Yesterday I was using my camera like normal and smoke suddenly started coming out of it, along with a strong burnt smell. After that it just stopped working completely. I’ve attached a few photos of the damage. Not really sure what happened or where to start.
That definitely sounds like a hardware failure, not a software/config problem. Can you confirm the exact model? From the photos it looks like the Arducam B0167B12 IMX477 12MP PTZ Camera for Raspberry Pi 4/3B+/3 and Jetson Nano/Xavier NX, but I want to make sure before we go further.
Yes, that’s the one - the B0167B12 IMX477 12MP PTZ camera. I’ve used it for a while without issues until this happened. The smoke and burnt smell came out of nowhere while it was running.
Thanks for confirming. Based on the photos and your description, I’m afraid the kit is defective. Smoke and a burnt smell are typical signs of a hardware failure. The important thing now is to figure out which part actually failed. There are two pieces involved: the camera module itself and the PTZ control board. Can you test them separately and see if either one still responds? If the control board is fine, you can still make PTZ control work with Arducam’s script. But we need to confirm whether the camera module, the control board, or both are defective.
I checked the hardware and I honestly can’t tell exactly where the problem is. The control board and the camera both don’t seem to be working. Neither responds. Is there anything else I can try to narrow it down?
Given the burnt smell and the fact that both the camera module and the control board are not responding, this points to a hardware failure in the kit. If the control board had still been working, you could have driven the PTZ using Arducam’s script even with a bad camera module, but since both pieces are dead there isn’t a software-side fix for this. Conclusion: the camera module and the control board both appear to be defective.
