Hey everyone, I’m having trouble getting my Arducam setup working and could use some guidance. I picked up the B0491 (IMX219 8MP camera) and the B0489 V3Link kit with the 4-ch deserializer RX board and camera interface board. I’ve tried using these with two different SBCs — a BeagleY-AI and a Raspberry Pi 5 — and neither one works out of the box. I’ve never gotten this product to work properly since I got it.
Before I dive deeper into troubleshooting, does anyone have the schematics for the V3Link system (both the serializer and deserializer ends) and the IMX219 camera board? I’d like to understand the hardware better while debugging.
Thanks for reaching out. The schematics for the V3Link system are included in the Arducam V3Link datasheet, which you can find here:
That should cover both ends of the link as well as the camera board details.
Regarding the compatibility issues — can you share what OS images you’re running on the BeagleY-AI and the Raspberry Pi 5 respectively? Also, what are the specific symptoms? Is it not detecting the camera at all, or is it throwing errors when you try to capture? That’ll help narrow things down.
Quick update — I’ve made some progress on the BeagleY-AI side. I grabbed the most recent Beagle image based on version 11.00.00.08, freshly loaded from the BeagleBoard.org site, and now the V3Link adapter works with both of my IMX219 8MP cameras. The demo applications are functional and I’m getting video.
Just to confirm: any other image I tried would not work at all. So it seems like older or incompatible OS builds were the culprit there.
I’m moving on to try this with a TDA4VM SK board next, but before that I had a few questions:
Will a 12MP camera work on this 4-ch deserializer adapter board? Which model should I be looking at?
The V3Link camera (8MP) has a ribbon connecting it to the serializer — can I disconnect that ribbon and run the camera directly over standard CSI-2, say on a Raspberry Pi?
What about lens compatibility for V3Link cameras? Specifically models B0153, B0154, B0152, B0103 — do these work?
Can the B0180 be used to replace just the camera module, or is it a lens-only thing? My main goal here is to get a suitable lens for the 8MP V2.3 camera.
Great to hear the BeagleY-AI is up and running. That confirms the root cause — the older or incompatible OS images on the BeagleY-AI were the problem. The kernel and device tree support needed for the V3Link just isn’t there in those earlier builds. For anyone else hitting this: make sure you flash the most recent Beagle image based on version 11.00.00.08 from the BeagleBoard.org site.
Now to your questions:
12MP camera on the 4-ch deserializer: Yes, it’s supported. The model you want is the IMX477. It’s compatible with the V3Link kit.
Bypassing V3Link for direct CSI-2: Yes, absolutely. You can disconnect the ribbon that goes from the camera to the V3Link serializer board, and then connect the camera directly to the Raspberry Pi’s CSI-2 interface. It’ll work without issues — the sensor itself is a standard IMX219.
Lens compatibility: Any camera with an IMX219 or IMX477 sensor will work with the V3Link kit, so that includes B0153, B0154, B0152, and B0103. You’re covered on those.
B0180 and lens replacement: The B0180 is a replacement lens. If you’re looking for a wider field of view on your V3Link cameras (including the 8MP V2.3), the B0180 is the recommended option. You’d swap the original lens out and install the B0180 in its place.
Hope that clears things up — good luck with the TDA4VM!
