Hi, I’m trying to set up the CamArray 12MP Synchronized Stereo Camera Bundle Kit on my Jetson and I’m stuck at the driver install step. I followed the multiple-cameras-on-the-Jetson doc here:
Hey, thanks for the detailed report. That message usually means the installer couldn’t match a driver package to your specific Jetson/L4T combo, so it bails out instead of installing.
Can you send me a few things so I can pin down exactly which package it’s looking for?
uname -r
cat /etc/nv_tegra_release
Which exact Jetson board you’re on (Dev Kit or module + carrier)
With those I can tell you whether the matching deb even exists yet.
Also just to add, the installer seems to look through a folder of debs and pick one based on the version, but nothing matches. I can paste the directory listing if that helps.
Yep, please paste the listing of the driver package folder — ls -l on whatever directory the install script ships with. That’ll confirm which releases it covers.
In the meantime: that kernel string (5.10.65-tegra-34.1.0-...) maps to L4T 34.1, which is JetPack 5.0. That’s a pretty important detail here.
dpkg: dependency problems prevent configuration of arducam-camarray:
arducam-camarray depends on nvidia-l4t-kernel (= 4.6.2-...); however:
Version of nvidia-l4t-kernel on system is 5.0-...
And even if I force it with --force-depends it starts trying to build the kernel module against the headers and fails, so no /dev/video* devices show up and dmesg has nothing about the camarray driver. So it’s definitely not just the script being picky.
Right, that confirms it. Two separate blockers there: the package pins to the L4T 4.6.x kernel, and even forced, the module won’t build against the 5.10.65-tegra headers you have.
Short version of the root cause: the driver install package for JetPack 5.0 hasn’t been released yet. The bundle only ships builds for JetPack 4.6, 4.6.1 and 4.6.2. Since JetPack 5.0 is still a preview release and has a number of unresolved issues on our side, we don’t recommend using it for this camera setup yet.
Ah, ok. Is there any way to build it from source in the meantime, or is there a beta deb I could try on 5.0? I’d rather not reflash unless I have to. Happy to test something experimental if it exists.
There isn’t a source drop or a 5.0 deb available for this HAT right now, so there’s nothing to hand over on the 5.0 side yet. I did send you a note privately with the version info I’d need if anything does get published, so check your messages.
Best path at the moment is to flash to a supported release. Use JetPack 4.6, 4.6.1 or 4.6.2 — those are the versions the CamArray/Camarray HAT driver packages are built for, and the install will pick the matching deb automatically once the L4T version lines up.
So to wrap up:
Don’t use JetPack 5.0 for this setup — the driver package isn’t released for it and it’s a preview build.
Reflash to JetPack 4.6, 4.6.1 or 4.6.2, then re-run the install script from the docs page.
The Cannot find the corresponding deb package, please send the following information to [email protected] error is expected on JetPack 5.0 and will go away once you’re on one of the 4.6.x releases.
If you reflash and still hit the same message, post your uname -r and the directory listing again and we’ll take another look.
