When I run the UVC serial number program it just pops up an error saying “unknown device”. I can’t get past that at all.
Setup:
4x B0200 cameras (IMX291)
Windows 10
Tested with OBS, amcap.exe (AMCap) and the built-in Windows 10 Camera app
All four cameras work fine in those apps, they show up and I can preview from them no problem. One of the cameras is a different hardware version from the other three. Not sure if that matters.
Hi, thanks for the details. A few quick things to rule out first, since this tool is a bit picky about the camera being in use:
Did you fully quit AMCap (and OBS / Windows Camera app) before running the serial number program? The tool can’t grab the device if another app has it open, and it will often report “unknown device” instead of a clearer error.
Which USB port are you using? USB hubs and USB 3 ports can sometimes cause this.
Are you able to test a single camera on its own, with nothing else plugged in?
Can you confirm those and let me know what happens?
Thanks, that rules out the usual suspects. Since all four cameras preview fine in OBS/AMCap/Windows Camera but the serial number tool still reports “unknown device”, this points at something in the firmware/hardware rather than your setup.
One thing that stands out: you mentioned one camera is a different hardware version than the other three. We suspect a firmware/hardware change is affecting the ability to write the serial number, and the mixed versions could be part of it. I’m escalating this to our hardware engineer to look at producing a fixed firmware.
In the meantime, could you send me a clear photo of the front and the back of each camera? That will let us confirm the versions before the engineer builds the firmware.
Ok, sent over the front and back pictures for all four cameras. Let me know if you need anything else. I’m guessing I just wait for the new firmware now?
Got the photos, thank you. Our hardware engineer is building a new firmware for the camera that will let the serial number be modified again. Expect it within about two days (possible these two days).
Once it’s ready I’ll send it to you through private message along with the instructions to reprogram the camera. After reprogramming you should be able to run the UVC serial number tool without the “unknown device” error.
Thanks for hanging in there. The updated firmware for the B0200/IMX291 is now ready and we’ve already tested it on our side before releasing it — it enables modifying the serial number (device name), which the original firmware/hardware didn’t allow. That’s what was producing the “unknown device” error in the UVC serial number tool.
I’ve sent you the firmware download link through private message. Please download it and reprogram the camera with that file, then try modifying the serial number again. Let us know how it goes and whether you hit any issues with the other cameras too — happy to help if anything comes up after the update.
