From uctronics.com -
B0265N -
Jetson Nano 4G -
IMX477 - How to install the Driver - Arducam -
Sensors are detected (after reconfiguring CSI port with jetson-io ofc). Tested with both arducam drivers and official drivers. However with neither of them i can get a proper image from the cameras as you can see in the photo below
jetson1@jetson1-desktop:~$ dmesg | grep imx
[ 1.316861] imx477 7-001a: tegracam sensor driver:imx477_v2.0.6
[ 1.617246] imx477 7-001a: imx477_board_setup: error during i2c read probe (-121)
[ 1.617280] imx477 7-001a: board setup failed
[ 1.617352] imx477: probe of 7-001a failed with error -121
[ 1.617677] imx477 8-001a: tegracam sensor driver:imx477_v2.0.6
[ 2.060881] vi 54080000.vi: subdev imx477 8-001a bound
The cameras are connected to a HAT camarray board that is connected to the Jetson Nano.
I changed the CSI ports, i have used a secondary HAt camarray board i had, i tested both official and arducam drivers, all with no success. The sensors do get something because there is a thin line on top of all that pin noise where video can be actually seen if you look closely. -
Maybe someone had this issue and knows a fix for it?!
