Hi everyone, I’m stuck trying to install the ArduCam IMX519 kernel driver on my Raspberry Pi. The install keeps failing with an “unsupported kernel version” error.
My setup:
Hardware Revision: a02082
Kernel Version: 6.1.21-v7+
Package: imx519_kernel_driver – bullseye-v5
I’m using the official SD card image from Raspberry Pi and I have not run rpi-update. Has anyone run into this?
Can you share the full error output from the script, plus the exact commands you’ve run so far? That will help narrow down whether the script is picking the wrong package for your kernel.
Package: imx519_kernel_driver -- bullseye-v5
You are using an unsupported kernel version, please install the official SD Card image(do not execute rpi-update):
https://www.raspberrypi.com/software/operating-systems/
I also cloned the manual focus application repo as step 7:
Thanks for the full log. That “unsupported kernel version” message means the script can’t find a matching package for kernel 6.1.21-v7+ under the bullseye-v5 package set. The 6.1.21-v7+ kernel isn’t supported by the imx519_kernel_driver bullseye-v5 package, so the package lookup fails.
Got it. So refreshing the install package doesn’t change the outcome, which points back to the kernel being the blocker. The imx519_kernel_driver bullseye-v5 package doesn’t have a build for 6.1.21-v7+.
Even though you’re on the official image as reported, the kernel version you’re running still isn’t matched by that driver package, so that’s the part that needs to be resolved.
