Hi, I’m having a weird issue with the B0498 USB camera. On cold boot, the camera is detected as a USB 2.0 device and only gives 720p. If I unplug and replug the USB cable, it’s recognized properly as USB 3.0 and I get 4K. This happens on multiple Windows 11 computers with different USB 3.0 ports and cables. I’ve tried everything I can think of. Anyone else seen this?
Thanks for reaching out. That’s definitely unusual since USB-C is supposed to be symmetrical. Let’s start with some basics - what cables and ports have you tried? Also, have you tested on more than one PC?
Yeah, I’ve tested on 3 different computers running Windows 11 Pro. I’m using the USB-C (camera side) to USB-A cable that came with it, and I’ve also tried multiple other USB 3.2 and USB 3.0 cables. Always the same behavior - the port itself has the blue insert with the SS symbol so I know it’s USB 3.0. As soon as I unplug and replug (same port, same cable), it jumps to USB 3.0 and 4K works fine.
Got it. Let’s try a few things:
- Try different USB 3.0 ports on the same machine
- Try booting with the cable connected vs connecting after boot
- Run this script in PowerShell as admin to force a USB rescan without physically unplugging:
pnputil /enum-devices /connected | find “USB”
pnputil /restart-device
Let me know what happens.
Tried different USB ports - same result. I also tried that pnputil approach to remove and rescan the device without physically touching the cable - it always comes back as USB 2.0 unless I actually disconnect and reconnect the cable.
I also tried changing the connection order (disconnecting USB-C from camera first, plugging USB-A into PC, then connecting USB-C to camera) - still fails on boot.
One thing I noticed though - if I flip the USB-C connector at the camera side, the issue seems to go away. It stays in USB 3.0 mode even after reboot. That seems really strange since USB-C should be reversible, right?
That’s a very interesting finding. You’re right, USB-C should be fully symmetrical, but after some analysis, I think I can explain what’s happening.
The camera module uses an onboard multiplexer (Mux) that handles signal routing based on the CC1/CC2 pin handshaking with your PC’s USB controller. The USB 3.0 SuperSpeed data pairs are primarily routed on one side of the board due to hardware layout constraints in the compact M12 mount form factor.
When the camera first powers on during boot, it attempts to establish a SuperSpeed (USB 3.0) link. If the initial handshake across those data lanes fails - which can happen due to tiny timing variations in power-up between different PC hub controllers - the hardware falls back to USB 2.0 pins on the opposite side to ensure the device is at least detected.
This is essentially a negotiation timeout issue. The PC’s controller likely misses the SuperSpeed window in that one orientation during the initial power surge, causing the camera to lock into USB 2.0 mode until the connection is physically reset.
That makes a lot of sense actually. So the orientation of the USB-C plug matters because of timing during boot. Is there a permanent fix for this? I need this camera in a setup that gets power cycled daily and I can’t keep flipping the connector every morning. Do you have a firmware update that could fix the handshaking timing?
That’s a completely understandable concern. Here’s the resolution:
Immediate Fix: Flip the USB-C connector on the camera side to the orientation that works. You’ve already confirmed this resolves the issue.
For Permanent Installations:
- Connect the camera in the orientation that successfully negotiates USB 3.0
- Verify the link speed in Device Manager (look for “SuperSpeed” under USB properties)
- Once verified, secure the cable so it can’t be accidentally rotated or bumped
The root cause is a timing-sensitive handshake between the onboard Mux and the host PC’s USB controller during initial power-up. Since you’ve identified that flipping the connector resolves it, the camera should stay locked into USB 3.0 mode as long as the cable remains in that orientation.
Regarding firmware - this is primarily a hardware board layout limitation. Making a fully symmetrical board for high-bandwidth data paths within the compact M12 mount form factor is a significant design challenge. I don’t have a firmware update that would change this behavior, but once you lock in the correct orientation, the connection remains stable regardless of subsequent reboots. The issue only occurs during the initial power-up handshake.
So in short: flip the connector once, verify USB 3.0 is active, and then leave it be. You shouldn’t have any further issues.
