B0031 on Raspberry Pi Zero 2W: never worked, can't see datasheet, need 1080P/idle current
Hi, I’ve got one of your Raspberry Pi camera modules (model B0031, sold under the Uctronics name) that I’m using on a Raspberry Pi Zero 2W. To be honest I never got it to work properly, but what I’m really chasing right now is the power numbers. Can you tell me the current consumption for this camera when it’s recording at 1080P, and also when it’s just sitting idle? I need this for a project we’re evaluating. Thanks.
Hi, happy to help. For the B0031 camera module: when the camera is idle, the current consumption does not exceed 10mA. For the current draw while the camera is running, please refer to the attached document/image - it has the detailed current consumption figures for the active/recording state. If the attachment isn’t showing up on your end, let me know and I’ll re-send it.
Thanks for the quick reply. Unfortunately I can’t see any attachment on your message at all - nothing shows up on my end. Could you please resend the datasheet? I still need the current consumption figure for 1080P recording, and for idle. Also just so you know, I never got this module working, so anything you can share is helpful.
Sorry about that - the file wasn’t uploaded correctly on our side, which is why you couldn’t see it. I’ve re-sent it as a picture this time so it should display properly. Please have another look at the attached picture - it shows the current consumption of the camera when it is running. To repeat the idle figure: the current consumption of the camera when it is idle does not exceed 10mA.
Got it, thanks - I can see the picture now. A few more technical questions:
  1. Is there a difference in current consumption when the camera is used as a view finder vs when the camera is actually recording? I assume it will be the same, could you please confirm?
  2. Is there a technical datasheet that lists all the electrical specifications? If yes, could you please send it to me? It will be useful for us in future.
  3. What is the lifetime of the product? Will it stay in production for the next 5 years?
Some context: we’re planning to potentially use this camera on one of our medical devices, so we’re looking into the feasibility of using it in our device.
Just to pull together where we’re at on this one:
  • Idle current consumption: confirmed, it does not exceed 10mA.
  • Running/recording current consumption: this is in the image I re-attached - the first upload had failed, which is why you weren’t seeing anything, so please work from the re-sent picture.
On your other questions, I don’t have firm answers yet:
  1. View finder vs recording - your assumption that it’s the same is reasonable since the sensor is streaming in both cases, but I want to confirm this properly rather than guess.
  2. Full electrical spec datasheet - I’m checking whether we have a version we can share directly. In the meantime, our documentation page is https://www.arducam.com/documents/ and there’s also the forum at https://www.arducam.com/forums/ which may already cover some of this.
  3. Product lifetime / 5-year availability - that’s a longer-range roadmap question I need to pass along before I can give you anything solid.
I’ll follow up here once I have answers on those three points.
