Hey everyone, I’m pretty stuck here. I’ve got a Raspberry Pi 5 and a 5MP OV5647 camera module, but the camera just isn’t showing up anywhere in the Raspberry Pi configuration. I’ve been digging through forum posts and saw a few people mention that recent updates might have borked camera support on the Pi 5 — could that be what’s going on here?
I’ve tried the obvious stuff — reseated the ribbon cable a couple times, rebooted, ran rpi-update, the whole lot. Still nothing. The camera doesn’t appear in libcamera-hello --list-cameras either, just says no cameras available.
Anyone else run into this on a Pi 5? Is there some new camera stack I’m supposed to be using now?
Thanks for reaching out. Before we point fingers at software updates, let’s rule out the basics first. On the Pi 5, camera issues usually come down to one of two things — either a physical connection problem or a software/configuration mismatch. We need to check both.
Let’s start with the hardware side. Could you post a couple of clear, well-lit photos showing:
Where the ribbon cable connects to the camera board itself.
Where the ribbon cable connects to the Raspberry Pi 5 (the CSI/DSI connector).
I want to check the orientation and seating — the Pi 5’s cable connectors are a bit different from older models and it’s easy to get the cable flipped or not fully inserted. The metal contacts on the ribbon should be facing the right direction depending on which connector you’re using.
Once we’ve got those, we’ll move on to the software diagnostics.
While you’re getting those photos together, let’s also grab a full diagnostic snapshot of your system. I’ve got a tool that’ll pull everything we need in one go. Run these commands in a terminal on your Pi 5:
Once it finishes, it’ll generate a file called arducam-bug-report.txt. That file will contain all the relevant system info — OS version, kernel details, what the camera subsystem is seeing (or not seeing), dmesg output related to the camera, i2c device listings, and your current config.txt setup. Basically everything I’d need to figure out whether this is a driver issue, a device tree problem, or something else.
Attach that .txt file along with the two photos and we’ll dig in from there.
