B0292: 120-degree lens edge clarity and cutting 38x38 board tabs?
Hey everyone, I’m evaluating the Arducam B0292 module for a project and running into some optical concerns. Right now I’m at a 40mm focal distance and capturing a roughly 17x4mm rectangular area. I’m considering switching to the 120-degree FOV option but I’m worried the outer regions of the image won’t be as sharp as what I’m getting now. Has anyone used both options and can comment on edge clarity?
Also, I noticed the 38x38 board has these cutouts with eight little tabs holding the outer perimeter to the main board area. I’d like to know if I can snip those tabs and remove the outer section entirely without killing the camera. Are those cutouts there for vibration isolation or something structural, or are they just for PCB panelization?
Good questions. A few things would help narrow this down — what’s the end goal with the wider FOV? Are you trying to capture a larger area at the same 40mm working distance, or are you trying to reduce the working distance while maintaining the same 17x4mm field of view? The tradeoffs are pretty different depending on which direction you’re going.
The goal is to capture a larger area at roughly the same working distance. I’m imaging a flat surface and need to cover more real estate in a single frame. The 17x4mm rectangle is limiting — ideally I’d want something closer to 25x6mm or even wider. The 120-degree option seemed like the obvious path but I’ve been burned before with wide-angle modules where the corners get soft or distorted.
So here’s the thing with the B0292 — it’s a fixed-lens module. The lens is not user-replaceable or swappable, so you can’t just pop on a different lens to change the FOV. If you’re looking at a “120-degree option” that implies a different lens assembly, that would require a different camera module entirely, not a modification to the B0292.
Ah, that’s good to know and honestly a bit of a disappointment. I had assumed the B0292 had interchangeable lens options since I saw different FOV variants listed. So if lens swapping is off the table, what are my actual options for getting a wider effective FOV out of this module? I’m stuck at the 40mm distance due to the mechanical constraints of the enclosure.
With the fixed lens, your main levers are physical positioning and software cropping — but they work in opposite directions. Since you need a wider FOV at the same working distance, repositioning won’t help here (moving the camera further away would widen the field but also change your working distance, which you said is constrained). The more practical approach might be looking at a different module in the Arducam lineup that natively offers a wider FOV at your target working distance. Have you looked at something like the B0392 or the OV5642-based modules? Those have different lens options and might get you closer to the 25x6mm field at 40mm.
I haven’t looked at the B0392 yet, I’ll check that out. But going back to my second question — can I cut the outer edge off this 38x38 board? My enclosure is tight and shaving off that outer perimeter would save me a few millimeters on each side. Just want to make sure I’m not cutting through something critical or removing a feature that’s meant to dampen vibration.
On the board cutout question — yes, you can cut away the outer perimeter including those eight tab-connected sections without affecting camera functionality. Those outer regions are mechanically non-essential as far as the electrical operation goes. They’re not there for vibration isolation or anything like that — it’s more of a PCB panelization / mounting convenience thing. Just be careful not to damage any traces when you’re trimming, and obviously don’t cut into the inner board area where the components and routing are. If the full 38x38 footprint isn’t needed for your enclosure, you’re safe to remove the outer edge.
That’s exactly what I needed to know — thanks. I’ll proceed with trimming the board down and I’ll dig into the B0392 datasheet to see if the FOV math works out better. Appreciate the help.
No problem. One last thought — if you want to stay with the B0292 and try to make it work, you could also experiment with digital cropping in a different way: capture at the native resolution and then remap or dewarp the image if barrel distortion at the edges is your main concern. It won’t give you a truly wider physical FOV, but it can clean up the outer regions if you do end up testing a wider module and find the edge quality lacking. But honestly, switching to a module with the right native FOV is the cleaner path here. Good luck with the build.
