I performed several additional tests on my setup.
Hardware:
- Camera: Arducam B01678MP 8MP PTZ Camera
- Board: Jetson Orin Nano Super Developer Kit
- JetPack: 6.2.1
- L4T: 36.4.7
Current status
- The camera video works correctly.
- The IMX219 sensor is detected and streaming normally.
- The PTZ controller LED turns on after connecting 5V, GND, SDA and SCL.
- If I manually extend the focus lens and then power on the PTZ controller, the focus motor automatically retracts the lens once and stops. This indicates that the focus motor and controller are powered and performing an initialization.
I2C investigation
I checked all available I2C buses.
The IMX219 camera sensor is detected as:
9-0010 → imx219
The device at address 0x10 belongs to the IMX219 sensor, not the PTZ controller.
I also verified that:
/sys/bus/i2c/devices/9-0010/driver → imx219
There is no device at address 0x0C, which is the address used by the PTZ Focuser.py example.
Running:
python3 FocuserExample.py -i 9
opens the camera successfully, but none of the controls work:
- Focus: not working
Electrical measurements
I also checked the GPIO I2C lines.
Without the PTZ controller connected:
- SDA = 3.3 V
- SCL = 3.3 V
After connecting the PTZ controller:
- SDA = 3.3 V
- SCL drops to approximately 1.3 V
If I disconnect only the SCL wire from the PTZ controller, the Jetson SCL line immediately returns to 3.3 V.
This indicates that the PTZ controller (or something on that board) is pulling the SCL line low.
I also verified:
- GPIO wiring continuity is correct.
- The jumper wires are good.
- The focus motor itself is functional because it performs the initialization movement during power-up.
Questions
Is the B01678MP PTZ controller expected to appear as a separate I2C device (for example at address 0x0C) on JetPack 6.2.1 / L4T 36.4.7?
Is there an updated PTZ controller driver or Focuser.py implementation for JetPack 6?
Is the SCL line dropping to ~1.3 V expected during initialization, or does this indicate a faulty PTZ controller board?
Any guidance would be appreciated.
