Hi everyone, I’m trying to get an ArduCam UC-512 camera working with a Jetson Nano and I’m completely stuck. The camera just won’t work at all - I can’t get a preview or any image output from it. I was told to reach out to the support engineers about this. Has anyone run into this with the UC-512 on a Nano?
Thanks for the details. Before we dig into troubleshooting, could you generate a diagnostic bug report so I can see the current state of your setup? Please reboot the device and run the following commands one by one:
That will produce an arducam-bug-report.txt file in the current directory. Please attach that file here so I can take a look.
Okay, I did that. Rebooted the Nano, downloaded the tool, made it executable, and ran it. It generated the arducam-bug-report.txt file as expected. I’ve attached it below.
Thanks for the report. Looking through it, the Jetson Nano is actually detecting the camera module, so this doesn’t look like a hardware detection failure. The problem seems to be on the preview/operation side. Let’s try the Arducam Jetson quick start script to get a preview going:
sudo pip install pick==1.3.0
python3 start.py 0
Then choose imx219 and select preview. The script is available here:
https://github.com/edward-ardu/jetson_quick_start_script
Let me know what happens when you try that.
I tried those steps just now. Installed pick==1.3.0, ran python3 start.py 0, chose imx219, and hit preview - but the camera still fails to work. I’ve attached a screenshot of the error below.
Thanks for the screenshot. Since the Nano detects the camera but it still won’t produce a preview, we need to figure out whether the module itself is defective or if this is a Jetson/platform-side issue. Do you have a Raspberry Pi available to test the camera on? If so, please follow the IMX219 Multi-Camera Kit quick start guide to verify the module works there:
https://docs.arducam.com/Raspberry-Pi-Camera/Multi-Camera-CamArray/quick-start/#imx219-multi-camera-kit
That cross-platform test will help us isolate whether it’s the hardware or the Jetson Nano setup. Let me know how it goes.
