Hi, I’m trying to get a Arducam 64MP camera working on my Raspberry Pi and I can’t get the kernel driver to install. The install script runs for a while and then bails out saying it can’t find a corresponding package. I’m on Bullseye. What am I doing wrong?
Sorry you’re hitting that. That message usually means the installer couldn’t find a prebuilt kernel module matching your running kernel. Can you share a few things so I can check it against the supported list?
- Hardware revision (from
/proc/cpuinfo, the ‘Revision’ line) - Exact kernel version (
uname -r) - The package name you’re trying to install
- The full output/error from the install script
Sure, here’s what I’ve got:
- Hardware Revision: a01041
- Kernel Version: 5.15.45-v7+
- Package: 64mp_pi_hawk_eye_kernel_driver – bullseye
And this is the full output when the install fails:
Cannot find the corresponding package, please send the following information to support
Package: 64mp_pi_hawk_eye_kernel_driver -- bullseye
You are using an unsupported kernel version, please install the official SD Card image(do not execute rpi-update):
https://www.raspberrypi.com/software/operating-systems/
The script gets all the way through and then dies right at the kernel driver step.
Thanks, that’s exactly what I needed.
So the installer is basically saying it has no prebuilt module for the kernel you’re running. The 64mp_pi_hawk_eye_kernel_driver package only ships builds for the kernels that come with the official Raspberry Pi OS images. Your kernel is 5.15.45-v7+, and there’s no matching package for that combination on Bullseye — hence the “Cannot find the corresponding package” line followed by “You are using an unsupported kernel version.”
Quick question so I can be sure: did you install this OS from the official Raspberry Pi Imager, or did you update the kernel at some point (e.g. rpi-update)? That -v7+ kernel is not what a stock Bullseye image ships with.
Yeah, I ran rpi-update a while back to get a newer kernel for something else. I didn’t realize that would break the camera driver. Is there any way to make the current setup work, or do I have to start over? Also, just so I understand — is the failure happening because of the kernel version itself, or because of the driver package?
That explains it. The failure is the driver package, but the cause is the kernel. The installer looks for a module built against your exact kernel version, finds nothing, and stops. There’s no package for 5.15.45-v7+ on Bullseye, so nothing to install.
The fix is to put the official Raspberry Pi OS image back on the card — that’s the OS/kernel the driver is actually built for. Two important things:
- Use the official image, not a kernel you’ve bumped yourself. You can grab the recommended one here: Index of /raspios_full_armhf/images/raspios_full_armhf-2022-04-07 (the general download page is https://www.raspberrypi.com/software/operating-systems/).
- Do not run
rpi-updateafterward. That’s what pulled you onto an unsupported kernel in the first place, and it will break the driver again.
After flashing, boot it, confirm uname -r shows a supported kernel, then run the driver install script again — it should find the matching package this time.
Got it. For a01041, is there a specific image I should pick, or does the recommended one cover it? And do I need to redo the whole camera setup from scratch after flashing, or will the driver install just pick up where it left off?
The recommended official image covers that board fine — just flash it fresh rather than trying to patch the current install, since the kernel is what needs to change. You’ll need to redo the camera setup after that: flash the card, boot, then run the 64mp_pi_hawk_eye_kernel_driver install script again on the fresh kernel. Then verify the driver loaded before touching the camera config.
Quick recap for anyone reading this thread:
- Symptom:
64mp_pi_hawk_eye_kernel_driver -- bullseyeinstall fails with “Cannot find the corresponding package” / “You are using an unsupported kernel version.” - Environment: Hardware Revision a01041, Kernel 5.15.45-v7+.
- Cause: the driver package has no build for that kernel.
5.15.45-v7+came fromrpi-update, and the Arducam 64MP kernel driver only supports the kernels shipped with the official Raspberry Pi OS images. - Fix / workaround: flash the official Raspberry Pi OS image (Index of /raspios_full_armhf/images/raspios_full_armhf-2022-04-07), boot it, and do not run
rpi-update. Then reinstall the kernel driver.
If it still can’t find the package after a fresh official image, post uname -r and the full installer output and we’ll take another look.
