B163 IMX135 camera module CSI-2 4-lane support on Raspberry Pi?
Hi everyone, I’ve got a B163 (IMX135 MIPI 13MP color camera module) and I’m a bit confused about the CSI-2 lane support. The product page still says “CSI-2 serial data output (MIPI 2Lane/4Lane selectable)” but I can’t get 4-lane mode working at all. Is that spec actually correct, or is 4-lane just not possible on all Raspberry Pi models?
Can you give me a bit more detail on your setup? Which Raspberry Pi model are you using, and what have you tried so far to switch it into 4-lane mode? That’ll help narrow down whether this is a hardware limit or a configuration issue.
Sure. The module is the B163 (IMX135 MIPI 13MP color camera) over CSI-2. The spec I’m looking at says MIPI 2Lane/4Lane selectable. I’ve attached a screenshot of the product info for reference. Nothing I’ve tried so far gets 4 lanes working.
Thanks, that helped. I checked the product page and the feature section does still list “CSI-2 serial data output (MIPI 2Lane/4Lane selectable)”. Looking at the actual CSI lane support, the issue is that Raspberry Pi 0 through 4 only expose a 2-lane CSI interface. 4-lane CSI is only available on the Raspberry Pi 5. So on Pi 0-4, the module can’t run in 4-lane mode no matter what you configure.
Thanks for the explanation. So to confirm my understanding: on Raspberry Pi 0-4 there’s only a 2-lane CSI interface, and the Pi 5 is the one that supports a 4-lane CSI interface. Does that mean 4-lane is currently not possible on any Pi, since compatibility for the Pi 5 still needs to be done?
That’s correct. Raspberry Pi 0-4 are limited to a 2-lane CSI interface, so 4-lane mode isn’t usable on those boards. The Raspberry Pi 5 does have a 4-lane CSI interface, but compatibility for 4-lane mode on the Pi 5 still needs to be added in the future. So at the moment, 4-lane isn’t supported across the board - 2-lane is what you can rely on.
