Hi everyone, I’m stuck trying to get a 16MP autofocus Arducam camera working on a Jetson Xavier NX and the install script just bails out on me. When I run the setup it prints this:
Kernel version: 5.10.65-tegra-34.1.1-20220516211757
Jetson type: UNKNOWN
The board is a Seeed Studio Jetson SUB Mini PC with the Xavier NX module (aluminum case with cooling fan, 128GB SSD, pre-installed Jetpack) and I’ve already applied the latest updates. Any idea what’s missing here? The “Jetson type: UNKNOWN” part doesn’t look right to me.
Thanks for the details. That message comes straight from the driver installer — it tries to match your board/kernel to a prebuilt .deb and couldn’t find one, so it prints the info you see plus that support address. The key clue is “Jetson type: UNKNOWN”: the installer reads the board model to pick the right package, and when it can’t recognize the board it reports UNKNOWN and stops there.
Two quick questions so I can point you the right way:
Which 16MP camera is it exactly? There are two that look almost identical — the 16MP IMX298 and the 16MP IMX519 — and they use different driver packages.
Are you on NVIDIA’s official carrier board or a third-party one?
It’s the 16MP IMX519 camera. And no, I’m not on the official board — it’s the Seeed Studio Jetson SUB Mini PC, so a third-party carrier board with the Xavier NX module in it. Kernel is still 5.10.65-tegra-34.1.1-20220516211757.
That explains it. This error shows up when the installer is running on a board or carrier board that isn’t supported. Because the Seeed Studio carrier board isn’t in the list of recognized boards, the installer can’t match your setup to a .deb — which is exactly why you get “Jetson type: UNKNOWN” and no package.
So two things to be aware of:
The camera drivers/overlays are built against NVIDIA’s reference board configs, so a third-party carrier board like the Seeed one isn’t covered and the deb install won’t complete.
The recommended path is to run the camera on the official NVIDIA I/O board (the Xavier NX developer kit baseboard), where the deb matches and the install finishes normally.
Can you confirm once more that it’s the IMX519 and not the IMX298? Once we’re sure we can advise on the driver side.
Confirmed, it’s the 16MP IMX519. So basically I can’t use it with this Seeed carrier board at all? Every attempt gives me the same thing:
I was hoping to keep the smaller enclosure, but it sounds like the board itself is the blocker.
Right — the failure is the carrier board, not the camera itself. Since the installer can’t identify the board it never even gets to installing the IMX519 support, so you’ll keep hitting that same message no matter how many times you re-run it. The practical workaround is to run the camera on the official NVIDIA I/O board (Xavier NX developer kit baseboard) with the standard JetPack image — there the deb matches and the install completes.
Staying on the Seeed board would require a driver package/overlay built for that specific board, which the current installer doesn’t support. So for now: use the official I/O board, and if you run into anything else once you’re on it, post the new installer output and we’ll take a look.
