Here is some more stuff I could not fit into my first post
[ 0.000000] Linux version 6.1.70-v7+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1714 SMP Thu Jan 4 14:48:23 GMT 2024
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Rev 1.2
[ 0.000000] Reserved memory: created CMA memory pool at 0x1e000000, size 256 MiB
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000003b3fffff]
[ 0.000000] Normal empty
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000003b3fffff]
[ 0.000000] percpu: Embedded 17 pages/cpu s37012 r8192 d24428 u69632
[ 0.000000] pcpu-alloc: s37012 r8192 d24428 u69632 alloc=17*4096
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 240555
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 overlayroot=tmpfs console=ttyS0,115200 console=tty1 root=PARTUUID=7fb63720-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=US
[ 0.000000] Unknown kernel command line parameters "splash overlayroot=tmpfs", will be passed to user space.
[ 0.000000] Memory: 665272K/970752K available (10240K kernel code, 1454K rwdata, 3140K rodata, 1024K init, 612K bss, 43336K reserved, 262144K cma-reserved)
[ 0.000000] ftrace: allocating 34930 entries in 103 pages
[ 0.000000] ftrace: allocated 103 pages with 5 groups
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000001] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000018] Switching to timer-based delay loop, resolution 52ns
[ 0.000376] Console: colour dummy device 80x30
[ 0.000449] printk: console [tty1] enabled
[ 0.000498] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000519] CPU: Testing write buffer coherency: ok
[ 0.000567] pid_max: default: 32768 minimum: 301
[ 0.000697] LSM: Security Framework initializing
[ 0.000885] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.000907] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.001941] cgroup: Disabling memory control group subsystem
[ 0.002452] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.003234] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.003245] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.003347] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.003357] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.003475] Setting up static identity map for 0x100000 - 0x10003c
[ 0.003599] rcu: Hierarchical SRCU implementation.
[ 0.003608] rcu: Max phase no-delay instances is 1000.
[ 0.004253] smp: Bringing up secondary CPUs ...
[ 0.005087] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.005955] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.006746] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.006839] smp: Brought up 1 node, 4 CPUs
[ 0.006861] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.006874] CPU: All CPU(s) started in HYP mode.
[ 0.006880] CPU: Virtualization extensions available.
[ 0.007562] devtmpfs: initialized
[ 0.023096] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.023289] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.023315] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.033272] pinctrl core: initialized pinctrl subsystem
[ 0.034370] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.037378] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.042199] audit: initializing netlink subsys (disabled)
[ 0.042415] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
[ 0.042995] thermal_sys: Registered thermal governor 'step_wise'
[ 0.044131] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.044148] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.044400] Serial: AMBA PL011 UART driver
[ 0.051208] platform 3f101000.cprman: Fixed dependency cycle(s) with /soc/dsi@7e700000
[ 0.051645] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.053828] platform 3f700000.dsi: Fixed dependency cycle(s) with /soc/dsi@7e700000/bridge@0/ports/port@0/endpoint
[ 0.070060] raspberrypi-firmware soc:firmware: Attached to firmware from 2023-10-17T15:42:39, variant start
[ 0.080073] raspberrypi-firmware soc:firmware: Firmware hash is 30f0c5e4d076da3ab4f341d88e7d505760b93ad7
[ 0.121536] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[ 0.126957] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.128535] SCSI subsystem initialized
[ 0.128762] usbcore: registered new interface driver usbfs
[ 0.128816] usbcore: registered new interface driver hub
[ 0.128864] usbcore: registered new device driver usb
[ 0.129069] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.129449] pps_core: LinuxPPS API ver. 1 registered
[ 0.129458] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[ 0.129483] PTP clock support registered
[ 0.131692] clocksource: Switched to clocksource arch_sys_counter
[ 0.132197] VFS: Disk quotas dquot_6.6.0
[ 0.132267] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.132403] FS-Cache: Loaded
[ 0.132647] CacheFiles: Loaded
[ 0.146799] NET: Registered PF_INET protocol family
[ 0.147097] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.149606] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.149642] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.149814] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.149931] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.150261] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.150389] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.150445] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.150676] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.151158] RPC: Registered named UNIX socket transport module.
[ 0.151169] RPC: Registered udp transport module.
[ 0.151176] RPC: Registered tcp transport module.
[ 0.151184] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.151548] Trying to unpack rootfs image as initramfs...
[ 0.162845] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 2.009892] Freeing initrd memory: 15640K
[ 2.226621] Initialise system trusted keyrings
[ 2.227017] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 2.235816] zbud: loaded
[ 2.238128] NFS: Registering the id_resolver key type
[ 2.238171] Key type id_resolver registered
[ 2.238180] Key type id_legacy registered
[ 2.238299] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 2.238311] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 2.239592] Key type asymmetric registered
[ 2.239605] Asymmetric key parser 'x509' registered
[ 2.239770] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 2.239782] io scheduler mq-deadline registered
[ 2.239792] io scheduler kyber registered
[ 2.245253] simple-framebuffer 3ea81000.framebuffer: framebuffer at 0x3ea81000, 0x177000 bytes
[ 2.245282] simple-framebuffer 3ea81000.framebuffer: format=a8r8g8b8, mode=800x480x32, linelength=3200
[ 2.245728] Console: switching to colour frame buffer device 100x30
[ 2.250434] simple-framebuffer 3ea81000.framebuffer: fb0: simplefb registered!
[ 2.253399] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[ 2.255127] bcm2835-rng 3f104000.rng: hwrng registered
[ 2.255500] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 2.266561] brd: module loaded
[ 2.273414] loop: module loaded
[ 2.274031] Loading iSCSI transport class v2.0-870.
[ 2.275369] usbcore: registered new interface driver lan78xx
[ 2.275432] usbcore: registered new interface driver smsc95xx
[ 2.275449] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 3.003468] Core Release: 2.80a
[ 3.003484] Setting default values for core params
[ 3.003508] Finished setting default values for core params
[ 3.203745] Using Buffer DMA mode
[ 3.203754] Periodic Transfer Interrupt Enhancement - disabled
[ 3.203762] Multiprocessor Interrupt Enhancement - disabled
[ 3.203770] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.203783] Dedicated Tx FIFOs mode
[ 3.204305] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = 9e104000 dma = 0xde104000 len=9024
[ 3.204340] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 3.204354] dwc_otg: Microframe scheduler enabled
[ 3.204462] WARN::hcd_init_fiq:457: FIQ on core 1
[ 3.204481] WARN::hcd_init_fiq:458: FIQ ASM at 807c5eb8 length 36
[ 3.204502] WARN::hcd_init_fiq:497: MPHI regs_base at bb810000
[ 3.204524] dwc_otg 3f980000.usb: DWC OTG Controller
[ 3.204558] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 3.204595] dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
[ 3.204646] Init: Port Power? op_state=1
[ 3.204654] Init: Power Port (0)
[ 3.204847] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 3.204866] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.204880] usb usb1: Product: DWC OTG Controller
[ 3.204892] usb usb1: Manufacturer: Linux 6.1.70-v7+ dwc_otg_hcd
[ 3.204903] usb usb1: SerialNumber: 3f980000.usb
[ 3.205470] hub 1-0:1.0: USB hub found
[ 3.205514] hub 1-0:1.0: 1 port detected
[ 3.206089] dwc_otg: FIQ enabled
[ 3.206098] dwc_otg: NAK holdoff enabled
[ 3.206105] dwc_otg: FIQ split-transaction FSM enabled
[ 3.206118] Module dwc_common_port init
[ 3.206389] usbcore: registered new interface driver usb-storage
[ 3.206570] mousedev: PS/2 mouse device common for all mice
[ 3.208850] sdhci: Secure Digital Host Controller Interface driver
[ 3.208861] sdhci: Copyright(c) Pierre Ossman
[ 3.209117] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.210868] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.211181] hid: raw HID events driver (C) Jiri Kosina
[ 3.211306] usbcore: registered new interface driver usbhid
[ 3.211316] usbhid: USB HID core driver
[ 3.215026] Initializing XFRM netlink socket
[ 3.215075] NET: Registered PF_PACKET protocol family
[ 3.215169] Key type dns_resolver registered
[ 3.216168] Registering SWP/SWPB emulation handler
[ 3.216807] registered taskstats version 1
[ 3.216857] Loading compiled-in X.509 certificates
[ 3.217607] Key type .fscrypt registered
[ 3.217619] Key type fscrypt-provisioning registered
[ 3.228438] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 3.228572] 3f201000.serial: ttyAMA1 at MMIO 0x3f201000 (irq = 114, base_baud = 0) is a PL011 rev2
[ 3.228768] serial serial0: tty port ttyAMA1 registered
[ 3.229884] bcm2835-aux-uart 3f215040.serial: there is not valid maps for state default
[ 3.230271] printk: console [ttyS0] disabled
[ 3.230356] 3f215040.serial: ttyS0 at MMIO 0x3f215040 (irq = 86, base_baud = 50000000) is a 16550
[ 3.230748] printk: console [ttyS0] enabled
[ 3.231780] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 3.232040] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 3.233217] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 3.233235] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
[ 3.260080] sdhost: log_buf @ fae526ad (de107000)
[ 3.308523] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 3.310677] of_cfs_init
[ 3.310834] of_cfs_init: OK
[ 3.316525] Freeing unused kernel image (initmem) memory: 1024K
[ 3.331798] Indeed it is in host mode hprt0 = 00021501
[ 3.370528] mmc0: host does not support reading read-only switch, assuming write-enable
[ 3.374599] mmc0: new high speed SDXC card at address aaaa
[ 3.375482] mmcblk0: mmc0:aaaa SD512 477 GiB
[ 3.378847] mmcblk0: p1 p2
[ 3.379427] mmcblk0: mmc0:aaaa SD512 477 GiB (quirks 0x00004000)
[ 3.399167] mmc1: new high speed SDIO card at address 0001
[ 3.412225] Run /init as init process
[ 3.412237] with arguments:
[ 3.412245] /init
[ 3.412253] splash
[ 3.412261] with environment:
[ 3.412268] HOME=/
[ 3.412276] TERM=linux
[ 3.412284] overlayroot=tmpfs
[ 3.541780] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 3.541938] Indeed it is in host mode hprt0 = 00001101
[ 3.792129] usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcdDevice= 2.00
[ 3.792167] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.792932] hub 1-1:1.0: USB hub found
[ 3.793030] hub 1-1:1.0: 5 ports detected
[ 4.111793] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 4.242053] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
[ 4.242090] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.244990] smsc95xx v2.0.0
[ 4.373656] SMSC LAN8700 usb-001:003:01: attached PHY driver (mii_bus:phy_addr=usb-001:003:01, irq=199)
[ 4.375347] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:5e:9a:b2
[ 6.369807] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
[ 7.199657] systemd[1]: System time before build time, advancing clock.
[ 7.440031] NET: Registered PF_INET6 protocol family
[ 7.441518] Segment Routing with IPv6
[ 7.441565] In-situ OAM (IOAM) with IPv6
[ 7.547905] systemd[1]: systemd 252.17-1~deb12u1+rpi1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[ 7.547960] systemd[1]: Detected architecture arm.
[ 7.556605] systemd[1]: Hostname set to <raspbpi>.
[ 9.003280] systemd[1]: Queued start job for default target graphical.target.
[ 9.056382] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[ 9.059188] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[ 9.061804] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
[ 9.064408] systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck.
[ 9.065555] systemd[1]: Created slice user.slice - User and Session Slice.
[ 9.066186] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[ 9.067624] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
[ 9.068423] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
[ 9.069071] systemd[1]: Reached target nss-user-lookup.target - User and Group Name Lookups.
[ 9.069649] systemd[1]: Reached target slices.target - Slice Units.
[ 9.070063] systemd[1]: Reached target swap.target - Swaps.
[ 9.070469] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
[ 9.075172] systemd[1]: Listening on syslog.socket - Syslog Socket.
[ 9.076059] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
[ 9.076539] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[ 9.078319] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
[ 9.079246] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[ 9.080241] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
[ 9.084264] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[ 9.085284] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[ 9.086662] systemd[1]: dev-hugepages.mount - Huge Pages File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/mm/hugepages).
[ 9.091407] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
[ 9.097691] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
[ 9.103949] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
[ 9.105609] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
[ 9.115904] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
[ 9.127413] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
[ 9.135135] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
[ 9.143528] systemd[1]: Starting [email protected] - Load Kernel Module configfs...
[ 9.152078] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
[ 9.160641] systemd[1]: Starting [email protected] - Load Kernel Module drm...
[ 9.171555] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
[ 9.182280] systemd[1]: Starting [email protected] - Load Kernel Module fuse...
[ 9.197078] systemd[1]: Starting [email protected] - Load Kernel Module loop...
[ 9.200563] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
[ 9.229963] systemd[1]: Starting systemd-journald.service - Journal Service...
[ 9.254158] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
[ 9.266816] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
[ 9.292645] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[ 9.306854] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
[ 9.313606] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
[ 9.316019] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
[ 9.319383] systemd[1]: Finished fake-hwclock.service - Restore / save the current clock.
[ 9.326699] device-mapper: ioctl: 4.47.0-ioctl (2022-07-28) initialised: [email protected]
[ 9.331127] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
[ 9.336913] systemd[1]: [email protected]: Deactivated successfully.
[ 9.338010] systemd[1]: Finished [email protected] - Load Kernel Module configfs.
[ 9.340872] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[ 9.341855] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
[ 9.344380] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[ 9.345774] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
[ 9.348258] systemd[1]: [email protected]: Deactivated successfully.
[ 9.349214] systemd[1]: Finished [email protected] - Load Kernel Module loop.
[ 9.350714] fuse: init (API version 7.37)
[ 9.355619] systemd[1]: [email protected]: Deactivated successfully.
[ 9.356798] systemd[1]: Finished [email protected] - Load Kernel Module fuse.
[ 9.410186] i2c_dev: i2c /dev entries driver
[ 9.432436] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
[ 9.438264] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
[ 9.444308] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
[ 9.450672] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
[ 9.450767] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
[ 9.505290] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
[ 9.507385] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
[ 9.509110] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
[ 9.511352] systemd[1]: systemd-firstboot.service - First Boot Wizard was skipped because of an unmet condition check (ConditionFirstBoot=yes).
[ 9.511985] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
[ 9.532569] systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed...
[ 9.539367] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
[ 9.569119] systemd[1]: Starting systemd-sysusers.service - Create System Users...
[ 9.604765] systemd[1]: [email protected]: Deactivated successfully.
[ 9.605611] systemd[1]: Finished [email protected] - Load Kernel Module drm.
[ 9.641455] systemd[1]: Started systemd-journald.service - Journal Service.
[ 9.762452] systemd-journald[243]: Received client request to flush runtime journal.
[ 9.774627] systemd-journald[243]: File /var/log/journal/66371c5654184c2a84178607b83a240e/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 11.291272] Driver for 1-wire Dallas network protocol.
[ 11.335025] rpi-gpiomem 3f200000.gpiomem: window base 0x3f200000 size 0x00001000
[ 11.335867] rpi-gpiomem 3f200000.gpiomem: initialised 1 regions as /dev/gpiomem
[ 11.340519] gpio-4 (onewire@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[ 11.355258] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 11.361965] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 11.366405] mc: Linux media interface: v0.10
[ 11.366943] [vc_sm_connected_init]: start
[ 11.367764] [vc_sm_connected_init]: installed successfully
[ 11.689136] videodev: Linux video capture interface: v2.00
[ 11.775305] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 11.789876] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 11.841870] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 11.842437] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 11.842842] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 11.844389] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 11.844434] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 11.844458] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 11.844481] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 11.844500] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 11.848642] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 11.871989] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[ 11.872431] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[ 11.872757] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 11.873004] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 11.873034] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 11.873057] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 11.873074] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 11.873092] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 11.873253] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 11.884983] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 11.947492] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 12.132211] i2c i2c-11: Added multiplexed i2c bus 0
[ 12.133472] i2c 10-0036: Fixed dependency cycle(s) with /soc/csi@7e801000/port/endpoint
[ 12.133760] i2c i2c-11: Added multiplexed i2c bus 10
[ 12.180524] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 12.284044] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 12.284228] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 12.313658] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 12.313722] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 12.368799] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 12.368866] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 12.383141] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 12.383200] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 12.389287] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[ 12.389343] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[ 12.417280] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 12.426773] Bluetooth: Core ver 2.22
[ 12.426900] NET: Registered PF_BLUETOOTH protocol family
[ 12.426912] Bluetooth: HCI device and connection manager initialized
[ 12.426940] Bluetooth: HCI socket layer initialized
[ 12.426957] Bluetooth: L2CAP socket layer initialized
[ 12.426985] Bluetooth: SCO socket layer initialized
[ 12.568374] Bluetooth: HCI UART driver ver 2.3
[ 12.568477] Bluetooth: HCI UART protocol H4 registered
[ 12.568909] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 12.569936] Bluetooth: HCI UART protocol Broadcom registered
[ 12.574079] hci_uart_bcm serial0-0: supply vbat not found, using dummy regulator
[ 12.574842] hci_uart_bcm serial0-0: supply vddio not found, using dummy regulator
[ 12.625839] cfg80211: Loaded X.509 cert '[email protected]: 577e021cb980e0e820821ba7b54b4961b8b4fadf'
[ 12.628437] cfg80211: Loaded X.509 cert '[email protected]: 3abbc6ec146e09d1b6016ab9d6cf71dd233f0328'
[ 12.630964] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[ 12.692016] uart-pl011 3f201000.serial: no DMA platform data
[ 12.724187] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 12.944285] Bluetooth: hci0: BCM: chip id 94
[ 12.944837] Bluetooth: hci0: BCM: features 0x2e
[ 12.948039] Bluetooth: hci0: BCM43430A1
[ 12.948070] Bluetooth: hci0: BCM43430A1 (001.002.009) build 0000
[ 12.953421] Bluetooth: hci0: BCM43430A1 'brcm/BCM43430A1.raspberrypi,3-model-b.hcd' Patch
[ 13.261072] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
[ 13.295707] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[ 13.296362] usbcore: registered new interface driver brcmfmac
[ 13.432664] mipi-dsi 3f700000.dsi.0: Fixed dependency cycle(s) with /soc/dsi@7e700000/port/endpoint
[ 13.432725] mipi-dsi 3f700000.dsi.0: Fixed dependency cycle(s) with /panel_disp@1/port/endpoint
[ 13.539858] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Jul 19 2021 03:24:18 version 7.45.98 (TOB) (56df937 CY) FWID 01-8e14b897
[ 13.837325] Bluetooth: hci0: BCM: features 0x2e
[ 13.841389] Bluetooth: hci0: BCM43438A1 37.4MHz Raspberry Pi 3-0141
[ 13.841424] Bluetooth: hci0: BCM43430A1 (001.002.009) build 0508
[ 14.336656] w1_master_driver w1_bus_master1: w1_search: max_slave_count 64 reached, will continue next search.
[ 14.606674] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 16.705475] ov5647: probe of 10-0036 failed with error -5
[ 16.891525] Console: switching to colour dummy device 80x30
[ 16.897941] vc4-drm soc:gpu: bound 3f400000.hvs (ops vc4_hvs_ops [vc4])
[ 16.930756] Registered IR keymap rc-cec
[ 16.930962] rc rc0: vc4-hdmi as /devices/platform/soc/3f902000.hdmi/rc/rc0
[ 16.931134] input: vc4-hdmi as /devices/platform/soc/3f902000.hdmi/rc/rc0/input0
[ 16.936324] vc4-drm soc:gpu: bound 3f902000.hdmi (ops vc4_hdmi_ops [vc4])
[ 16.943832] vc4-drm soc:gpu: bound 3f700000.dsi (ops vc4_dsi_ops [vc4])
[ 16.944162] vc4-drm soc:gpu: bound 3f004000.txp (ops vc4_txp_ops [vc4])
[ 16.944401] vc4-drm soc:gpu: bound 3f206000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 16.944609] vc4-drm soc:gpu: bound 3f207000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 16.944826] vc4-drm soc:gpu: bound 3f807000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 16.945017] vc4-drm soc:gpu: bound 3fc00000.v3d (ops vc4_v3d_ops [vc4])
[ 16.970283] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 0
[ 16.974458] Console: switching to colour frame buffer device 100x30
[ 16.974499] vc4-drm soc:gpu: [drm] fb0: vc4drmfb frame buffer device
[ 17.052354] edt_ft5x06 10-0038: supply iovcc not found, using dummy regulator
[ 17.517215] input: 10-0038 generic ft5x06 (79) as /devices/platform/soc/3f205000.i2c/i2c-11/i2c-10/10-0038/input/input1
