Hi, I bought an ArduCAM product and I’m trying to follow the instruction manual, but I can’t open your webpage at all. The page I need is this one: https://www.arducam.com/docs/camera-for-raspberry-pi/raspberry-pi-libcamera-guide/ It just won’t load for me. The only way I can get anything to download is by using a VPN (翻墙). Without that I can’t open the page. Any idea what’s going on?
Hi, sorry to hear you’re stuck. Let’s figure out whether it’s the page itself or your connection. A few quick questions:
- What OS and browser are you using?
- When you open that URL, does it time out, show an error, or just hang forever?
- Can you open the main site https://www.arducam.com at all, or only the docs page fails?
If you can, open the browser dev tools (F12) → Network tab, reload the page, and tell me what the state of the failing request is (pending / failed / timeout).
I’m in mainland China (that might matter). On my PC and on my phone it’s the same - the page just spins and eventually times out. The main arducam.com also fails for me, not only the docs page. No error code, it just hangs. I tried Chrome and Edge, same result. I haven’t tried any other OS.
With a VPN on, everything loads fine and I can download the files I need. Without it, nothing on the site is reachable.
That helps a lot. This smells like a network routing / regional access problem rather than a broken page, since it fails from both your phone and PC and only works over VPN.
Can you run a couple of checks and paste the output?
On Windows: nslookup www.arducam.com and ping www.arducam.com
If you have curl: curl -v --max-time 15 https://www.arducam.com/docs/camera-for-raspberry-pi/raspberry-pi-libcamera-guide/
Also try switching your DNS to 8.8.8.8 or 1.1.1.1 and see if that changes anything.
Ok, I ran those.
nslookup returns an IP fine, so DNS resolves. But ping www.arducam.com just times out (100% packet loss).
curl -v hangs at the TLS/connect stage and then times out after 15s, no HTTP response at all.
I also switched my DNS to 8.8.8.8 and 1.1.1.1 and flushed the cache - same result, still can’t reach the site. Only the VPN makes it work. I don’t have any logs beyond that.
Thanks, that’s clear. DNS resolving but TCP/TLS timing out means the connection is being blocked or dropped somewhere between your ISP and our servers - not something on your machine or a bad URL. We can’t change ISP-level routing from our side, unfortunately.
Some options while you’re behind that network:
- Use a VPN as you’re already doing to reach the docs.
- Try the docs from a different network (mobile hotspot on another carrier, or a friend’s connection) to confirm.
- We also mirror some content elsewhere, so let me see what I can provide directly.
Which exact files/images do you need from the Raspberry Pi libcamera guide?
I mainly need the Raspberry Pi libcamera setup guide steps and the files that go with it - I’m building a camera for Raspberry Pi and the manual keeps pointing me back to that docs page. That’s exactly the page I can’t reach without VPN. If you can send what’s on it, that would solve my problem.
Got it. I’ve sent the relevant guide and the associated files to you through private message - please check your messages and try it from there.
In the meantime, could you also test whether the plain file host is reachable without VPN? Sometimes the CDN is blocked but a direct download endpoint isn’t. Try opening the same link over http instead of https, and let me know if that changes anything.
I checked the private message, thank you - I can download from there. I tried the http version of the docs URL and it also fails without VPN, same timeout. So the whole site seems blocked from my network, not just one protocol or page.
That confirms it. Here’s where we stand:
- The URL https://www.arducam.com/docs/camera-for-raspberry-pi/raspberry-pi-libcamera-guide/ is not directly reachable from your domestic (China) network.
- DNS resolves fine, but TCP/TLS connections time out, so the traffic is being blocked upstream of your machine.
- It fails on multiple devices and browsers, and changing DNS doesn’t help.
- It only works with a VPN, which is why you couldn’t follow the manual or download the files without one.
This is a network/accessibility issue, not a product or documentation defect. Since we can’t change ISP-level routing, the practical workarounds are: use the VPN (as you’re doing), open the docs from another network, or use the guide and files I sent you privately.
If the plain site still works for you over VPN, you’re all set to continue the libcamera setup. Let us know if you hit any errors once you’re into the configuration steps and we’ll take it from there.
