Hello Arducam team,
We use three B0478 cameras in an imaging system. We need to obtain an accurate timestamp corresponding to the actual sensor exposure of each frame from each camera, and we would like to know whether exposure can be synchronized across all three cameras.
Our setup:
- Three B0478 / Sony IMX586 USB 3.0 cameras, USB VID:PID
04b4:0478. - Linux x86_64,
uvcvideo, OpenCV with the V4L2 backend. - Continuous streaming at 4000 × 3000, YUYV, 5 fps, with manual camera controls.
Our application currently selects frames from the continuous stream; it does not issue a sensor hardware trigger.
We record the application request time, the host monotonic timestamp immediately after grab(), and CAP_PROP_POS_MSEC. However, we do not assume that these timestamps represent the actual sensor exposure. During our inspection, uvcvideo reported clock=CLOCK_MONOTONIC and hwtimestamps=0.
Could you clarify the following specifically for the B0478 and our board revision?
- Accurate exposure timestamps
Does the current firmware provide a timestamp tied to the sensor exposure for each frame? We need the actual capture timestamp, rather than the time when the application requests, receives or retrieves the image.
Please specify the event represented by this timestamp—for example, first-row exposure start, exposure midpoint/end, sensor readout start or USB transmission—and its accuracy, resolution, systematic offset and jitter.
For rolling-shutter operation at 4000 × 3000, please identify the reference row/event and provide the timing information needed to determine when other rows are exposed.
How can we retrieve these timestamps under Linux? Are they available through UVC PTS/SCR, the V4L2 metadata node (UVCH), an Extension Unit or an Arducam API? Is uvcvideo hwtimestamps=1 supported and meaningful with this firmware?
We also need to associate each timestamp reliably with its corresponding frame and compare timestamps across all three cameras using a common time reference. Please provide a supported method and, ideally, a Linux example.
- Synchronization of the three cameras
Can three B0478 cameras synchronize their sensor exposures, rather than merely deliver frames to the host at similar times?
Does this board revision support an external trigger or synchronization interface, such as FSIN, XVS or VSYNC? If so, please provide the pinout or test points, electrical requirements, configuration procedure and achievable exposure skew and jitter between three cameras.
Please clarify whether synchronization requires a firmware update or hardware modifications, and whether it is supported at our current resolution and frame rate.
Our supplied update package includes:
SKU_B0478_UC_A48_RevC_UVC3.0_2025-12-02_24.img
B0478_AF_2025.07.23_A_vsyn_int.bin
What does vsyn_int mean in this package, and does it relate to exposure timestamps or camera synchronization? We do not assume that it enables an external trigger.
We also found your hardware timestamp documentation for the USB Camera Shield Plus. Please confirm whether that functionality applies to the B0478 UVC product.
Thank you.
