Cannot find libcamera_dev package on Raspberry Pi 3B (stretch, kernel 4.19.66-v7+)
Hi, I’m trying to install libcamera on my Raspberry Pi 3B but the install keeps failing. I get this message:
Hardware Revision: a02082
Kernel Version: 4.19.66-v7+
Package: libcamera_dev – stretch
Setup is a Pi 3B, hardware revision a02082, kernel 4.19.66-v7+, and it seems to be looking for libcamera_dev for stretch. What am I doing wrong here?
Hi, thanks for the details. That error basically means the script couldn’t match a libcamera_dev package build for the OS release it detected (‘stretch’) on your hardware revision/kernel combo. Before I can point you to the right package, I need to know which Arducam product you’re actually using, since the install steps and packages differ between the pivariety line and the autofocus camera line. Could you tell me which product you purchased? A couple of photos of the board/camera or the purchase link would help a lot.
Ah sorry, should have said up front. I’m using a B0176 autofocus camera with the Pi 3B, trying to drive it through libcamera. I used the Arducam Pivariety V4L2 Driver install script:
Then running the installer it fails with the same message:
I attached a couple of photos of the camera and the board. Also, just to be clear, this is the same Pi I first reported - nothing about the hardware changed.
Thanks, that clears things up. So the setup is: Raspberry Pi 3B (rev a02082), kernel 4.19.66-v7+, Raspbian stretch, B0176 autofocus camera, and you’re running the pivariety install script which is looking for ‘libcamera_dev – stretch’. The script only prints that ‘Cannot find the corresponding package’ message when it can’t find a matching package for the OS release it detects, so at this point it looks like there’s no libcamera_dev build for stretch being picked up on your combo. Can you paste the lines the script prints just before it errors, so we can see what OS/package it thinks it detected? Also, what does cat /etc/os-release show on that Pi?
Here’s what /etc/os-release gives me:
PRETTY_NAME=“Raspbian GNU/Linux 9 (stretch)”
NAME=“Raspbian GNU/Linux”
VERSION_ID=“9”
VERSION=“9 (stretch)”
ID=raspbian
ID_LIKE=debian
And the script output before the error is basically just the menu where I pick libcamera, then it goes straight to the ‘Cannot find the corresponding package…’ block with the hardware revision, kernel and ‘libcamera_dev – stretch’ lines. No other error above it. I haven’t gotten any further than that - the install just doesn’t complete.
OK, so to summarize where we are: you’re on a Pi 3B (rev a02082), kernel 4.19.66-v7+, Raspbian stretch, using the B0176 autofocus camera with the pivariety install script. The installer is failing because it can’t find the libcamera_dev package for the stretch release on your setup, which is exactly what the ‘Cannot find the corresponding package’ text means. We haven’t pinned down the root cause yet, so there’s no working install at the moment - I don’t want to hand you a package that doesn’t match and send you in circles. I’ve got your product info and the photos now. Let me check whether there’s a libcamera_dev build that matches stretch/your kernel for this hardware, and I’ll get back to you in this thread. If you can grab the full raw output of the script (the detected-OS lines included) that would help confirm it.
