Roboshop
B0102
Jetson Xavier NX
Is it possible to use B0102 with Jetson Xavier NX kit? Where do I find the instructions and drivers?
What is the difference between B0102 and B0193?
Regards.
Using IMX219 on Jetson Nano does not need to install the driver. If you have already installed the Arducam driver, you can use the “sudo dpkg -r arducam-nvidia-l4t-kernel” command to uninstall it.
If you want to use B0267 and B0102 at the same time, you will need to modify the device tree. Please tell me your L4T version and use the “cat /etc/nv_tegra_release” command to get it.
Tips: The usage of B0267 and B0102 are somewhat different. B0102 is an officially supported camera, so you can use the onboard ISP. Instructions for use: https://www.arducam.com/docs/camera-for-jetson-nano/native -jetson-cameras-imx219-imx477/imx219-8mp-camera
