheduler kyber registered
[ 1.205092] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 1.205157] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 1.205258] brcm-pcie fd500000.pcie: MEM 0x0600000000…0x063fffffff → 0x00c0000000
[ 1.205354] brcm-pcie fd500000.pcie: IB MEM 0x0000000000…0x01ffffffff → 0x0400000000
[ 1.269373] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 1.269760] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.269793] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.269821] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 1.269949] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.270208] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.274334] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.274473] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.274911] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 1.278869] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.278910] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.278964] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.278995] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.287130] iproc-rng200 fe104000.rng: hwrng registered
[ 1.287709] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.289075] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.289508] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 1.300772] brd: module loaded
[ 1.310422] loop: module loaded
[ 1.311208] Loading iSCSI transport class v2.0-870.
[ 1.316215] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.375426] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.376553] usbcore: registered new interface driver r8152
[ 1.376634] usbcore: registered new interface driver lan78xx
[ 1.376699] usbcore: registered new interface driver smsc95xx
[ 1.424130] pci 0000:00:00.0: enabling device (0000 → 0002)
[ 1.424344] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.424390] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.425130] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x00003c0000000890
[ 1.426440] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 1.426479] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.426508] usb usb1: Product: xHCI Host Controller
[ 1.426531] usb usb1: Manufacturer: Linux 5.15.32-v8+ xhci-hcd
[ 1.426554] usb usb1: SerialNumber: 0000:01:00.0
[ 1.427353] hub 1-0:1.0: USB hub found
[ 1.427465] hub 1-0:1.0: 1 port detected
[ 1.428147] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.428182] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.428219] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.428691] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 1.428728] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.428755] usb usb2: Product: xHCI Host Controller
[ 1.428778] usb usb2: Manufacturer: Linux 5.15.32-v8+ xhci-hcd
[ 1.428801] usb usb2: SerialNumber: 0000:01:00.0
[ 1.429472] hub 2-0:1.0: USB hub found
[ 1.429558] hub 2-0:1.0: 4 ports detected
[ 1.431115] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.431452] dwc_otg: FIQ enabled
[ 1.431465] dwc_otg: NAK holdoff enabled
[ 1.431475] dwc_otg: FIQ split-transaction FSM enabled
[ 1.431488] Module dwc_common_port init
[ 1.432064] usbcore: registered new interface driver uas
[ 1.432172] usbcore: registered new interface driver usb-storage
[ 1.432422] mousedev: PS/2 mouse device common for all mice
[ 1.437668] sdhci: Secure Digital Host Controller Interface driver
[ 1.437704] sdhci: Copyright(c) Pierre Ossman
[ 1.438304] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.441798] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.442418] hid: raw HID events driver (C) Jiri Kosina
[ 1.442596] usbcore: registered new interface driver usbhid
[ 1.442621] usbhid: USB HID core driver
[ 1.442965] ashmem: initialized
[ 1.451846] Initializing XFRM netlink socket
[ 1.451919] NET: Registered PF_PACKET protocol family
[ 1.452062] Key type dns_resolver registered
[ 1.453201] registered taskstats version 1
[ 1.453247] Loading compiled-in X.509 certificates
[ 1.453921] Key type ._fscrypt registered
[ 1.453948] Key type .fscrypt registered
[ 1.453968] Key type fscrypt-provisioning registered
[ 1.465817] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 1.466142] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.466312] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 17, base_baud = 0) is a PL011 rev2
[ 1.477599] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.478092] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.479301] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.479335] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.509977] of_cfs_init
[ 1.510172] of_cfs_init: OK
[ 1.544778] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
[ 1.545216] Waiting for root device PARTUUID=7f866caa-02…
[ 1.597820] mmc1: new high speed SDIO card at address 0001
[ 1.644335] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
[ 1.645375] mmcblk0: mmc0:aaaa SU32G 29.7 GiB
[ 1.648683] mmcblk0: p1 p2
[ 1.649224] mmcblk0: mmc0:aaaa SU32G 29.7 GiB
[ 1.663314] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 1.663362] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 1.683328] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.833893] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.833948] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.833975] usb 1-1: Product: USB2.0 Hub
[ 1.835991] hub 1-1:1.0: USB hub found
[ 1.836287] hub 1-1:1.0: 4 ports detected
[ 3.660912] EXT4-fs (mmcblk0p2): recovery complete
[ 3.664318] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 3.664457] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 3.670102] devtmpfs: mounted
[ 3.678078] Freeing unused kernel memory: 3776K
[ 3.678312] Run /sbin/init as init process
[ 3.678335] with arguments:
[ 3.678343] /sbin/init
[ 3.678353] with environment:
[ 3.678361] HOME=/
[ 3.678371] TERM=linux
[ 4.063902] systemd[1]: System time before build time, advancing clock.
[ 4.166110] NET: Registered PF_INET6 protocol family
[ 4.167994] Segment Routing with IPv6
[ 4.168052] In-situ OAM (IOAM) with IPv6
[ 4.224522] systemd[1]: systemd 247.3-7 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[ 4.225510] systemd[1]: Detected architecture arm64.
[ 4.233853] systemd[1]: Set hostname to .
[ 4.946402] systemd[1]: Queued start job for default target Multi-User System.
[ 4.949639] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.952047] systemd[1]: Created slice system-getty.slice.
[ 4.952828] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.953854] systemd[1]: Created slice system-modprobe.slice.
[ 4.954299] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.955316] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 4.956513] systemd[1]: Created slice User and Session Slice.
[ 4.957379] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 4.958177] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 4.959664] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 4.960237] systemd[1]: Reached target Local Encrypted Volumes.
[ 4.960835] systemd[1]: Reached target Slices.
[ 4.961275] systemd[1]: Reached target Swap.
[ 4.962561] systemd[1]: Listening on Syslog Socket.
[ 4.963667] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 4.964415] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 4.965947] systemd[1]: Listening on Journal Audit Socket.
[ 4.967032] systemd[1]: Listening on Journal Socket (/dev/log).
[ 4.968414] systemd[1]: Listening on Journal Socket.
[ 4.975532] systemd[1]: Listening on udev Control Socket.
[ 4.976870] systemd[1]: Listening on udev Kernel Socket.
[ 4.978135] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 4.982157] systemd[1]: Mounting POSIX Message Queue File System…
[ 4.986999] systemd[1]: Mounting RPC Pipe File System…
[ 4.992795] systemd[1]: Mounting Kernel Debug File System…
[ 4.998180] systemd[1]: Mounting Kernel Trace File System…
[ 4.999105] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[ 5.005414] systemd[1]: Starting Restore / save the current clock…
[ 5.011879] systemd[1]: Starting Set the console keyboard layout…
[ 5.017533] systemd[1]: Starting Create list of static device nodes for the current kernel…
[ 5.023529] systemd[1]: Starting Load Kernel Module configfs…
[ 5.036290] systemd[1]: Starting Load Kernel Module drm…
[ 5.042073] systemd[1]: Starting Load Kernel Module fuse…
[ 5.051175] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 5.055886] systemd[1]: Starting File System Check on Root Device…
[ 5.064946] systemd[1]: Starting Journal Service…
[ 5.081633] systemd[1]: Starting Load Kernel Modules…
[ 5.091838] systemd[1]: Starting Coldplug All udev Devices…
[ 5.107552] fuse: init (API version 7.34)
[ 5.128797] systemd[1]: Mounted POSIX Message Queue File System.
[ 5.130000] systemd[1]: Mounted RPC Pipe File System.
[ 5.130932] systemd[1]: Mounted Kernel Debug File System.
[ 5.132669] systemd[1]: Mounted Kernel Trace File System.
[ 5.134976] systemd[1]: Finished Restore / save the current clock.
[ 5.138006] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 5.140957] systemd[1]: [email protected]: Succeeded.
[ 5.142506] systemd[1]: Finished Load Kernel Module configfs.
[ 5.145211] systemd[1]: [email protected]: Succeeded.
[ 5.146631] systemd[1]: Finished Load Kernel Module drm.
[ 5.149385] systemd[1]: [email protected]: Succeeded.
[ 5.150876] systemd[1]: Finished Load Kernel Module fuse.
[ 5.157947] systemd[1]: Mounting FUSE Control File System…
[ 5.163291] systemd[1]: Mounting Kernel Configuration File System…
[ 5.176725] systemd[1]: Started File System Check Daemon to report status.
[ 5.185464] systemd[1]: Mounted FUSE Control File System.
[ 5.186602] i2c_dev: i2c /dev entries driver
[ 5.187494] systemd[1]: Mounted Kernel Configuration File System.
[ 5.192935] systemd[1]: Finished Load Kernel Modules.
[ 5.198799] systemd[1]: Starting Apply Kernel Variables…
[ 5.278628] systemd[1]: Finished Apply Kernel Variables.
[ 5.308253] systemd[1]: Finished File System Check on Root Device.
[ 5.313052] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 5.440868] systemd[1]: Started Journal Service.
[ 5.460788] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
[ 5.516490] systemd-journald[135]: Received client request to flush runtime journal.
[ 5.539018] systemd-journald[135]: File /var/log/journal/5a41e3150f1147c48235f0857aaaf5ae/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 6.395681] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
[ 6.397661] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
[ 6.399615] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
[ 6.409390] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
[ 6.466510] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.468277] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 6.468318] [vc_sm_connected_init]: start
[ 6.476036] [vc_sm_connected_init]: installed successfully
[ 6.507556] mc: Linux media interface: v0.10
[ 6.531521] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.558131] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 6.600334] videodev: Linux video capture interface: v2.00
[ 6.620362] i2c i2c-22: Added multiplexed i2c bus 0
[ 6.679664] i2c 10-000c: Fixing up cyclic dependency with fe801000.csi
[ 6.683145] i2c i2c-22: Added multiplexed i2c bus 10
[ 6.685267] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 6.889686] [drm] No displays found. Consider forcing hotplug if HDMI is attached
[ 6.889731] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[ 6.901014] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[ 6.993121] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 7.005271] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.025759] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.027000] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 7.039925] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[ 7.053006] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.065995] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.071653] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.114292] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 7.114375] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 7.118348] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 7.119053] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 7.120486] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 7.124937] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 7.125003] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 7.129524] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 7.129689] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 7.129743] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 7.130805] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 7.130840] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 7.130860] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 7.130878] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 7.170513] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 7.176990] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[ 7.182089] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 7.183425] usbcore: registered new interface driver brcmfmac
[ 7.183541] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.bin failed with error -2
[ 7.200322] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[ 7.201102] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 7.201595] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 7.201629] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 7.201651] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 7.201669] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 7.201697] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 7.202030] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 7.230629] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 7.230714] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 7.279955] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[ 7.280118] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[ 7.445401] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 7.445577] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 7.451246] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov 1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
[ 7.603199] random: crng init done
[ 7.603226] random: 7 urandom warning(s) missed due to ratelimiting
[ 8.355857] arducam: loading out-of-tree module taints kernel.
[ 8.382890] arducam-pivariety 10-000c: firmware version: 0x10002
[ 8.845192] uart-pl011 fe201000.serial: no DMA platform data
[ 8.904664] 8021q: 802.1Q VLAN Support v1.8
[ 8.919408] arducam-pivariety 10-000c: Consider updating driver arducam-pivariety to match on endpoints
[ 9.001254] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 9.353398] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 9.556814] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 9.557054] bcmgenet fd580000.ethernet eth0: Link is Down
[ 15.321450] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 15.664006] Bluetooth: Core ver 2.22
[ 15.664100] NET: Registered PF_BLUETOOTH protocol family
[ 15.664105] Bluetooth: HCI device and connection manager initialized
[ 15.664120] Bluetooth: HCI socket layer initialized
[ 15.664127] Bluetooth: L2CAP socket layer initialized
[ 15.664138] Bluetooth: SCO socket layer initialized
[ 15.671514] Bluetooth: HCI UART driver ver 2.3
[ 15.671534] Bluetooth: HCI UART protocol H4 registered
[ 15.671591] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 15.671737] Bluetooth: HCI UART protocol Broadcom registered
[ 15.830095] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 15.830114] Bluetooth: BNEP filters: protocol multicast
[ 15.830127] Bluetooth: BNEP socket layer initialized
[ 15.840826] NET: Registered PF_ALG protocol family
[ 31.711311] cam-dummy-reg: disabling
