Get the “ACK CMD SPI interface Error! END” , Maybe the pins are not connected correctly.
Please send us your wiring diagram.
Please refer to this link for detailed instructions.
For my wiring : GND(NANO) → GND (shield), 5V (NANO) → 5V (shield), D13 (NANO) → 13 (shield),
D12 (NANO) → 12 (shield), D11 (NANO) → 11 (shield), D10 (NANO) → 10 (shield), A4 (NANO) → SDA (shield) and A5 (NANO) → SCL (shield).
I also tried with using the ICSP and simply connecting the D10(nano)–> 10 (shield), A4(nano)–>SDA(shield) and A5(nano)–> SCL (shield), but it doesn’t work either.
Thanks
Can you take a physical picture of your connection?
Hi
here is my wiring:
white wire : A5 to SCL
brown wire: A4 to SDA
purple wire : D10 to 10
Hi
here is my wiring:
Hi
here is my wiring:
I’m able to load the picture, but when I click on submit, the page refresh and my post doesn’t show up.
I’m able to load the picture, but when I submit it, the post doesn’t appear
Sorry for all these posts, I think the fact that my reply had an image made it longer to appear so I tried many times because I thought there was a bug. Didn’t think it would do that. Hope there is a way to delete replies ?
Any way, at least you have my picture.
Sorry again.
I looked at your pin connection and it seems to be all right.Since I only have a broken Arduino nano at the moment, I can’t verify your connection for you.
I suggest you use Arduino UNO first to make sure the shield work properly.
