Hi @akshar2324
Thank you for your inquiry regarding the exposure capabilities of the IMX519 USB 3.0 Auto Focus camera.
You are correct that the current firmware limits the exposure_time_absolute to a maximum value corresponding to approximately 200ms. This limit is imposed by the USB bridge firmware to ensure standard video frame rates and stability for general webcam usage.
To answer your specific questions:
Is this limit bypassable via controls/SDK?
No, standard UVC controls or vendor extensions cannot override this hard limit on the stock firmware, as the timing generators inside the bridge chip are configured for this specific range.
How to achieve 500ms – 1s exposure?
Enabling long exposure on this USB module requires Custom Firmware . We need to modify the internal firmware to allow the frame rate to drop significantly to accommodate the longer integration times you require for low-light imaging.
Since this is a specific requirement not covered by the mass-production firmware, please contact our sales team at [email protected] to request a quote for this firmware customization service . Please mention your specific target exposure time (e.g., up to 1 second) so our engineering team can evaluate the feasibility.
