Cannot multiplex two OV5647 cameras using libcamera on Pi Zero W Arducam Doubleplexer
Hi everyone, hoping someone here has hit this before. I’ve got the Arducam Multi-Camera Adapter Doubleplexer Stereo Module V2 (UC-444) on a Raspberry Pi Zero W V1.1. The adapter won’t detect my Raspberry Pi 5MP OV5647 cameras on either port. The strange part is it works fine with my 8MP IMX219 cameras, so the board itself seems okay, but the OV5647 modules just never show up. Has anyone else seen this?
Thanks for posting. Just so you know, the old setup guide you’re probably following (the Multi_Adapter_Board_2Channel_uc444 readme on the ArduCAM GitHub) is no longer supported. Please abandon those steps and use the current Quick Start Guide instead: Quick Start Guide for Multi-Camera Adapter Board - Arducam Wiki — make sure you’re on the ‘dual camera adapter board (B016601)’ section. Try that flow and report back.
Update after going through the new guide. Here’s what I’ve verified:
  • 2x Arducam UC-261 and 2x Arducam Pi camera Rev 1.3 all work fine on their own.
  • Connecting any of them through the doubleplexer gives ‘Camera frontend has timed out!’ in libcamera.
  • The doubleplexer itself is confirmed working with Raspberry Pi V2 (IMX219) cameras using the Arducam GitHub examples.
    The product page claims support for up to two 5MP OV5647 / 8MP IMX219 / 12.3MP IMX477 / 12MP IMX708 cameras with no mixing, so OV5647 should be supported.
    There’s also a separate problem on top of this: I can’t multiplex between the two OV5647s in the same libcamera process. I have to close and reopen the camera each time, which is way too slow for video. Flipping the SEL pin with arducam_multi_adapter_uc444.py doesn’t work when the camera-mux-2port overlay is loaded.
Let’s focus on the OV5647 timeout first since that’s blocking everything. Can you share the full environment — OS/kernel, libcamera version, which overlay is in config.txt, and the media device nodes you’re seeing? Also, which exact scripts are you running for the multiplexing tests?
Here you go:
Thanks. Can you run the UC-444 script again with camera-mux-2port loaded and paste the entire terminal output? I’d like to see exactly where it dies.
Sure, here’s the full run:
pi@raspberrypi:~/RaspberryPi/Multi_Camera_Adapter/Multi_Adapter_Board_2Channel_uc444 $ python3 arducam_multi_adapter_uc444.py
[1:51:05.030547527] [1914]  INFO Camera camera_manager.cpp:297 libcamera v0.0.5+83-bde9b04f
[1:51:05.082212805] [1915]  INFO RPI vc4.cpp:437 Registered camera /base/soc/i2c0mux/i2c@1/pca@70/i2c@0/ov5647@36 to Unicam device /dev/media3 and ISP device /dev/media0
[1:51:05.082447699] [1915]  INFO RPI pipeline_base.cpp:1101 Using configuration file '/usr/share/libcamera/pipeline/rpi/vc4/rpi_apps.yaml'
[1:51:05.108938276] [1915]  INFO RPI vc4.cpp:437 Registered camera /base/soc/i2c0mux/i2c@1/pca@70/i2c@1/ov5647@36 to Unicam device /dev/media3 and ISP device /dev/media0
[1:51:05.109145357] [1915]  INFO RPI pipeline_base.cpp:1101 Using configuration file '/usr/share/libcamera/pipeline/rpi/vc4/rpi_apps.yaml'
Error: Could not set address to 0x70: Device or resource busy
init1 A
[1:51:06.098146049] [1923]  INFO Camera camera_manager.cpp:297 libcamera v0.0.5+83-bde9b04f
[1:51:06.184780223] [1926]  INFO RPI vc4.cpp:437 Registered camera /base/soc/i2c0mux/i2c@1/pca@70/i2c@0/ov5647@36 to Unicam device /dev/media3 and ISP device /dev/media0
[1:51:06.185022148] [1926]  INFO RPI pipeline_base.cpp:1101 Using configuration file '/usr/share/libcamera/pipeline/rpi/vc4/rpi_apps.yaml'
[1:51:06.224097940] [1926]  INFO RPI vc4.cpp:437 Registered camera /base/soc/i2c0mux/i2c@1/pca@70/i2c@1/ov5647@36 to Unicam device /dev/media3 and ISP device /dev/media0
[1:51:06.224329188] [1926]  INFO RPI pipeline_base.cpp:1101 Using configuration file '/usr/share/libcamera/pipeline/rpi/vc4/rpi_apps.yaml'
[1:51:06.238205487] [1923]  INFO Camera camera.cpp:1033 configuring streams: (0) 320x240-BGR888 (1) 640x480-SGBRG10_CSI2P
[1:51:06.239085324] [1926]  INFO RPI vc4.cpp:565 Sensor: /base/soc/i2c0mux/i2c@1/pca@70/i2c@0/ov5647@36 - Selected sensor format: 640x480-SGBRG10_1X10 - Selected unicam format: 640x480-pGAA
init1 B
[1:51:09.011587765] [1923]  INFO Camera camera_manager.cpp:297 libcamera v0.0.5+83-bde9b04f
[1:51:09.103278568] [1936]  INFO RPI vc4.cpp:437 Registered camera /base/soc/i2c0mux/i2c@1/pca@70/i2c@0/ov5647@36 to Unicam device /dev/media3 and ISP device /dev/media0
[1:51:09.103477733] [1936]  INFO RPI pipeline_base.cpp:1101 Using configuration file '/usr/share/libcamera/pipeline/rpi/vc4/rpi_apps.yaml'
[1:51:09.133635365] [1936]  INFO RPI vc4.cpp:437 Registered camera /base/soc/i2c0mux/i2c@1/pca@70/i2c@1/ov5647@36 to Unicam device /dev/media3 and ISP device /dev/media0
[1:51:09.133832967] [1936]  INFO RPI pipeline_base.cpp:1101 Using configuration file '/usr/share/libcamera/pipeline/rpi/vc4/rpi_apps.yaml'
[1:51:09.147522289] [1923]  INFO Camera camera.cpp:1033 configuring streams: (0) 320x240-BGR888 (1) 640x480-SGBRG10_CSI2P
[1:51:09.148367282] [1936]  INFO RPI vc4.cpp:565 Sensor: /base/soc/i2c0mux/i2c@1/pca@70/i2c@0/ov5647@36 - Selected sensor format: 640x480-SGBRG10_1X10 - Selected unicam format: 640x480-pGAA
[1:51:10.225229282] [1936]  WARN V4L2 v4l2_videodevice.cpp:2007 /dev/video0[16:cap]: Dequeue timer of 1000000.00us has expired!
[1:51:10.225518394] [1936] ERROR RPI pipeline_base.cpp:1333 Camera frontend has timed out!
[1:51:10.225640997] [1936] ERROR RPI pipeline_base.cpp:1334 Please check that your camera sensor connector is attached securely.
[1:51:10.225761778] [1936] ERROR RPI pipeline_base.cpp:1335 Alternatively, try another cable and/or sensor.
That log is really useful. Two things stand out:
  • ‘Error: Could not set address to 0x70: Device or resource busy’ keeps appearing when the script tries to address the I2C mux. That suggests the script and the camera-mux-2port overlay are both trying to control the mux at 0x70.
  • Both OV5647 sensors do register (ov5647@36 on mux ports 0 and 1), but the capture path then fails with ‘Camera frontend has timed out!’ and the V4L2 dequeue timer expiring. So the sensor enumerates, but no frames are actually delivered.
    Can you give me a full list of everything you’ve tried, including what worked and what didn’t?
Here’s the complete list:
  • camera-mux-2port overlay: works for taking pictures with the OV5647 cameras individually.
  • arducam_multi_adapter_uc444.py with the overlay loaded: fails with ‘Could not set address to 0x70: Device or resource busy’ and ‘Camera frontend has timed out!’.
  • picamera2 multicamera_preview.py with multiple camera instances: fails, similar to [HOW-TO] Cleanly Close and Configure Cameras with Arducam Multicam v2.2 · Issue #1008 · raspberrypi/picamera2 · GitHub.
  • 2x Arducam UC-261 and 2x Arducam Pi camera Rev 1.3 without the doubleplexer: all verified working.
  • Same cameras through the doubleplexer: libcamera reports ‘Camera frontend has timed out!’.
  • Doubleplexer with Raspberry Pi V2 cameras: works using the Arducam GitHub examples.
Thanks, that matches everything so far. Let me recap where we are: you need video from both cameras, but starting/stopping each camera to grab a frame only gets around 0.5 fps. You bought the board based on the ~20us switching time mentioned at https://www.arducam.com/robot-fish-swarm-multi-camera/ but no software example you’ve found reaches even 2fps. The picamera2 multicamera_preview.py example also fails, same as the issue you linked. Let me confirm a couple of details on our end before I give you a definitive answer.
Thanks. To be direct — is there any way at all to get both OV5647 cameras working in the same process for video capture with this board?
Here’s the conclusion from our side. The doubleplexer is a multiplexer: only one of the two cameras can be activated at a time, and they operate alternately — the product description states this explicitly. That means both cameras cannot run concurrently in the same process with libcamera, which is the root cause of what you’re hitting with the OV5647s and the multiplexing attempts. The ‘Camera frontend has timed out!’ is the same underlying limitation: with the overlay holding the mux, the SEL/I2C switching the script expects can’t happen cleanly.
For simultaneous dual-camera video you’ll need different hardware:
Details on the doubleplexer itself: Arducam Multi Camera Adapter Doubleplexer Stereo Module V2 for Raspberry Pi Zero, Pi 3/3 b+, 4b
That clears it up, thanks. So the board alternates cameras rather than running them side by side, which means concurrent libcamera in the same process was never going to work. I’ll look into the camarray HAT as the alternative for dual-camera use. Appreciate the help.
