Hi everyone, I’m trying to get two Quadrascopic camera systems working with a Raspberry Pi 5 and I just can’t get a successful setup going. I’ve done a lot of research and tried various approaches, but nothing has worked so far. I’m flexible on the OS side if there’s a recommended and tested one for this.
Welcome! Could you share the exact hardware you’re working with, and a bit more about what ‘not working’ looks like? Any error messages, and which OS you’ve tried so far? That would help narrow things down.
Sure. It’s the Quadrascopic 1MP*4 OV9281 camera bundle kit with USB-C. The boards are 2x ArduCam UC-512 Rev.D1 and 8x ArduCam UC-788 Rev.B, all going to a Raspberry Pi 5. Honestly I haven’t captured any logs yet - I’ve just been trying different methods I found in forum posts and none of them got me a clean setup. That’s why I’m hoping for the officially recommended method.
Thanks, that helps. Just so we’re on the same page: the UC-512 and UC-788 are the camera board revisions in that OV9281 kit, and you’re trying to run both Quadrascopic systems off one Pi 5. Before we jump to a full setup guide, the most important thing is to confirm the Pi actually sees the cameras. Which OS are you on right now, or have you been switching between a few?
I’ve tried a couple of OSes, but I’d rather stop guessing. If there’s a specific OS that’s known to work best for this kit on the Pi 5, I’ll start fresh with that. Do you have a recommended one, plus step-by-step instructions for getting both systems up together?
A good starting point is Raspberry Pi OS (Bookworm) 64-bit. But even the ‘tested’ path depends on your setup - two Quadrascopic systems on one Pi 5 is a lot of USB traffic, so we need to see how the devices enumerate. Can you plug in one system at a time and run lsusb and dmesg | tail -n 50 right after connecting, then post the output? That will tell us whether this is a detection, driver, or bandwidth issue.
Got it, I’ll do that and post the output. While I’m at it - is there an official setup doc for the Quadrascopic OV9281 + Pi 5 combination? I’d rather follow something tested than keep stitching together random posts.
Yes, the ArduCam docs cover the Quadrascopic kit, and I’d follow those for the base install. For now, though, we don’t have a root cause identified yet because there’s no error info or logs from the failed attempts. Once you share the OS you’re using, the lsusb output, and the dmesg tail, we can start ruling things out. Also helpful to know: are you connecting both systems through a hub, or straight into the Pi’s USB ports?
I’ve been connecting them straight into the Pi, no hub. I’ll grab the outputs and post back. Just to confirm the end goal: both Quadrascopic systems running at the same time on the one Pi 5.
Correct, that’s the goal. To summarize where things stand: no root cause yet and no workaround yet, because we’re missing the basic detection details. Once you post lsusb and dmesg output, plus the OS you’re on, we’ll know whether the cameras are even enumerating. That’s the first checkpoint - everything else depends on it.
