B0249 IMX477 MIPI camera not working on Jetson Orin, need driver source code
Hi, we bought the Arducam B0249 (IMX477) and can’t get it working on our Jetson Orin carrier board. We need the B0249 driver source code. On GitHub I can only find Xavier NX / Jetson Nano driver source for the IMX477:
The camera is the B0249 MIPI 4-lane version with the 22-pin, 0.5 mm pitch connector for a Jetson Orin carrier board.
Can you give me more detail so I can point you to the right driver? Which platform are you using — Jetson Orin Nano/NX or Jetson Nano/NX? What exactly is failing: the driver won’t install, or the camera won’t output an image? And which JetPack version are you on?
We’re on JetPack 6.0 with Jetson Orin NX / Orin Nano, L4T is Jetson Linux 36.3. The Arducam website and GitHub only show Xavier NX and Jetson Nano source code, so we need the B0249 (IMX477) source that supports JetPack 6.0 + Orin NX/Nano.
I’ve sent you the driver source patch through private message — Orin_NX_JetPack6.0_L4T-36.3.0_IMX477.patch. Please check your messages and review it for JetPack 6.0 + Jetson Orin NX / Orin Nano, L4T 36.3.
Thanks. Our software engineer checked the source you sent, but it’s MIPI 2 lanes. The Jetson Orin NX/Nano MIPI is 4 lanes. We need the 4-lane driver source.
Our driver for this camera is 2-lane, not 4-lane.
Before we bought these we asked on the official site whether the B0249 supports MIPI 4 lanes, and the reply was yes, so we ordered. But the actual driver is 2-lane. The official product page for the B0249 models also says it supports MIPI 4 lanes:
https://www.arducam.com/product/b0242-arducam-imx477-hq-camera/
Is the website spec wrong, or are you just not providing the 4-lane driver source?
Sorry for the earlier wording — let me clarify. The product page says the camera has a 4-lane interface, but the platform still needs to support a 4-lane driver, and the Jetson Orin series does support that. The Jetson Native imx477 driver is already a 4-lane driver. The source is available from NVIDIA:
Here’s the full test setup so you can see what we’re seeing. Two Arducam B024 modules on an Orin Nano dev kit (P3768 carrier board) with an Orin NX 16G module (P3767), JetPack 6.0.2, L4T 36.3, kernel 5.15. I followed the Arducam quick start guide:
https://docs.arducam.com/Nvidia-Jetson-Camera/Native-Camera/Quick-Start-Guide/#12mp-imx477-camera
After installing the driver, CAM0 and CAM1 preview both open normally. But when we measure the CSI ports, both J20 and J21 only show two data lanes (x2) with signal. I ran sudo /opt/nvidia/jetson-io/jetson-io.py, set it to ‘Camera IMX477 Dual 4 lane’, saved, and rebooted. Then I opened CAM1 (J21) preview and measured again — still only two data lanes have signal.
We’re stuck on the MIPI 4-lane validation. The question we need answered: how do we enable and use x4 lanes on CAM1 (J21) on the NVIDIA dev board?
To be clear, the camera itself supports 4 lanes. If you’re using the NVIDIA native imx477 dual 4-lane driver and still only see 2-lane output on the CSI ports, then I’d recommend checking with NVIDIA official support. That points to the platform/driver configuration on the Orin dev board rather than the B024 camera hardware.
