I bought the camera module from Robu.in in India - Model number of the product(s)?
Arducam High Quality IR-CUT Camera for NVIDIA Jetson Nano/NX and NVIDIA
Orin NX/AGX Orin, 12.3MP 1/2.3 Inch IMX477 HQ Camera Module with 6mm CS
Lens SKU: B0274 - What hardware/platform were you working on?
Nvidia Jetson Nano Developer Kit - Instructions you have followed. (link/manual/etc.)
I used the following link to install the driver.
Releases · ArduCAM/MIPI_Camera · GitHub
chmod +x install_imx477.sh
sudo ./install_imx477.sh
The above commands are used to install the driver. - Problems you were having?
I was able to successfully detect the attached camera device using ls **
** /dev/video0. Not able to confirm the video streaming in the device. - The dmesg log from your hardware?
I have attached the logs from the terminal when I run the
following command gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! “video/x- **
** raw(memory:NVMM),width=1440,height=1080,framerate=$FRAMERATE/1” ! **
** nvvidconv ! nvoverlaysink
itiningtreeğitiminitro-skrapist cat /etc/v/rele catt /etc/nw/releases No ach file or directasy
Itinindiregitiminitree-desktop?- cat /etc/dy tours releas
832 (release). REVISION: 5.9 OCTD: 1521747 BOARD: 1210xet, EABI: arches, DATE: Fri Jan 15 22:55:35 UTC 2021 itimindtreeğitiminitree-desktop:- is /auv/videol
1st cannot access /dev/video’s No such file or directory
ThimindtreeBitinindtree-desktop:- is /dev/video
itimindtreeğitimindtree-desktop:- FRAMERATE-30
overlaysine-ravinemory:),width-440,height-1000, framarate-2FRAMERATE/1"
Setting pipeline to TASED
Pipeline is live and does not need FREROLL… Setting pipeline to PLAYING…
New clock: staystemclock
T ARGUE: Creating output stream
CONSOMER: Waiting until producer is connected… GST ANGUS: Available densor modes:
GET ANGUR: 4032 x 3040 - 25.999999 tps Duration - 33333334 Analog Gain range min 1.000000, max 22.250000; Exposure Range min 13000, max 6837090002
GOT ARGURE 1920 x 1080 FR-59.999999 fps Duration
16666667; Analog Gain range min 1.000000, max 22,250000; Exposure Range min 13000, max 4837090002
003: 2592 x 1944 R 29.999999 tps Duration 33333334 Analog Gain range min 1.000000, max 22.250000; Exposure Range nin 13000, max 6837090002 GST ARGUS: 2560 x 1440 FR-40.000000 fps Duration 25000000 Analog Gain range min 1.000000, max 22.250000; Exposure Range min 13000, max 483709000
GOT AROUS: Running with following settings:
Camera index = 0 Canera mode <-2
Output Stream X- 2592 - 1944
seconds to Run
0
Frane Rate - 29,999999 GOT ANGUS: Setup Complete, starting captures for 0 seconds
GET ARGUS: Starting repeat capture requests, COMMER: Producer has connecteds continuing,
but utils: dabut fd -1 mapped entry NOT found
but utils: can not get buffer from FD… Exiting… ERROR: from element /GstPipeline:pipeline0/GstvArguscamerasro rquscamerasrco: CANCELLED
Additional debug info: Angus Error Status
Execution ended after 0:00:04.538172905 setting pipeline to PAUSED
setting pipeline to READY
gst-launch-1.0:8421): GStreamer-CRITICAL gst mini_object_set_gdata: assertion object = NULL failed
Note: The logs were converted to text from image.
Not able to confirm from the terminal logs about the video streaming.
8. What help do you need
Can you please send the suitable links explaining all the commands with respect to this camera and also can you guys help us with the python integration of these commands?
