B0498 IMX585 USB 3.0 UVC camera not recognized after firmware update attempt
Hi everyone, I’m having trouble with my Arducam B0498 (IMX585 USB 3.0 UVC camera). I’m using it on both Debian Linux and Windows 10, both x64 machines.
The camera is detected and I can get video through v4l2 and OBS, but the image settings are basically stuck — I can’t adjust exposure, gain, or anything meaningful through the UVC controls. Low-light performance is also terrible, way worse than what this sensor should be capable of.
I found this thread that seems related: Need B0498_firmware_update.7z for IMX585 USB 3.0 UVC camera
Has anyone else run into this? Is a firmware update the right path here?
That does sound like a firmware issue — the symptoms you’re describing (UVC controls not working properly, poor low-light performance) line up with an older firmware version that had known bugs with the IMX585’s exposure pipeline and control interface.
The thread you linked is indeed relevant. There’s a firmware updater tool for Windows that addresses these exact problems. Have you tried running that update yet? If not, I’d recommend giving it a shot on your Windows machine first. Just make sure you follow the video instructions carefully — interrupting the flash process can cause issues.
If you’ve already attempted it, let me know what happened and we can go from there.
So I went ahead and ran the firmware updater on Windows following the video guide. It seemed to complete without any obvious error messages.
But now when I plug the camera into my Linux box, something is wrong. The camera is still detected — it shows up under lsusb and as a /dev/video device — but v4l2 and OBS both show a black screen, no image at all. I’ve tried:
  • Different USB ports (both 2.0 and 3.0)
  • Checking dmesg (no errors, device enumerates fine)
  • v4l2-ctl --list-formats (still lists formats, but no actual frame data)
  • guvcview — same thing, device opens but no image
It’s like the camera is alive on the USB bus but the sensor isn’t producing any frames. Did the firmware flash partially fail?
That’s odd — the device enumerating but producing no frames suggests the firmware image may not have written cleanly, even if the updater didn’t show an error. The USB bridge firmware and the sensor-side firmware are separate pieces; it’s possible the bridge side is working (hence USB enumeration) but the sensor initialization is failing.
A few things to try:
  1. On Windows, does the camera show up in Device Manager? If so, does the standard Camera app or OBS on Windows produce an image?
  2. Can you run v4l2-ctl --all on Linux and paste the output? I’m curious what controls are being exposed.
  3. Have you tried re-running the firmware updater on Windows a second time? Sometimes a re-flash resolves an incomplete write.
If the updater behaves differently on a second attempt, that would tell us a lot.
This just got worse. I tried running the firmware updater again on Windows and it froze at 3% progress, then the whole tool crashed after about 30 seconds of being stuck. No error dialog, just disappeared.
Now the camera isn’t recognized at all — not on Windows, not on Linux. On Linux, lsusb doesn’t show it anymore. On Windows, Device Manager doesn’t even flicker when I plug it in. Tried different cables, different ports, same result on two completely different PCs.
The LED on the camera board still lights up when plugged in, so it’s getting power, but the USB interface seems completely dead.
I’m a developer and I’ve done direct FPGA flashing before — if there’s a way to recover this via a low-level flash (SPI, JTAG, whatever interface this thing uses), I’m comfortable doing it. I just need the firmware binary and any documentation on the recovery procedure. Otherwise I think this thing is bricked.
What you’re describing — the updater freezing at 3% and crashing — strongly points to the firmware being corrupted mid-write. That would explain why the device no longer enumerates: the USB bridge firmware itself is now incomplete or damaged, so the USB PHY can’t even start up properly. The LED lighting up just means the board is receiving VBUS power, nothing more.
Unfortunately there isn’t a publicly documented low-level recovery method for end users on this particular module — the flash interface isn’t exposed in a way that’s accessible without specialized hardware.
However, we can recover this. I’ve sent you a private message with details for a remote support session where we can reset the camera and apply the latest firmware correctly using our internal tools. Please check your messages and we’ll get this sorted out.
Thanks, I got your message with the remote session details and the scheduling link. I’ve booked a slot — had to reschedule from the earlier one since it was too short notice on my end, but I’m confirmed for later today.
Just to confirm: during the session, you’ll be able to re-flash the firmware even though the device isn’t enumerating over USB at all right now? Curious what the recovery path looks like technically, but I’ll save the questions for the session. Appreciate the help.
Yes, we can recover from this state — the tooling we use internally can address the device at a lower level than what the standard USB enumeration path requires, so the bricked state you’re seeing is recoverable.
To summarize where we are: the root cause was an incomplete firmware write during the flashing process. The first update likely wrote enough to break sensor initialization (hence no frames but still enumerating), and the second attempt corrupted the bootloader or bridge firmware entirely when it crashed at 3%.
During the session we’ll reset the camera to a clean state and apply the latest firmware properly. I’ll walk you through the whole process. Looking forward to getting your B0498 back up and running — see you at the scheduled time.
