UCTRONICS -
SKU: B029001 -
RaspberryPi 4 B -
UVC Cameras on Linux - Arducam Wiki -
I have two identical cameras connected to the RPi, and both cameras are at 9 inches from the target with the target in the center of the field of view and filling about 30-40% if the view. One of the two cameras always refocuses when I start it in VLC Media Player, but the other does not. I have tried changing lighting, but that does not help. The scene is well lit. I can see a little bit of adjustment in the image quality over the first few seconds, but then it stops at a point where the balance / lighting is good, but the image is out of focus. -
Let me know how to get this for you if you need it. -
Changing lighting, restarting RPi, power cycling RPi -
Is there a way to control the focus of this camera manually or to set the part of the field of view that is used to fid focus? Any other suggestions to get the focus to work?
(I abandoned my previously purchased Arducam 12MP stereo camera array because manual focus was not possible, even though the distance is fixed. I could simply never get good focus. So, I am depending on autofocus for my application.)
