UCTTRONICS
UC-425 Rev C USB Shield
ArduCam GitHub / SDK documentation
Yes
Can someone explain how does the USB_RST pin (40th pin on Harwin M50-4302045 connector) work?
Documentaion tells that is input. And it is the pull-up.
Where do I need to connect this pin to restart the shield? Am I need the additional board to solve this problem? Can I solve it without soldering the reset scheme manually?
Also I can’t find an information about two metal holes on a top right corner.
Thanks in advance.
Own hardware configuration
Alternative decision without manual intervention.
