Amazon -
camera board: B0395; lens: B0180 -
raspberry pi 4bullseye with latest updates as of 10:00pm pst -
libcamera -
one of my v2.2 boards works and the other does not. I then tried the board that worked again just to make sure I didn’t do something to break the lens and it did work. Then I tried the other board one last time and still the same error. Libcamera tells me to try a new lens or a new ribbon cable. But that same lens and ribbon cable work on a different v2.2 board. -
The dmesg log from your hardware?-config.txt
# http://rpf.io/configtxt
#hdmi_safe=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
camera_auto_detect=0
display_auto_detect=0
# Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
disable_overscan=1
[cm4]
otg_mode=1
[pi4]
arm_boost=1
dtoverlay=imx219
gpu_mem=128
Use same lens, same ribbon cable, same raspberry pi & same os/updates bullseye latest on two camera boards. one of my v2.2 boards works and the other does not. -
Why the other same camera board can’t work? And how to fix it.
