Hey everyone, I’m having trouble getting the Arducam B0498 (USB3 UVC Camera Kit) working on my Raspberry Pi 5. I’m running the latest Bookworm 64-bit OS.
I was under the impression this camera was supposed to be plug-and-play on Linux, but I’m getting some weird behavior. When I try to capture a movie or still image, a pop-up window appears for maybe 1/10th of a second showing an all-green rectangle, then disappears. This green pop-up happens every single time I try to capture anything.
I’ve attached a couple screenshots of what I’m seeing.
Has anyone else run into this on a Pi 5 with Bookworm?
Thanks for the response. Here’s what I’ve found so far:
The camera IS detected on the Pi 5. It shows up at /dev/video0 and qvl2 identifies it correctly — it sees the B0498 without any issues there.
I’ve also tested the camera on my Windows 10 Asus laptop, and it works perfectly fine there. So the hardware itself seems okay, the problem is specific to the Pi 5 running Bookworm.
On the Pi, any capture attempt — whether it’s a still image or video — triggers that split-second green rectangle pop-up before it just dies. I’ve tried a few different capture utilities and the behavior is consistent across all of them.
That’s useful — the fact that qvl2 sees it and it works on Windows rules out a lot of things.
Since the camera is detected but capture fails, this could be a driver or UVC pipeline issue on Bookworm. Have you looked into the MIPI-CSI driver installation for this camera? I know the B0498 is a UVC device, but some of these Arducam kits rely on or interact with their MIPI driver stack under the hood, especially on Pi hardware. It might be worth attempting that driver installation to see if it resolves the capture pipeline issue.
Alright, so I went down that path and here’s where things got messy.
I attempted to install the MIPI-CSI driver from the Arducam repo. The Makefile fails during compilation on Bookworm. The issue seems to be around how Bookworm handles get/try — they changed something in the kernel headers or toolchain and the existing Makefile just doesn’t cope with it.
I spent some time modifying the Makefile and wrote some custom code to work around the get/try changes. After a fair bit of tinkering, I got it to compile cleanly — no errors, no warnings. Installed the newly compiled driver on the Pi and rebooted.
But here’s the thing: the B0498 still fails with the exact same green pop-up behavior. No change whatsoever.
I’m starting to wonder if that driver work was a red herring. My MIPI-CSI driver changes might only be relevant for the MIPI imx585 camera boards, not the B0498 USB3 UVC kit. Even though it compiled successfully, maybe the code path for the USB3 UVC device is still broken, or it was never the right driver to begin with for this particular camera. I’m kind of stuck now.
That’s good troubleshooting, and I think your hypothesis about the MIPI driver not being relevant to the B0498 USB3 UVC path makes sense — the B0498 should indeed be operating purely over the UVC stack, so the MIPI-CSI driver compilation was likely unrelated to your issue.
Before we dig deeper into custom fixes, can I ask — have you had a chance to go through the official Quick Start Guide for Linux on this camera? It covers the expected setup steps and dependencies, and it’s possible there’s something in there that was missed during the initial configuration on Bookworm.
Give that a read-through and follow the steps as written, then let me know if you hit any snags or if the behavior changes at all. That’ll give us a clean baseline to work from.
