Can you post a bit more detail about your setup? The kernel version and the exact Jetson model would help, plus the exact command you ran so we can see what’s happening.
The exact command was:
nvidia@linux:~$ sudo ./install_imx477.sh
And the full error output:
Cannot find the corresponding deb package, please send the following information to support
Kernel version: 4.9.253-tegra-32.7.1-20220219090432
Jetson type: Nano (Developer Kit Version)
You have run the wrong command. For the IMX477 on a Jetson, the correct installer is ./install_full.sh -m imx477, not ./install_imx477.sh. That’s why it couldn’t find a matching deb package.
Thanks, I followed that and used ./install_full.sh -m imx477 instead. But now it’s stuck on a different step: the Jetson can reach Google fine, but it can’t connect to GitHub, so the script can’t pull down what it needs. I’ve attached a screenshot of what I’m seeing.
That looks like an intermittent GitHub connectivity issue from your network, not a problem with the camera or the driver. Please retry the command again. Sometimes I can not connect to GitHub but it will work about 10 mins later.
Sounds good. Just to recap what we’ve found so far: the original ‘Cannot find the corresponding deb package’ error came from running the wrong installer (./install_imx477.sh instead of ./install_full.sh -m imx477). The GitHub connection failure is a separate, intermittent network issue on your side - not a driver or camera fault. Retrying after about 10 minutes usually gets past it. We can’t fix GitHub reachability from here directly, but if it keeps failing after a few retries, let us know and we’ll go from there.
