Quick start from product listing.
I’m having identical issues to /t/imx462-camera-is-not-recognized/6920. Followed the quick start guide. New Pi 4, bought several B0444s. Firmware is 0x10002. Same thing about showing up as a imx290 when I try to force it. Installed fresh image today with Pi Imager.
Installed 64bit and 32bit bookworm. Turned i2c on/off, saw device on i2c as imx290. Enabled/disabled uart. enabled/disabled autodetect camera.
The same camera works on an Pi zero 2W with bookworm without issues that I setup a month or two ago. I tried multiple cables. I’ve flashed microsd card with 32bit and 64bit variants.
There is video0 with ls/dev/video0, but when I do libcamera-still --list-cameras, there are no cameras available. I’ve played with disabling uart, camera auto detect, enabling i2c with many variations. I’ve seen that the arducam libcamera has been updated in the last month or so, I tried updating but same issue.
After spending 6+ hours on it, I just flashed the Pi 4 to bullseye and the Pi 4 worked similar to the Pi Zero 2W
[0:02:41.988646759] [1878] INFO Camera camera_manager.cpp:325 libcamera v0.3.2+27-7330f29b
[0:02:42.017852640] [1881] WARN CameraSensorProperties camera_sensor_properties.cpp:305 No static properties available for 'arducam-pivariety'
[0:02:42.017918843] [1881] WARN CameraSensorProperties camera_sensor_properties.cpp:307 Please consider updating the camera sensor properties database
[0:02:42.038597889] [1881] ERROR IPAProxy ipa_proxy.cpp:154 Configuration file 'arducam-pivariety.json' not found for IPA module 'rpi/vc4'
[0:02:42.043326375] [1881] ERROR IPARPI ipa_base.cpp:127 Could not create camera helper for arducam-pivariety
[0:02:42.043374763] [1881] ERROR RPI pipeline_base.cpp:820 Failed to load a suitable IPA library
[0:02:42.043406855] [1881] ERROR RPI vc4.cpp:216 Failed to register camera arducam-pivariety 10-000c: -22
I’m having issues posting the error in the main post. This was the output from the Pi 4 w/ bookworm.
