Been banging my head against this for a bit. We have several Arducams in a project and they’re all throwing the same warning when I try to grab frames with OpenCV. Right now there are 4 cameras hooked up to a single machine running Ubuntu 20/22, Python 3, using cv2 to capture. The capture basically stalls and I see this in the logs:
Thanks for the report. To narrow this down, which Arducam models are these, and are the cameras connected directly to USB ports or through a hub? Does the timeout happen right away or only after streaming for a while? Also, could you run v4l2-ctl --list-devices and paste what you see for /dev/video2? That warning is coming from OpenCV’s V4L2 backend (cap_v4l.cpp:1134), where it calls select() waiting for the device to be readable and it times out.
They’re all Arducams, 4 of them on the one computer. Honestly haven’t checked if it’s right away or only after a while yet - the log line I have is from the 16th. I’m capturing with cv2, no custom code beyond that. I’ll grab the v4l2-ctl output once I’m back at the machine. Just wanted to see if this warning is a known thing.
That warning means the V4L2 device didn’t signal ready-to-read within OpenCV’s select() timeout. With 4 cameras on one host, the first thing I’d suspect is USB bandwidth or the device getting reset, but it can also be an OpenCV-specific issue. A few quick checks when you’re at the box:
dmesg | grep -i usb to look for resets/disconnects
v4l2-ctl --list-devices and v4l2-ctl -d /dev/video2 --all
Try a single camera by itself and see if the timeout still occurs
Lower the resolution/fps in cv2 (e.g., 640x480 @ 30) to rule out bandwidth saturation
Also let me know the exact models and whether a USB hub is involved.
Will run those and post back. I can say the error is showing up across all the Arducams, not just video2, and it’s the same select() timeout each time. Haven’t been able to isolate it to a single camera yet. The setup is just the 4 cameras on the one Ubuntu box.
Quick summary of where we are: the error is a V4L2 select() timeout coming from OpenCV’s VideoIO (cap_v4l.cpp:1134) while reading /dev/video2, with 4 Arducams on a single Ubuntu 20/22 machine using Python3 + cv2. Root cause isn’t pinned down yet and there’s no fix at this point. Main suspicion is the camera not delivering frames in time - possibly USB bandwidth/contention with 4 devices - but we still need the diagnostics above (dmesg for USB resets, single-camera test, lower resolution/fps, and model details) to confirm. Post back with those results and we can dig further.
