Other Arducam Distributor (Tokopedia)
OV5647
Raspberry Pi 4B
4.Which instruction are you following? https://www.arducam.com/docs/cameras-for-raspberry-pi/synchronized-stereo-camera-hat/sync-stereo-camera-hat-user-manual/
never tried
I’m confused about the cable of OV5647, the arducam sockets for camera are too small for the cable, so do i need to buy cable like this and change the cable of OV5647 ? I mean, is this cable is suitable for the arducam board ? need fast reply ASAP thank you.
I mean the camera module you bought and what you want it to work with.
If you bought a separate ov5647 then you need to do some soldering according to the tutorial, and yes you need to buy the corresponding cable.
This method of hardware modification is not recommended because it is easy to encounter problems.
If you want to use the ov5647 stereo camera then it is recommended to buy a kit.
Can I know what you want to achieve with the stereo camera? The Green problem of IMX219 may not affect the use of some scenes.
