Other - www.botland.com.pl - Model number of the product(s)?
Buy Raspberry Pi NoIR Camera HD v2 8MPx - Botland - Robotic Shop
USB3.0 shield plus (B0317) UC-593 Rev C - What hardware/platform were you working on?
Linux x86 - Instructions you have followed. (link/manual/etc.)
https://github.com/ArduCAM/ArduCAM_USB_Camera_Shield - Problems you were having?
In some cases Arducam is not recoginzed correctly and can’t be used:
device num:4
index: 0 Serial:A-
index: 2 Serial:
L\ufffd-
index: 2 Serial:
index: 4 Serial:\ufffd
Cannot open camera.rtn_val = 65281
Expected output when bug doesn’t occur:
device num:4
index: 0 Serial:AU3S-2241-0089 <-- this is valid device with serial number and we can use it without issues
index: 2 Serial:20\ufffd-
index: 2 Serial:
Serial: AU3S-2241-0089
(early initialization removed, because of post size limt)
[ +0.002316] ahci 0000:00:17.0: version 3.0
[ +0.005642] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ +0.000341] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ +0.000829] intel-lpss 0000:00:15.0: enabling device (0000 -> 0002)
[ +0.000628] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000001109810
[ +0.000038] ACPI: video: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ +0.001042] idma64 idma64.0: Found Intel integrated DMA 64-bit
[ +0.000812] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.13
[ +0.000410] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ +0.000375] usb usb1: Product: xHCI Host Controller
[ +0.000413] usb usb1: Manufacturer: Linux 5.13.0-28-generic xhci-hcd
[ +0.000253] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input3
[ +0.000243] usb usb1: SerialNumber: 0000:00:14.0
[ +0.001574] hub 1-0:1.0: USB hub found
[ +0.000649] hub 1-0:1.0: 16 ports detected
[ +0.002647] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ +0.000666] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ +0.000658] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
[ +0.000678] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.13
[ +0.000659] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ +0.000098] i2c i2c-0: 2/2 memory slots populated (from DMI)
[ +0.000560] usb usb2: Product: xHCI Host Controller
[ +0.001105] usb usb2: Manufacturer: Linux 5.13.0-28-generic xhci-hcd
[ +0.000410] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 3 ports 6 Gbps 0x7 impl SATA mode
[ +0.000322] usb usb2: SerialNumber: 0000:00:14.0
[ +0.000680] ahci 0000:00:17.0: flags: 64bit ncq sntf pm led clo only pio slum part ems deso sadm sds apst
[ +0.000867] i2c i2c-0: Successfully instantiated SPD at 0x50
[ +0.000210] hub 2-0:1.0: USB hub found
[ +0.000022] hub 2-0:1.0: 10 ports detected
[ +0.019206] i915 0000:00:02.0: enabling device (0000 -> 0003)
[ +0.000950] checking generic (c0000000 258000) vs hw (dd000000 1000000)
[ +0.000002] checking generic (c0000000 258000) vs hw (b0000000 10000000)
[ +0.002202] scsi host0: ahci
[ +0.000697] scsi host1: ahci
[ +0.000562] scsi host2: ahci
[ +0.000405] ata1: SATA max UDMA/133 abar m2048@0xdf34b000 port 0xdf34b100 irq 126
[ +0.000401] ata2: SATA max UDMA/133 abar m2048@0xdf34b000 port 0xdf34b180 irq 126
[ +0.000377] ata3: SATA max UDMA/133 abar m2048@0xdf34b000 port 0xdf34b200 irq 126
[ +0.005498] pps pps0: new PPS source ptp0
[ +0.000398] igb 0000:02:00.0: added PHC on eth0
[ +0.000370] igb 0000:02:00.0: Intel(R) Gigabit Ethernet Network Connection
[ +0.000352] igb 0000:02:00.0: eth0: (PCIe:2.5Gb/s:Width x1) c4:00:ad:e1:f2:e2
[ +0.000350] igb 0000:02:00.0: eth0: PBA No: FFFFFF-0FF
[ +0.000340] igb 0000:02:00.0: Using MSI-X interrupts. 2 rx queue(s), 2 tx queue(s)
[ +0.001084] igb 0000:02:00.0 enp2s0: renamed from eth0
[ +0.049325] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
[ +0.073620] e1000e 0000:00:1f.6 0000:00:1f.6 (uninitialized): registered PHC clock
[ +0.173699] usb 1-3: new high-speed USB device number 2 using xhci_hcd
[ +0.012007] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ +0.000477] ata2: SATA link down (SStatus 4 SControl 300)
[ +0.004318] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[ +0.000003] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[ +0.000462] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[ +0.000690] ata1.00: supports DRM functions and may not be fully accessible
[ +0.000471] ata3: SATA link down (SStatus 4 SControl 300)
[ +0.000941] ata1.00: disabling queued TRIM support
[ +0.000001] ata1.00: ATA-11: Samsung SSD 870 EVO 1TB, SVT02B6Q, max UDMA/133
[ +0.000463] ata1.00: 1953525168 sectors, multi 1: LBA48 NCQ (depth 32), AA
[ +0.000990] i915 0000:00:02.0: [drm] failed to retrieve link info, disabling eDP
[ +0.001683] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[ +0.000369] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[ +0.000597] ata1.00: supports DRM functions and may not be fully accessible
[ +0.000802] ata1.00: disabling queued TRIM support
[ +0.001735] ata1.00: configured for UDMA/133
[ +0.036205] nvidia: loading out-of-tree module taints kernel.
[ +0.000229] scsi 0:0:0:0: Direct-Access ATA Samsung SSD 870 2B6Q PQ: 0 ANSI: 5
[ +0.000183] nvidia: module license 'NVIDIA' taints kernel.
[ +0.000510] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ +0.000012] ata1.00: Enabling discard_zeroes_data
[ +0.000032] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ +0.000006] sd 0:0:0:0: [sda] Write Protect is off
[ +0.000001] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ +0.000009] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ +0.000311] Disabling lock debugging due to kernel taint
[ +0.012507] tsc: Refined TSC clocksource calibration: 3599.998 MHz
[ +0.000487] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x33e451ab1a6, max_idle_ns: 440795278720 ns
[ +0.000887] clocksource: Switched to clocksource tsc
[ +0.006227] [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 0
[ +0.000580] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ +0.000167] e1000e 0000:00:1f.6 eth0: (PCI Express:2.5GT/s:Width x1) c4:00:ad:e1:f2:e1
[ +0.002248] e1000e 0000:00:1f.6 eth0: Intel(R) PRO/1000 Network Connection
[ +0.000679] e1000e 0000:00:1f.6 eth0: MAC: 12, PHY: 12, PBA No: FFFFFF-0FF
[ +0.002376] e1000e 0000:00:1f.6 eno1: renamed from eth0
[ +0.006768] i915 0000:00:02.0: [drm] Cannot find any crtc or sizes
[ +0.002595] nvidia-nvlink: Nvlink Core is being initialized, major device number 235
[ +0.001216] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[ +0.007938] ata1.00: Enabling discard_zeroes_data
[ +0.001704] sda: sda1 sda2
[ +0.042606] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 520.61.05 Thu Sep 29 05:30:25 UTC 2022
[ +0.000040] usb 1-3: New USB device found, idVendor=04b4, idProduct=6506, bcdDevice=50.00
[ +0.001398] usb 1-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ +0.001292] hub 1-3:1.0: USB hub found
[ +0.000475] hub 1-3:1.0: 4 ports detected
[ +0.024488] ata1.00: Enabling discard_zeroes_data
[ +0.032553] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 520.61.05 Thu Sep 29 05:29:37 UTC 2022
[ +0.002356] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ +0.000438] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 1
[ +0.001455] sd 0:0:0:0: [sda] supports TCG Opal
[ +0.000432] sd 0:0:0:0: [sda] Attached SCSI disk
[ +0.012907] i915 0000:00:02.0: [drm] Cannot find any crtc or sizes
[ +0.012649] i915 0000:00:02.0: [drm] Cannot find any crtc or sizes
[ +0.037347] usb 2-3: new SuperSpeed USB device number 2 using xhci_hcd
[ +0.020552] usb 2-3: New USB device found, idVendor=04b4, idProduct=6504, bcdDevice=50.00
[ +0.001343] usb 2-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ +0.002549] hub 2-3:1.0: USB hub found
[ +0.001344] hub 2-3:1.0: 4 ports detected
[ +0.121935] usb 1-4: new high-speed USB device number 3 using xhci_hcd
[ +0.154733] usb 1-4: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=23.11
[ +0.000603] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ +0.000583] usb 1-4: Product: USB2.1 Hub
[ +0.000504] usb 1-4: Manufacturer: GenesysLogic
[ +0.001959] hub 1-4:1.0: USB hub found
[ +0.000787] hub 1-4:1.0: 2 ports detected
[ +0.072817] raid6: avx2x4 gen() 728288 MB/s
[ +0.047998] raid6: avx2x4 xor() 329113 MB/s
[ +0.000191] usb 2-4: new SuperSpeed USB device number 3 using xhci_hcd
[ +0.022783] usb 2-4: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=23.11
[ +0.000391] usb 2-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ +0.000383] usb 2-4: Product: USB3.2 Hub
[ +0.000404] usb 2-4: Manufacturer: GenesysLogic
[ +0.002777] hub 2-4:1.0: USB hub found
[ +0.000717] hub 2-4:1.0: 2 ports detected
[ +0.020353] raid6: avx2x2 gen() 711981 MB/s
[ +0.048002] raid6: avx2x2 xor() 435125 MB/s
[ +0.004008] usb 1-3.2: new high-speed USB device number 4 using xhci_hcd
[ +0.043994] raid6: avx2x1 gen() 619076 MB/s
[ +0.048010] raid6: avx2x1 xor() 345571 MB/s
[ +0.008620] usb 1-3.2: New USB device found, idVendor=04b4, idProduct=1003, bcdDevice= 0.00
[ +0.000347] usb 1-3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ +0.000345] usb 1-3.2: Product: PERCIPIO DEVICEEE
[ +0.000335] usb 1-3.2: Manufacturer: PERCIPIO
[ +0.000323] usb 1-3.2: SerialNumber: 207000134827
[ +0.038026] raid6: sse2x4 gen() 289802 MB/s
[ +0.040313] usb 2-3.1: new SuperSpeed USB device number 4 using xhci_hcd
[ +0.007680] raid6: sse2x4 xor() 169007 MB/s
[ +0.048010] raid6: sse2x2 gen() 303737 MB/s
[ +0.047999] raid6: sse2x2 xor() 184314 MB/s
[ +0.043999] usb 1-11: new full-speed USB device number 5 using xhci_hcd
[ +0.003990] raid6: sse2x1 gen() 253967 MB/s
[ +0.022950] usb 2-3.1: New USB device found, idVendor=1689, idProduct=2304, bcdDevice= 1.06
[ +0.000328] usb 2-3.1: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ +0.000322] usb 2-3.1: Product: USB Camera
[ +0.000321] usb 2-3.1: Manufacturer: Generic
[ +0.000349] usb 2-3.1: SerialNumber: 200901010001
[ +0.023735] raid6: sse2x1 xor() 128433 MB/s
[ +0.000319] raid6: using algorithm avx2x4 gen() 32189 MB/s
[ +0.000306] raid6: .... xor() 329113 MB/s, rmw enabled
[ +0.000307] raid6: using avx2x2 recovery algorithm
[ +0.000993] xor: automatically using best checksumming function avx
[ +0.001043] async_tx: api initialized (async)
[ +0.038878] Btrfs loaded, crc32c=crc32c-intel, zoned=yes
[ +0.043842] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ +0.011972] usb 1-11: New USB device found, idVendor=8087, idProduct=0029, bcdDevice= 0.01
[ +0.000683] usb 1-11: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ +0.105624] usb 1-4.1: new high-speed USB device number 6 using xhci_hcd
[ +0.042335] systemd[1]: Inserted module 'autofs4'
[ +0.033069] systemd[1]: systemd 245.4-4ubuntu3.15 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ +0.020967] systemd[1]: Detected architecture x86-64.
[ +0.033340] systemd[1]: Set hostname to <dvt10-9>.
[ +0.036303] usb 1-4.1: New USB device found, idVendor=2bc5, idProduct=050b, bcdDevice= 1.00
[ +0.000403] usb 1-4.1: New USB device strings: Mfr=2, Product=1, SerialNumber=3
[ +0.000399] usb 1-4.1: Product: USB 2.0 Camera
[ +0.000394] usb 1-4.1: Manufacturer: Sonix Technology Co., Ltd.
[ +0.000397] usb 1-4.1: SerialNumber: AQCD5220069
[ +0.036458] usb 1-3.3: new full-speed USB device number 7 using xhci_hcd
[ +0.000401] usb 1-3.3: New USB device found, idVendor=2886, idProduct=0018, bcdDevice= 2.00
[ +0.000447] usb 1-3.3: New USB device strings: Mfr=1, Product=3, SerialNumber=0
[ +0.000002] usb 1-3.3: Product: ReSpeaker 4 Mic Array (UAC1.0)
[ +0.000000] usb 1-3.3: Manufacturer: SEEED
[ +0.001042] EXT4-fs (sda2): re-mounted. Opts: (null). Quota mode: none.
[ +0.004492] usb 2-4.2: new SuperSpeed USB device number 5 using xhci_hcd
[ +0.000888] FS-Cache: Netfs 'nfs' registered for caching
[ +0.003219] systemd-journald[430]: Received client request to flush runtime journal.
[ +0.020262] usb 2-4.2: New USB device found, idVendor=2bc5, idProduct=060b, bcdDevice= 0.01
[ +0.000684] usb 2-4.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ +0.000501] usb 2-4.2: Product: ORBBEC Depth Sensor
[ +0.000503] usb 2-4.2: Manufacturer: Orbbec(R)
[ +0.077903] usb 2-3.4: new SuperSpeed USB device number 6 using xhci_hcd
[ +0.020480] usb 2-3.4: LPM exit latency is zeroed, disabling LPM.
[ +0.000958] usb 2-3.4: New USB device found, idVendor=04b4, idProduct=03f2, bcdDevice= 0.00
[ +0.000489] usb 2-3.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ +0.000406] usb 2-3.4: Product: FX3
[ +0.000398] usb 2-3.4: Manufacturer: Arducam
[ +0.007668] NFS: Registering the id_resolver key type
[ +0.000782] Key type id_resolver registered
[ +0.000450] Key type id_legacy registered
[ +0.034593] nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
[ +0.003492] nvidia-uvm: Loaded the UVM driver, major device number 511.
[ +0.000095] mc: Linux media interface: v0.10
[ +0.014973] usbcore: registered new interface driver snd-usb-audio
[ +0.103636] mei_me 0000:00:16.0: enabling device (0004 -> 0006)
[ +0.006174] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[ +0.000198] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ +0.000535] snd_hda_intel 0000:01:00.1: Disabling MSI
[ +0.000005] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[ +0.024301] Bluetooth: Core ver 2.22
[ +0.000015] NET: Registered protocol family 31
[ +0.012321] usb 2-3.1: Found UVC 1.00 device USB Camera (1689:2304)
[ +0.004674] Bridge firewalling registered
[ +0.000019] IPv6: ADDRCONF(NETDEV_CHANGE): br-f9884795b2d8: link becomes ready
[ +0.307780] traps: light-locker[2365] trap int3 ip:7f15bd12e295 sp:7fffde87e1b0 error:0 in libglib-2.0.so.0.6400.6[7f15bd0f2000+84000]
[ +0.041461] traps: light-locker[2407] trap int3 ip:7f25c268d295 sp:7ffe84aeec90 error:0 in libglib-2.0.so.0.6400.6[7f25c2651000+84000]
[Dec12 06:08] usb 1-3.2: usbfs: process 34693 (nodelet) did not claim interface 0 before use
[ +5.559259] TCP: request_sock_TCP: Possible SYN flooding on port 35869. Sending cookies. Check SNMP counters.
[Dec12 06:09] usb 1-3.2: USB disconnect, device number 4
[ +0.240933] usb 1-3.2: new high-speed USB device number 8 using xhci_hcd
[ +0.100338] usb 1-3.2: New USB device found, idVendor=04b4, idProduct=1003, bcdDevice= 0.00
[ +0.000007] usb 1-3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ +0.000003] usb 1-3.2: Product: PERCIPIO DEVICEEE
[ +0.000002] usb 1-3.2: Manufacturer: PERCIPIO
[ +0.000001] usb 1-3.2: SerialNumber: 207000134827
[ +0.291795] [UFW BLOCK] IN=wlp3s0 OUT= MAC=f8:9e:94:9c:4f:4b:20:a6:cd:cb:4d:6e:08:00 SRC=192.168.5.84 DST=192.168.5.210 LEN=165 TOS=0x00 PREC=0x00 TTL=64 ID=1485 DF PROTO=UDP SPT=161 DPT=58007 LEN=145
[Dec12 07:54] xhci_hcd 0000:00:14.0: remove, state 1
[ +0.000017] usb usb2: USB disconnect, device number 1
[ +0.000005] usb 2-3: USB disconnect, device number 2
[ +0.000004] usb 2-3.1: USB disconnect, device number 4
[ +0.044599] usb 2-3.4: USB disconnect, device number 6
[ +0.001193] usb 2-4: USB disconnect, device number 3
[ +0.000010] usb 2-4.2: USB disconnect, device number 5
[ +0.002124] xhci_hcd 0000:00:14.0: USB bus 2 deregistered
[ +0.000122] xhci_hcd 0000:00:14.0: remove, state 1
[ +0.000013] usb usb1: USB disconnect, device number 1
[ +0.000006] usb 1-3: USB disconnect, device number 2
[ +0.000005] usb 1-3.2: USB disconnect, device number 8
[ +0.000623] usb 1-3.3: USB disconnect, device number 7
[ +0.002301] usb 1-4: USB disconnect, device number 3
[ +0.000009] usb 1-4.1: USB disconnect, device number 6
[ +0.065014] usb 1-11: USB disconnect, device number 5
[ +0.002165] xhci_hcd 0000:00:14.0: USB bus 1 deregistered
[ +0.023638] [UFW BLOCK] IN=wlp3s0 OUT= MAC=f8:9e:94:9c:4f:4b:20:a6:cd:cb:4d:6e:08:00 SRC=192.168.5.84 DST=192.168.5.210 LEN=165 TOS=0x00 PREC=0x00 TTL=64 ID=24364 DF PROTO=UDP SPT=161 DPT=45801 LEN=145
[ +0.997615] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ +0.000019] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ +0.001145] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000001109810
[ +0.000086] [UFW BLOCK] IN=wlp3s0 OUT= MAC=f8:9e:94:9c:4f:4b:20:a6:cd:cb:4d:6e:08:00 SRC=192.168.5.84 DST=192.168.5.210 LEN=165 TOS=0x00 PREC=0x00 TTL=64 ID=25832 DF PROTO=UDP SPT=161 DPT=45801 LEN=145
[ +0.000854] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.13
[ +0.000008] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ +0.000005] usb usb1: Product: xHCI Host Controller
[ +0.000003] usb usb1: Manufacturer: Linux 5.13.0-28-generic xhci-hcd
[ +0.000004] usb usb1: SerialNumber: 0000:00:14.0
[ +0.000293] hub 1-0:1.0: USB hub found
[ +0.000044] hub 1-0:1.0: 16 ports detected
[ +0.001936] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ +0.000004] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ +0.000001] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
[ +0.000030] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.13
[ +0.000002] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ +0.000001] usb usb2: Product: xHCI Host Controller
[ +0.000001] usb usb2: Manufacturer: Linux 5.13.0-28-generic xhci-hcd
[ +0.000001] usb usb2: SerialNumber: 0000:00:14.0
[ +0.000126] hub 2-0:1.0: USB hub found
[ +0.000039] hub 2-0:1.0: 10 ports detected
[ +0.335640] usb 1-3: new high-speed USB device number 2 using xhci_hcd
[ +0.148299] usb 1-3: New USB device found, idVendor=04b4, idProduct=6506, bcdDevice=50.00
[ +0.000012] usb 1-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ +0.001188] hub 1-3:1.0: USB hub found
[ +0.000051] hub 1-3:1.0: 4 ports detected
[ +0.126476] usb 2-3: new SuperSpeed USB device number 2 using xhci_hcd
[ +0.024210] usb 2-3: New USB device found, idVendor=04b4, idProduct=6504, bcdDevice=50.00
[ +0.000012] usb 2-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ +0.001364] hub 2-3:1.0: USB hub found
[ +0.000033] hub 2-3:1.0: 4 ports detected
[ +0.126330] usb 1-4: new high-speed USB device number 3 using xhci_hcd
[ +0.151209] usb 1-4: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=23.11
[ +0.000011] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ +0.000005] usb 1-4: Product: USB2.1 Hub
[ +0.000003] usb 1-4: Manufacturer: GenesysLogic
[ +0.003696] hub 1-4:1.0: USB hub found
[ +0.000305] hub 1-4:1.0: 2 ports detected
[ +0.121004] usb 2-4: new SuperSpeed USB device number 3 using xhci_hcd
[ +0.022450] usb 2-4: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=23.11
[ +0.000010] usb 2-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ +0.000005] usb 2-4: Product: USB3.2 Hub
[ +0.000003] usb 2-4: Manufacturer: GenesysLogic
[ +0.004580] hub 2-4:1.0: USB hub found
[ +0.000346] hub 2-4:1.0: 2 ports detected
[ +0.076368] usb 1-3.2: new high-speed USB device number 4 using xhci_hcd
[ +0.104966] usb 1-3.2: New USB device found, idVendor=04b4, idProduct=1003, bcdDevice= 0.00
[ +0.000013] usb 1-3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ +0.000005] usb 1-3.2: Product: PERCIPIO DEVICEEE
[ +0.000004] usb 1-3.2: Manufacturer: PERCIPIO
[ +0.000004] usb 1-3.2: SerialNumber: 207000134827
[ +0.079442] usb 2-3.1: new SuperSpeed USB device number 4 using xhci_hcd
[ +0.147625] usb 1-11: new full-speed USB device number 5 using xhci_hcd
[ +0.027967] usb 2-3.1: New USB device found, idVendor=1689, idProduct=2304, bcdDevice= 1.06
[ +0.000013] usb 2-3.1: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ +0.000005] usb 2-3.1: Product: USB Camera
[ +0.000004] usb 2-3.1: Manufacturer: Generic
[ +0.000003] usb 2-3.1: SerialNumber: 200901010001
[ +0.017864] usb 2-3.1: Found UVC 1.00 device USB Camera (1689:2304)
[ +0.103944] usb 1-11: New USB device found, idVendor=8087, idProduct=0029, bcdDevice= 0.01
[ +0.000014] usb 1-11: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ +0.102343] usb 1-4.1: new high-speed USB device number 6 using xhci_hcd
[ +0.023557] Bluetooth: hci0: Firmware revision 0.0 build 121 week 36 2020
[ +0.001995] input: USB Camera: KingSen 8M camera as /devices/pci0000:00/0000:00:14.0/usb2/2-3/2-3.1/2-3.1:1.0/input/input22
[ +0.059975] Bluetooth: hci0: MSFT filter_enable is already on
[ +0.088212] usb 1-4.1: New USB device found, idVendor=2bc5, idProduct=050b, bcdDevice= 1.00
[ +0.000003] usb 1-4.1: New USB device strings: Mfr=2, Product=1, SerialNumber=3
[ +0.000002] usb 1-4.1: Product: USB 2.0 Camera
[ +0.000001] usb 1-4.1: Manufacturer: Sonix Technology Co., Ltd.
[ +0.000001] usb 1-4.1: SerialNumber: AQCD5220069
[ +0.011090] usb 1-4.1: Found UVC 1.00 device USB 2.0 Camera (2bc5:050b)
[ +0.014220] input: USB 2.0 Camera: USB Camera as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.1/1-4.1:1.0/input/input23
[ +0.012723] usb 1-3.3: new full-speed USB device number 7 using xhci_hcd
[ +0.105408] usb 1-3.3: New USB device found, idVendor=2886, idProduct=0018, bcdDevice= 2.00
[ +0.000003] usb 1-3.3: New USB device strings: Mfr=1, Product=3, SerialNumber=0
[ +0.000001] usb 1-3.3: Product: ReSpeaker 4 Mic Array (UAC1.0)
[ +0.000001] usb 1-3.3: Manufacturer: SEEED
[ +0.078925] usb 2-4.2: new SuperSpeed USB device number 5 using xhci_hcd
[ +0.020063] usb 2-4.2: New USB device found, idVendor=2bc5, idProduct=060b, bcdDevice= 0.01
[ +0.000005] usb 2-4.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ +0.000002] usb 2-4.2: Product: ORBBEC Depth Sensor
[ +0.000002] usb 2-4.2: Manufacturer: Orbbec(R)
[ +0.083657] usb 2-3.4: new SuperSpeed USB device number 6 using xhci_hcd
[ +0.020401] usb 2-3.4: LPM exit latency is zeroed, disabling LPM.
[ +0.000543] usb 2-3.4: New USB device found, idVendor=04b4, idProduct=03f2, bcdDevice= 0.00
[ +0.000002] usb 2-3.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ +0.000001] usb 2-3.4: Product: FX3
[ +0.000001] usb 2-3.4: Manufacturer: Arducam
[Dec12 07:55] [UFW BLOCK] IN=wlp3s0 OUT= MAC=01:00:5e:00:00:fb:52:44:e2:4a:b3:39:08:00 SRC=192.168.5.115 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=23742 PROTO=2
[Dec12 07:56] usb 1-3.2: usbfs: process 40146 (nodelet) did not claim interface 0 before use
[ +18.131900] nodelet[40063]: segfault at 7f0ab3fff9d0 ip 00007f0b65413aab sp 00007ffffd859ac0 error 4 in libpthread-2.31.so[7f0b65410000+11000]
[ +0.000026] Code: 0f 1e fa 41 57 41 56 41 55 41 54 55 53 48 83 ec 68 64 48 8b 04 25 28 00 00 00 48 89 44 24 58 31 c0 48 85 ff 0f 84 cd 01 00 00 <8b> 87 d0 02 00 00 49 89 ff 85 c0 0f 88 bc 01 00 00 48 39 bf 28 06
[ +0.135168] [UFW BLOCK] IN=wlp3s0 OUT= MAC=01:00:5e:00:00:fb:52:44:e2:4a:b3:39:08:00 SRC=192.168.5.115 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=37286 PROTO=2
[ +5.604602] usb 1-3.2: usbfs: process 51454 (nodelet) did not claim interface 0 before use
[ +6.773748] TCP: request_sock_TCP: Possible SYN flooding on port 43147. Sending cookies. Check SNMP counters.
[ +1.375988] TCP: request_sock_TCP: Possible SYN flooding on port 45315. Sending cookies. Check SNMP counters.
[Dec12 07:59] TCP: request_sock_TCP: Possible SYN flooding on port 46793. Sending cookies. Check SNMP counters.
[ +6.753962] xhci_hcd 0000:00:14.0: ERROR Unknown event condition 198 for slot 6 ep 2 , HC probably busted
[ +0.000373] xhci_hcd 0000:00:14.0: ERROR Unknown event condition 198 for slot 6 ep 2 , HC probably busted
[ +0.000375] xhci_hcd 0000:00:14.0: ERROR Unknown event condition 198 for slot 6 ep 2 , HC probably busted
[ +0.000374] xhci_hcd 0000:00:14.0: ERROR Unknown event condition 198 for slot 6 ep 2 , HC probably busted
[ +0.000138] xhci_hcd 0000:00:14.0: WARN waiting for error on ep to be cleared
[ +0.000001] uvcvideo 2-3.1:1.1: Failed to resubmit video URB (-22).
[ +0.798893] TCP: request_sock_TCP: Possible SYN flooding on port 36415. Sending cookies. Check SNMP counters.
[ +14.351165] usb 1-3.2: USB disconnect, device number 4
[ +0.232865] usb 1-3.2: new high-speed USB device number 8 using xhci_hcd
[ +0.104538] usb 1-3.2: New USB device found, idVendor=04b4, idProduct=1003, bcdDevice= 0.00
[ +0.000003] usb 1-3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ +0.000002] usb 1-3.2: Product: PERCIPIO DEVICEEE
[ +0.000001] usb 1-3.2: Manufacturer: PERCIPIO
[ +0.000000] usb 1-3.2: SerialNumber: 207000134827
[ +0.273252] [UFW BLOCK] IN=wlp3s0 OUT= MAC=f8:9e:94:9c:4f:4b:20:a6:cd:cb:4d:6e:08:00 SRC=192.168.5.84 DST=192.168.5.210 LEN=165 TOS=0x00 PREC=0x00 TTL=64 ID=20391 DF PROTO=UDP SPT=161 DPT=37229 LEN=145
[ +1.004630] [UFW BLOCK] IN=wlp3s0 OUT= MAC=f8:9e:94:9c:4f:4b:20:a6:cd:cb:4d:6e:08:00 SRC=192.168.5.84 DST=192.168.5.210 LEN=165 TOS=0x00 PREC=0x00 TTL=64 ID=36396 DF PROTO=UDP SPT=161 DPT=37229 LEN=145
Reboot/power cycle helps to recover from this. Sometimes restarting USB controller helps:
echo -n "0000:00:14.0" | sudo tee /sys/bus/pci/drivers/xhci_hcd/unbind; sleep 1; echo -n "0000:00:14.0" | sudo tee /sys/bus/pci/drivers/xhci_hcd/bind
- What help do you need?
I would like to know the reason for this inconsistent behavior from SDK. Some debug hints or suggested solutions are also welcome.
