B0202 (IMX291 160°) – Power Line Frequency 60 Hz has no effect, banding under LED lighting – firmware request
    Amazon / Arducam store
    B0202 – 1080P Low Light WDR, IMX291, 160° fisheye, USB 2.0
    lsusb: 0x0c45 Microdia / 0x0261 Arducam 1080P Low Light / bcdDevice 1.00 / 1 Arducam 1080P Low Light / 3 UC684
    Beelink S12 (Intel N95), Linux Mint 22.3 (Ubuntu 24.04 base), kernel 6.14.0-37-generic, uvcvideo driver. Capture via motion, YUYV 1920x1080 @ 5 fps. Also tested on a Lenovo ThinkPad X1 running Linux Mint.
  4. Instructions you have followed.
    Arducam Wiki – Troubleshooting, “How to Fix Flicker or Banding in Video Streams” (set Power Line Frequency to match local mains).
  5. What help do you need?
    The camera shows faint horizontal bands rolling slowly down the image under indoor LED shop lighting (US, 60 Hz mains). Following the wiki:
  • power_line_frequency was 1 (50 Hz) by default; set to 2 (60 Hz) and confirmed with v4l2-ctl -C. No change to the banding, including after restarting the stream.
  • Manual exposure (auto_exposure=1): exposure_time_absolute = 83, 84, 85 all show banding. 167 is band-free.
  • At 167 the image is heavily overexposed. gain is already at its minimum (0); backlight_compensation set to 0; brightness/gamma reduced, but highlights remain clipped.
Questions:
a) Is there a newer firmware for the B0202 where the 60 Hz anti-flicker setting works in auto-exposure mode?
b) Can you confirm the unit of exposure_time_absolute on this model (100 µs?) and whether exposure is quantized to line time?
c) Is there any firmware option to lower sensitivity further (lower minimum analog gain), so a flicker-safe 16.7 ms exposure isn’t overexposed in a lit room?
d) If a firmware update is available, please share the burning tool, procedure, and a recovery path in case the flash fails. I’ve read the B0200 thread where a serial-number change erased the firmware and want to avoid that.
User Controls
                     brightness 0x00980900 (int)    : min=-64 max=64 step=1 default=0 value=0
                       contrast 0x00980901 (int)    : min=0 max=64 step=1 default=32 value=32
                     saturation 0x00980902 (int)    : min=0 max=128 step=1 default=64 value=64
                            hue 0x00980903 (int)    : min=-40 max=40 step=1 default=0 value=0
        white_balance_automatic 0x0098090c (bool)   : default=1 value=1
                          gamma 0x00980910 (int)    : min=72 max=500 step=1 default=100 value=100
                           gain 0x00980913 (int)    : min=0 max=100 step=1 default=0 value=0
           power_line_frequency 0x00980918 (menu)   : min=0 max=2 default=1 value=1 (50 Hz)
      white_balance_temperature 0x0098091a (int)    : min=2800 max=6500 step=1 default=4600 value=4600 flags=inactive
                      sharpness 0x0098091b (int)    : min=0 max=6 step=1 default=2 value=2
         backlight_compensation 0x0098091c (int)    : min=0 max=2 step=1 default=1 value=1
Camera Controls
                  auto_exposure 0x009a0901 (menu)   : min=0 max=3 default=3 value=3 (Aperture Priority Mode)
         exposure_time_absolute 0x009a0902 (int)    : min=1 max=5000 step=1 default=156 value=156 flags=inactive
     exposure_dynamic_framerate 0x009a0903 (bool)   : default=0 value=0
Thank you!
