Hey everyone, I’m trying to get my ArduCam PTZ Lens and Controller mounted onto an Arducam for Raspberry Pi HQ Camera Module (the 12.3MP IMX477 one). I’m running a Raspberry Pi 5.
The problem: the two screws that came with the IMX477 camera module don’t fit the mounting holes on the PTZ Lens. Has anyone else run into this? What’s the correct screw size for mounting the PTZ lens?
Quick update — I’ve been testing different screw sizes and no luck so far:
M2 screws: too big, don’t fit
M2.5 screws: also don’t fit
Also, something I noticed: the screws that came with the IMX477 are machine screws (flat tip). But looking at photos of the PTZ lens assembly, it looks like the screws needed are pointed self-tapping screws, not machine screws. That might explain why nothing is threading properly.
Hi there — I took a look at the photo you uploaded, and I think I see the issue. The ArduCam PTZ lens is designed to mount directly onto the camera board that comes included in the PTZ kit. It’s not meant to be used with a separate C-CS mount adapter or a standalone camera board like the IMX477.
For assembly, you should only use the components from the original ArduCam PTZ kit. The C-CS adapter and any separate camera board won’t be compatible with the PTZ lens. Hope that helps clarify things.
I appreciate the response, but here’s the thing — the PTZ Lens kit I received did NOT include a camera board at all. That’s exactly why I’m trying to mount it onto the separately purchased Arducam IMX477 HQ Camera Module.
Also, I still haven’t gotten an answer to my actual question: what size screws are needed? From photos, they look like pointed self-tapping screws, not the machine screws that come with the IMX477. I just need to know what screws to use so I can actually assemble this thing. Can anyone from Arducam confirm the screw specification?
Still waiting on a clear answer about the screw size. Support mentioned the PTZ lens is only compatible with the camera board included in the PTZ kit — but again, no camera board came in my PTZ Lens box, and no screws either. So I’m stuck.
Re-uploading the photo for reference:
At this point I just need the screw size so I can source them myself.
Alright, I ended up solving this myself. I tested roughly 20 different screw sizes and finally found the one that fits:
The correct screw size is M1.7.
These are the small self-tapping type. For anyone else in the same situation, don’t bother with M2 or M2.5 — they’re too big. M1.7 self-tapping screws are what you need to mount the PTZ lens.
Arducam — you really should include these M1.7 screws in the PTZ Lens box for future customers. Would save a lot of headache.
Thanks for the update, and glad you were able to figure it out. Just to reiterate for anyone reading this thread — we don’t recommend detaching the lens from the camera board on the B016712MP model. The PTZ Lens and the C-CS mount adapter (B0240) are not designed to be compatible with each other.
As for the screw size specification for the PTZ Lens — I wasn’t able to find it documented anywhere internally, so you genuinely went further than we could on that front. Glad you identified M1.7 as the correct size and thanks for sharing it here — that’s definitely helpful for others who might run into the same situation.
