B0444 (2MP IMX462) Manual Focus issue
I just installed B0444 2MP IMX462 camera on Raspberry Pi 3B+ with the following OS version:
pi@raspberrypi:~ $ uname -a
Linux raspberrypi 6.1.21-v7+ #1642 SMP Mon Apr 3 17:20:52 BST 2023 armv7l GNU/Linux
pi@raspberrypi:~ $ cat /etc/os-release
NAME=“Raspbian GNU/Linux”
VERSION_ID=“11”
VERSION=“11 (bullseye)”
VERSION_CODENAME=bullseye
The camera is working fine except the focus feature is not working in PiCamera2. I use the code example from Pivariety-Camera-PiCamera2-User-Guide:
import time
picam2 = Picamera2()
picam2.start_preview(Preview.QTGL)
preview_config = picam2.create_preview_configuration()
picam2.start()
time.sleep(1)
picam2.set_controls({"AfTrigger": 0})
time.sleep(5)
Then, I got the following error. Please advise how to use the manual focus for this camera?
pi@raspberrypi:~ $ python cam.py
[0:50:20.409193751] [1495]  INFO Camera camera_manager.cpp:297 libcamera v0.0.0+4367-ad9428b4
[0:50:20.442828729] [1499]  WARN CameraSensorProperties camera_sensor_properties.cpp:261 No static properties available for 'arducam-pivariety'
[0:50:20.443036385] [1499]  WARN CameraSensorProperties camera_sensor_properties.cpp:263 Please consider updating the camera sensor properties database
[0:50:20.463772485] [1499] ERROR IPAProxy ipa_proxy.cpp:149 Configuration file 'arducam-pivariety.json' not found for IPA module 'rpi/vc4'
[0:50:20.789838431] [1499]  INFO RPI vc4.cpp:444 Registered camera /base/soc/i2c0mux/i2c@1/arducam_pivariety@c to Unicam device /dev/media2 and ISP device /dev/media1
[0:50:20.790089993] [1499]  INFO RPI pipeline_base.cpp:1101 Using configuration file '/usr/share/libcamera/pipeline/rpi/vc4/rpi_apps.yaml'
[0:50:23.704852240] [1495]  INFO Camera camera.cpp:1033 configuring streams: (0) 640x480-XBGR8888 (1) 1920x1080-SRGGB10_CSI2P
[0:50:23.834641379] [1499]  INFO RPI vc4.cpp:572 Sensor: /base/soc/i2c0mux/i2c@1/arducam_pivariety@c - Selected sensor format: 1920x1080-SRGGB10_1X10 - Selected unicam format: 1920x1080-pRAA
  File "/home/pi/cam.py", line 13, in <module>
  File "/usr/lib/python3/dist-packages/picamera2/picamera2.py", line 1093, in set_controls
    self.controls.set_controls(controls)
  File "/usr/lib/python3/dist-packages/picamera2/controls.py", line 58, in set_controls
    self.__setattr__(k, v)
  File "/usr/lib/python3/dist-packages/picamera2/controls.py", line 33, in __setattr__
    raise RuntimeError(f"Control {name} is not advertised by libcamera")
RuntimeError: Control AfTrigger is not advertised by libcamera
Thanks.
Hi @terri ,
I am wondering the same… Did you figure it out?
Hi @kay_xm @terri
This camera module doesn’t support the autofocus functionality. If you want to adjust the focus manually, you need to melt the glue around the lens with a heat gun or a hair dryer.
After that, you should be able to twist the lens to get the expected focus distance.
