Hi, I’m trying to get an Arducam IMX477 camera working on my Jetson Nano and I’m stuck. I’m following the driver install guide but I can’t find the matching deb package for my setup. I’ve looked through the downloads but nothing seems to line up with my kernel. Am I missing something obvious? Any help would be appreciated.
Hey, happy to help. To point you at the right package I need a couple of details first. Can you tell me:
- Which Jetson you’re on (Nano / Xavier NX / etc.)
- The exact kernel version, you can grab it with:
uname -r
That output will tell me which L4T release you’re on and which package is the right match.
Sure, here’s what I’ve got:
Device: Jetson Nano
Jetson type: Nano
Kernel version: 4.9.299-tegra-32.7.3-20221122092935
So it looks like 32.7.3? I kept checking the deb packages but I can only find ones with 32.7.2xxx in the name. Nothing with 32.7.3. That’s why I figured I’d ask before I install the wrong thing.
Thanks, that’s exactly the info I needed.
So what’s going on: you’re on kernel 4.9.299-tegra-32.7.3-20221122092935, which is L4T 32.7.3. The driver deb packages have so far only been updated/tested up to the 32.7.2xxx line. There’s no published deb that matches 32.7.3 yet, which is why you can’t find one that lines up with your kernel string. It’s not something you’re doing wrong on your end.
Testing on 32.7.3 still needs to be done before an official deb for that version can be released.
Ah, that explains it. So there’s genuinely no deb for 32.7.3 right now.
Is there any way to still get it working in the meantime, or do I just have to wait for the 32.7.3 release? I’d really like to get the camera up if possible. Also, will the 32.7.2 package work if I try it anyway, or would that just break things?
You don’t have to wait, but you do need a specific combination.
Until a 32.7.3 deb is released, use the package I’ll send you together with the matching firmware file. The deb package and the firmware have to be paired correctly for the sensor to enumerate, so don’t mix it with a different firmware build.
I’ve sent the package and the matching firmware details in a private message. Please grab them there and follow the install order (deb first, then drop in the firmware) and let me know how it goes.
Got the private message, thanks. I installed the deb and then added the firmware file as described. Rebooted and… I think we’re good? It actually detected the IMX477 this time. Ran a quick capture and it’s giving me frames instead of the usual errors.
One thing though, is this the supported path or just a temporary workaround? I just want to know if I should expect to redo this once 32.7.3 is officially out.
Nice, glad it came up. That’s expected behavior for that combo.
To sum up where we landed:
- Root cause: you’re on L4T 32.7.3 (kernel 4.9.299-tegra-32.7.3-20221122092935), and the deb packages so far only cover up to 32.7.2xxx. 32.7.3 hasn’t been validated, so no matching deb is published yet. That’s why the package couldn’t be found.
- Current path: use the provided package together with the matching firmware (both sent to you privately). That’s what got the IMX477 working on your Nano.
- Status: this is the interim solution until a 32.7.3 deb finishes testing and gets released.
Once an official 32.7.3 deb is out, I’d recommend switching to it so you’re on the supported package. If anything misbehaves before then, post back with your kernel version and dmesg output and we’ll take a look.
