Hi all, I’m stuck trying to install the Arducam driver on a Jetson Nano. The installer fails right away with:
Cannot find the corresponding deb package, please send the following information to support
Kernel version: 4.9.337-tegra-32.7.4-20230608212426
Jetson type: NVIDIA Jetson Nano Developer Kit
I followed the native camera quick start guide, but it stops at the driver install step. Has anyone seen this?
Can you tell me which exact camera module you have? That installer picks a matching deb package based on the board/kernel combination, so that error usually means it can’t find a match for your setup. The module model will help narrow it down.
Sure, it’s the Arducam 12MP*4 477P Quadrascopic Camera Bundle Kit (the one for Raspberry Pi, Jetson Nano, Xavier NX, AGX Orin, Orin Nano, Orin NX). Board is a Jetson Nano running the SD card image from NVIDIA’s get started page.
I followed the native camera quick start guide, and then the quadcam array guide. To get past the deb package error I downgraded the kernel. The installer completes now, but I still can’t read from the camera (screenshot attached).
Thanks. imx477_stereo is the right mode for the quad array on the Nano, but let’s reset the baseline because a kernel downgrade can leave the image in a messy state.
Can you confirm the SD card image is the one from:
Then follow the native camera quick start guide and run:
Thanks for the photos. Looking at them, it seems the wiring might be upside down. Can you also show me the back of these imx477 camera modules? I want to compare the orientation against the reference images.
Quick update, and a new problem. The system crashed suddenly while it was working, and after the crash none of the cameras can be detected anymore. I reinstalled everything from scratch and they still don’t show up. I really don’t think this is a hardware problem.
Okay, let’s summarize where we are. The original deb package error was worked around by downgrading the kernel, but after that the cameras still couldn’t be read. From the connection photos, I suspected the imx477 module wiring was upside down, and we were waiting on photos of the back of the modules to confirm the orientation. Then the system crashed, and after a full reinstall the cameras aren’t detected at all.
Next step is to double-check the camera module and data cable orientation against the reference images, and confirm what kernel version you’re running after the reinstall. If you can paste the current kernel version and any detection output, we can keep going from there.
