Arducam Pivistation 5 Hawkeye ethernet connection instable
    Arducam directly
    B0513
    Pivistation RaspberryPi5
    Pivistation 5 Series - Arducam Wiki
  5. Problems you were having?
    Connection freezes after minutes or seconds
dmesg
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x414fd0b1]
[    0.000000] Linux version 6.6.20+rpt-rpi-2712 ([email protected]) (gcc-12 (Debian 12.2.0-14) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1 SMP PREEMPT Debian 1:6.6.20-1+rpt1 (2024-03-07)
[    0.000000] KASLR enabled
[    0.000000] random: crng init done
[    0.000000] Machine model: Raspberry Pi 5 Model B Rev 1.0
[    0.000000] efi: UEFI not found.
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000002000000, size 320 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x0000000002000000..0x0000000015ffffff (327680 KiB) map reusable linux,cma
[    0.000000] OF: reserved mem: 0x0000000000000000..0x000000000007ffff (512 KiB) nomap non-reusable atf@0
[    0.000000] OF: reserved mem: 0x000000003fd165e0..0x000000003fd16617 (0 KiB) nomap non-reusable nvram@0
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x000000000007ffff]
[    0.000000]   node   0: [mem 0x0000000000080000-0x000000003fbfffff]
[    0.000000]   node   0: [mem 0x0000000040000000-0x00000000ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ffffffff]
[    0.000000] On node 0, zone DMA: 256 pages in unavailable ranges
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 14 pages/cpu s183976 r8192 d37208 u229376
[    0.000000] pcpu-alloc: s183976 r8192 d37208 u229376 alloc=14*16384
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: detected: Hardware dirty bit management
[    0.000000] CPU features: detected: Spectre-v4
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=2C:CF:67:4A:69:50 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=e25d61ac-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[    0.000000] Unknown kernel command line parameters "splash", will be passed to user space.
[    0.000000] Dentry cache hash table entries: 524288 (order: 8, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 7, 2097152 bytes, linear)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 260864
[    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[    0.000000] Memory: 3792848K/4190208K available (13376K kernel code, 2222K rwdata, 4288K rodata, 5056K init, 1213K bss, 69680K reserved, 327680K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 43116 entries in 43 pages
[    0.000000] ftrace: allocated 43 pages with 4 groups
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Rude variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[    0.000000] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[    0.000168] Console: colour dummy device 80x25
[    0.000172] printk: console [tty1] enabled
[    0.000203] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=216000)
[    0.000208] pid_max: default: 32768 minimum: 301
[    0.000231] LSM: initializing lsm=capability,integrity
[    0.000290] Mount-cache hash table entries: 8192 (order: 2, 65536 bytes, linear)
[    0.000303] Mountpoint-cache hash table entries: 8192 (order: 2, 65536 bytes, linear)
[    0.000647] cgroup: Disabling memory control group subsystem
[    0.001067] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[    0.001090] RCU Tasks Rude: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[    0.001112] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[    0.001172] rcu: Hierarchical SRCU implementation.
[    0.001174] rcu: 	Max phase no-delay instances is 1000.
[    0.001801] EFI services will not be available.
[    0.001870] smp: Bringing up secondary CPUs ...
[    0.002026] Detected PIPT I-cache on CPU1
[    0.002071] CPU1: Booted secondary processor 0x0000000100 [0x414fd0b1]
[    0.002250] Detected PIPT I-cache on CPU2
[    0.002285] CPU2: Booted secondary processor 0x0000000200 [0x414fd0b1]
[    0.002447] Detected PIPT I-cache on CPU3
[    0.002478] CPU3: Booted secondary processor 0x0000000300 [0x414fd0b1]
[    0.002504] smp: Brought up 1 node, 4 CPUs
[    0.002508] SMP: Total of 4 processors activated.
[    0.002510] CPU features: detected: 32-bit EL0 Support
[    0.002512] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.002514] CPU features: detected: Common not Private translations
[    0.002516] CPU features: detected: CRC32 instructions
[    0.002518] CPU features: detected: RCpc load-acquire (LDAPR)
[    0.002520] CPU features: detected: LSE atomic instructions
[    0.002522] CPU features: detected: Privileged Access Never
[    0.002524] CPU features: detected: RAS Extension Support
[    0.002527] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.002559] CPU: All CPU(s) started at EL2
[    0.002561] alternatives: applying system-wide alternatives
[    0.004432] devtmpfs: initialized
[    0.007209] Enabled cp15_barrier support
[    0.007216] Enabled setend support
[    0.007273] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.007279] futex hash table entries: 1024 (order: 2, 65536 bytes, linear)
[    0.008003] pinctrl core: initialized pinctrl subsystem
[    0.008159] DMI not present or invalid.
[    0.008314] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.008885] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.008930] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.008978] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.008997] audit: initializing netlink subsys (disabled)
[    0.009045] audit: type=2000 audit(0.008:1): state=initialized audit_enabled=0 res=1
[    0.009166] thermal_sys: Registered thermal governor 'step_wise'
[    0.009177] cpuidle: using governor menu
[    0.009241] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.009269] ASID allocator initialised with 32768 entries
[    0.009584] Serial: AMBA PL011 UART driver
[    0.010516] bcm2835-mbox 107c013880.mailbox: mailbox enabled
[    0.010865] 107d001000.serial: ttyAMA10 at MMIO 0x107d001000 (irq = 15, base_baud = 0) is a PL011 rev2
[    0.010875] printk: console [ttyAMA10] enabled
[    0.016116] raspberrypi-firmware soc:firmware: Attached to firmware from 2024-02-16T15:28:41, variant start_cd
[    0.020112] raspberrypi-firmware soc:firmware: Firmware hash is 4c845bd300000000000000000000000000000000
[    0.026457] Modules: 2G module region forced by RANDOMIZE_MODULE_REGION_FULL
[    0.026460] Modules: 0 pages in range for non-PLT usage
[    0.026462] Modules: 129416 pages in range for PLT usage
[    0.032673] bcm2835-dma 1000010000.dma: DMA legacy API manager, dmachans=0x1
[    0.033025] iommu: Default domain type: Translated
[    0.033027] iommu: DMA domain TLB invalidation policy: strict mode
[    0.033120] SCSI subsystem initialized
[    0.033159] usbcore: registered new interface driver usbfs
[    0.033167] usbcore: registered new interface driver hub
[    0.033176] usbcore: registered new device driver usb
[    0.033259] pps_core: LinuxPPS API ver. 1 registered
[    0.033261] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[    0.033266] PTP clock support registered
[    0.033524] vgaarb: loaded
[    0.033644] clocksource: Switched to clocksource arch_sys_counter
[    0.033775] VFS: Disk quotas dquot_6.6.0
[    0.033788] VFS: Dquot-cache hash table entries: 2048 (order 0, 16384 bytes)
[    0.033820] FS-Cache: Loaded
[    0.033854] CacheFiles: Loaded
[    0.035366] NET: Registered PF_INET protocol family
[    0.035457] IP idents hash table entries: 65536 (order: 5, 524288 bytes, linear)
[    0.041672] tcp_listen_portaddr_hash hash table entries: 2048 (order: 1, 32768 bytes, linear)
[    0.041697] Table-perturb hash table entries: 65536 (order: 4, 262144 bytes, linear)
[    0.041701] TCP established hash table entries: 32768 (order: 4, 262144 bytes, linear)
[    0.041837] TCP bind hash table entries: 32768 (order: 6, 1048576 bytes, linear)
[    0.042644] TCP: Hash tables configured (established 32768 bind 32768)
[    0.042767] MPTCP token hash table entries: 4096 (order: 2, 98304 bytes, linear)
[    0.042820] UDP hash table entries: 2048 (order: 2, 65536 bytes, linear)
[    0.042872] UDP-Lite hash table entries: 2048 (order: 2, 65536 bytes, linear)
[    0.042976] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.043104] RPC: Registered named UNIX socket transport module.
[    0.043106] RPC: Registered udp transport module.
[    0.043108] RPC: Registered tcp transport module.
[    0.043109] RPC: Registered tcp-with-tls transport module.
[    0.043110] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.043117] PCI: CLS 0 bytes, default 64
[    0.043181] Trying to unpack rootfs image as initramfs...
[    0.049725] kvm [1]: IPA Size Limit: 40 bits
[    0.049750] kvm [1]: GICV region size/alignment is unsafe, using trapping (reduced performance)
[    0.049782] kvm [1]: vgic interrupt IRQ9
[    0.049796] kvm [1]: VHE mode initialized successfully
[    0.285790] Freeing initrd memory: 16704K
[    0.321489] Initialise system trusted keyrings
[    0.321616] workingset: timestamp_bits=46 max_order=18 bucket_order=0
[    0.321666] zbud: loaded
[    0.321882] NFS: Registering the id_resolver key type
[    0.321890] Key type id_resolver registered
[    0.321892] Key type id_legacy registered
[    0.321898] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.321900] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.321959] F2FS not supported on PAGE_SIZE(16384) != 4096
[    0.322017] Key type asymmetric registered
[    0.322020] Asymmetric key parser 'x509' registered
[    0.322036] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    0.322073] io scheduler mq-deadline registered
[    0.322075] io scheduler kyber registered
[    0.322085] io scheduler bfq registered
[    0.322364] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7c502000, parent irq: 26)
[    0.322436] irq_brcmstb_l2: registered L2 intc (/soc/intc@7d503000, parent irq: 27)
[    0.322483] irq_brcmstb_l2: registered L2 intc (/soc/intc@7d508380, parent irq: 28)
[    0.322525] irq_brcmstb_l2: registered L2 intc (/soc/intc@7d508400, parent irq: 29)
[    0.322583] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7d510600, parent irq: 30)
[    0.322628] irq_brcmstb_l2: registered L2 intc (/soc/intc@7d517b00, parent irq: 31)
[    0.457462] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[    0.457846] 107d50c000.serial: ttyS0 at MMIO 0x107d50c000 (irq = 33, base_baud = 6000000) is a Broadcom BCM7271 UART
[    0.457895] serial serial0: tty port ttyS0 registered
[    0.458177] iproc-rng200 107d208000.rng: hwrng registered
[    0.458227] vc-mem: phys_addr:0x00000000 mem_base=0x3fc00000 mem_size:0x40000000(1024 MiB)
[    0.458451] bcm2712-iommu-cache 1000005b00.iommuc: bcm2712_iommu_cache_probe
[    0.460250] brd: module loaded
[    0.461573] loop: module loaded
[    0.461710] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[    0.461848] Loading iSCSI transport class v2.0-870.
[    0.462702] usbcore: registered new device driver r8152-cfgselector
[    0.462711] usbcore: registered new interface driver r8152
[    0.462717] usbcore: registered new interface driver lan78xx
[    0.462724] usbcore: registered new interface driver smsc95xx
[    0.462781] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    0.462803] dwc_otg: FIQ enabled
[    0.462804] dwc_otg: NAK holdoff enabled
[    0.462806] dwc_otg: FIQ split-transaction FSM enabled
[    0.462808] Module dwc_common_port init
[    0.462931] usbcore: registered new interface driver uas
[    0.462938] usbcore: registered new interface driver usb-storage
[    0.463034] mousedev: PS/2 mouse device common for all mice
[    0.471017] rpi-rtc soc:rpi_rtc: registered as rtc0
[    0.472524] rpi-rtc soc:rpi_rtc: setting system clock to 1970-01-01T00:19:40 UTC (1180)
[    0.472852] bcm2835-wdt bcm2835-wdt: Poweroff handler already present!
[    0.472855] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[    0.475220] sdhci: Secure Digital Host Controller Interface driver
[    0.475222] sdhci: Copyright(c) Pierre Ossman
[    0.475261] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.475453] ledtrig-cpu: registered to indicate activity on CPUs
[    0.475493] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.475505] hid: raw HID events driver (C) Jiri Kosina
[    0.475523] usbcore: registered new interface driver usbhid
[    0.475525] usbhid: USB HID core driver
[    0.475847] hw perfevents: enabled with armv8_cortex_a76 PMU driver, 7 counters available
[    0.476019] NET: Registered PF_PACKET protocol family
[    0.476052] Key type dns_resolver registered
[    0.480937] registered taskstats version 1
[    0.480996] Loading compiled-in X.509 certificates
[    0.483474] Key type .fscrypt registered
[    0.483476] Key type fscrypt-provisioning registered
[    0.484202] brcm-pcie 1000120000.pcie: host bridge /axi/pcie@120000 ranges:
[    0.484208] brcm-pcie 1000120000.pcie:   No bus range found for /axi/pcie@120000, using [bus 00-ff]
[    0.484220] brcm-pcie 1000120000.pcie:      MEM 0x1f00000000..0x1ffffffffb -> 0x0000000000
[    0.484226] brcm-pcie 1000120000.pcie:      MEM 0x1c00000000..0x1effffffff -> 0x0400000000
[    0.484235] brcm-pcie 1000120000.pcie:   IB MEM 0x1f00000000..0x1f003fffff -> 0x0000000000
[    0.484240] brcm-pcie 1000120000.pcie:   IB MEM 0x0000000000..0x0fffffffff -> 0x1000000000
[    0.485593] brcm-pcie 1000120000.pcie: Forcing gen 2
[    0.485815] brcm-pcie 1000120000.pcie: PCI host bridge to bus 0000:00
[    0.485819] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.485822] pci_bus 0000:00: root bus resource [mem 0x1f00000000-0x1ffffffffb] (bus address [0x00000000-0xfffffffb])
[    0.485826] pci_bus 0000:00: root bus resource [mem 0x1c00000000-0x1effffffff pref] (bus address [0x400000000-0x6ffffffff])
[    0.485842] pci 0000:00:00.0: [14e4:2712] type 01 class 0x060400
[    0.485871] pci 0000:00:00.0: PME# supported from D0 D3hot
[    0.486765] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    0.593651] brcm-pcie 1000120000.pcie: link up, 5.0 GT/s PCIe x4 (!SSC)
[    0.593672] pci 0000:01:00.0: [1de4:0001] type 00 class 0x020000
[    0.593687] pci 0000:01:00.0: reg 0x10: [mem 0xffffc000-0xffffffff]
[    0.593695] pci 0000:01:00.0: reg 0x14: [mem 0xffc00000-0xffffffff]
[    0.593702] pci 0000:01:00.0: reg 0x18: [mem 0xffff0000-0xffffffff]
[    0.593773] pci 0000:01:00.0: supports D1
[    0.593775] pci 0000:01:00.0: PME# supported from D0 D1 D3hot D3cold
[    0.605654] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    0.605664] pci 0000:00:00.0: BAR 8: assigned [mem 0x1f00000000-0x1f005fffff]
[    0.605669] pci 0000:01:00.0: BAR 1: assigned [mem 0x1f00000000-0x1f003fffff]
[    0.605674] pci 0000:01:00.0: BAR 2: assigned [mem 0x1f00400000-0x1f0040ffff]
[    0.605679] pci 0000:01:00.0: BAR 0: assigned [mem 0x1f00410000-0x1f00413fff]
[    0.605684] pci 0000:00:00.0: PCI bridge to [bus 01]
[    0.605687] pci 0000:00:00.0:   bridge window [mem 0x1f00000000-0x1f005fffff]
[    0.605692] pci 0000:00:00.0: Max Payload Size set to  256/ 512 (was  128), Max Read Rq  512
[    0.605701] pci 0000:01:00.0: Max Payload Size set to  256/ 256 (was  128), Max Read Rq  512
[    0.605769] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[    0.605809] pcieport 0000:00:00.0: PME: Signaling with IRQ 38
[    0.605862] pcieport 0000:00:00.0: AER: enabled with IRQ 38
[    0.605937] rp1 0000:01:00.0: bar0 len 0x4000, start 0x1f00410000, end 0x1f00413fff, flags, 0x40200
[    0.605941] rp1 0000:01:00.0: bar1 len 0x400000, start 0x1f00000000, end 0x1f003fffff, flags, 0x40200
[    0.605950] rp1 0000:01:00.0: enabling device (0000 -> 0002)
[    0.607096] rp1 0000:01:00.0: chip_id 0x20001927
[    0.630546] macb 1f00100000.ethernet eth0: Cadence GEM rev 0x00070109 at 0x1f00100000 irq 106 (2c:cf:67:4a:69:50)
[    0.631168] dw_axi_dmac_platform 1f00188000.dma: DesignWare AXI DMA Controller, 8 channels
[    0.631434] xhci-hcd xhci-hcd.0: xHCI Host Controller
[    0.631441] xhci-hcd xhci-hcd.0: new USB bus registered, assigned bus number 1
[    0.631895] xhci-hcd xhci-hcd.0: hcc params 0x0240fe6d hci version 0x110 quirks 0x0000008000000810
[    0.631905] xhci-hcd xhci-hcd.0: irq 131, io mem 0x1f00200000
[    0.631971] xhci-hcd xhci-hcd.0: xHCI Host Controller
[    0.631974] xhci-hcd xhci-hcd.0: new USB bus registered, assigned bus number 2
[    0.631978] xhci-hcd xhci-hcd.0: Host supports USB 3.0 SuperSpeed
[    0.632027] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[    0.632032] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.632035] usb usb1: Product: xHCI Host Controller
[    0.632037] usb usb1: Manufacturer: Linux 6.6.20+rpt-rpi-2712 xhci-hcd
[    0.632039] usb usb1: SerialNumber: xhci-hcd.0
[    0.632178] hub 1-0:1.0: USB hub found
[    0.632192] hub 1-0:1.0: 2 ports detected
[    0.632323] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.06
[    0.632327] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.632329] usb usb2: Product: xHCI Host Controller
[    0.632331] usb usb2: Manufacturer: Linux 6.6.20+rpt-rpi-2712 xhci-hcd
[    0.632333] usb usb2: SerialNumber: xhci-hcd.0
[    0.632418] hub 2-0:1.0: USB hub found
[    0.632429] hub 2-0:1.0: 1 port detected
[    0.632703] xhci-hcd xhci-hcd.1: xHCI Host Controller
[    0.632708] xhci-hcd xhci-hcd.1: new USB bus registered, assigned bus number 3
[    0.633157] xhci-hcd xhci-hcd.1: hcc params 0x0240fe6d hci version 0x110 quirks 0x0000008000000810
[    0.633167] xhci-hcd xhci-hcd.1: irq 136, io mem 0x1f00300000
[    0.633227] xhci-hcd xhci-hcd.1: xHCI Host Controller
[    0.633230] xhci-hcd xhci-hcd.1: new USB bus registered, assigned bus number 4
[    0.633234] xhci-hcd xhci-hcd.1: Host supports USB 3.0 SuperSpeed
[    0.633268] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[    0.633271] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.633274] usb usb3: Product: xHCI Host Controller
[    0.633276] usb usb3: Manufacturer: Linux 6.6.20+rpt-rpi-2712 xhci-hcd
[    0.633279] usb usb3: SerialNumber: xhci-hcd.1
[    0.633362] hub 3-0:1.0: USB hub found
[    0.633374] hub 3-0:1.0: 2 ports detected
[    0.633492] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.06
[    0.633495] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.633498] usb usb4: Product: xHCI Host Controller
[    0.633500] usb usb4: Manufacturer: Linux 6.6.20+rpt-rpi-2712 xhci-hcd
[    0.633502] usb usb4: SerialNumber: xhci-hcd.1
[    0.633582] hub 4-0:1.0: USB hub found
[    0.633593] hub 4-0:1.0: 1 port detected
[    0.634234] bcm2712-iommu 1000005100.iommu: bcm2712_iommu_init: DEBUG_INFO = 0x20804774
[    0.634565] platform 1000800000.codec: bcm2712_iommu_probe_device: MMU 1000005100.iommu
[    0.634570] platform 1000800000.codec: bcm2712_iommu_device_group: MMU 1000005100.iommu
[    0.634575] platform 1000800000.codec: Adding to iommu group 0
[    0.634586] platform 1000880000.pisp_be: bcm2712_iommu_probe_device: MMU 1000005100.iommu
[    0.634590] platform 1000880000.pisp_be: bcm2712_iommu_device_group: MMU 1000005100.iommu
[    0.634594] platform 1000880000.pisp_be: Adding to iommu group 0
[    0.634622] platform 1000800000.codec: bcm2712_iommu_attach_dev: MMU 1000005100.iommu
[    0.634625] platform 1000880000.pisp_be: bcm2712_iommu_attach_dev: MMU 1000005100.iommu
[    0.634629] bcm2712-iommu 1000005100.iommu: bcm2712_iommu_probe: Success
[    0.634979] bcm2712-iommu 1000005200.iommu: bcm2712_iommu_init: DEBUG_INFO = 0x20804774
[    0.635270] platform axi:gpu: bcm2712_iommu_probe_device: MMU 1000005200.iommu
[    0.635274] platform axi:gpu: bcm2712_iommu_device_group: MMU 1000005200.iommu
[    0.635278] platform axi:gpu: Adding to iommu group 1
[    0.635301] platform axi:gpu: bcm2712_iommu_attach_dev: MMU 1000005200.iommu
[    0.635304] bcm2712-iommu 1000005200.iommu: bcm2712_iommu_probe: Success
[    0.635615] bcm2712-iommu 1000005280.iommu: bcm2712_iommu_init: DEBUG_INFO = 0x20804774
[    0.635917] platform 1f00128000.csi: bcm2712_iommu_probe_device: MMU 1000005280.iommu
[    0.635921] platform 1f00128000.csi: bcm2712_iommu_device_group: MMU 1000005280.iommu
[    0.635925] platform 1f00128000.csi: Adding to iommu group 2
[    0.635930] platform 1f00128000.csi: bcm2712_iommu_attach_dev: MMU 1000005280.iommu
[    0.635933] bcm2712-iommu 1000005280.iommu: bcm2712_iommu_probe: Success
[    0.636729] sdhci-brcmstb 1000fff000.mmc: Got CD GPIO
[    0.636840] mmc0: CQHCI version 5.10
[    0.637122] mmc1: CQHCI version 5.10
[    0.637415] of_cfs_init
[    0.637448] of_cfs_init: OK
[    0.637520] clk: Disabling unused clocks
[    0.673371] mmc0: SDHCI controller on 1000fff000.mmc [1000fff000.mmc] using ADMA 64-bit
[    0.768570] mmc0: new ultra high speed SDR104 SDHC card at address 59b4
[    0.768810] mmcblk0: mmc0:59b4 USD00 29.5 GiB
[    0.769925]  mmcblk0: p1 p2
[    0.770019] mmcblk0: mmc0:59b4 USD00 29.5 GiB
[    0.826174] mmc1: SDHCI controller on 1001100000.mmc [1001100000.mmc] using ADMA 64-bit
[    0.829565] Freeing unused kernel memory: 5056K
[    0.829615] Run /init as init process
[    0.829616]   with arguments:
[    0.829618]     /init
[    0.829619]     splash
[    0.829621]   with environment:
[    0.829622]     HOME=/
[    0.829623]     TERM=linux
[    0.858962] mmc1: new ultra high speed DDR50 SDIO card at address 0001
[    0.962730] input: pwr_button as /devices/platform/pwr_button/input/input0
[    0.999986] brcmstb-i2c 107d508200.i2c:  @97500hz registered in interrupt mode
[    1.000231] brcmstb-i2c 107d508280.i2c:  @97500hz registered in interrupt mode
[    1.015784] [drm] Initialized v3d 1.0.0 20180419 for 1002000000.v3d on minor 0
[    1.018466] vc4-drm axi:gpu: bcm2712_iommu_of_xlate: MMU 1000005200.iommu
[    1.023225] vc4-drm axi:gpu: bound 107c580000.hvs (ops vc4_hvs_ops [vc4])
[    1.024629] Registered IR keymap rc-cec
[    1.024679] rc rc0: vc4-hdmi-0 as /devices/platform/soc/107c701400.hdmi/rc/rc0
[    1.024729] input: vc4-hdmi-0 as /devices/platform/soc/107c701400.hdmi/rc/rc0/input1
[    1.025400] input: vc4-hdmi-0 HDMI Jack as /devices/platform/soc/107c701400.hdmi/sound/card0/input2
[    1.026031] vc4-drm axi:gpu: bound 107c701400.hdmi (ops vc4_hdmi_ops [vc4])
[    1.027400] Registered IR keymap rc-cec
[    1.027442] rc rc1: vc4-hdmi-1 as /devices/platform/soc/107c706400.hdmi/rc/rc1
[    1.027486] input: vc4-hdmi-1 as /devices/platform/soc/107c706400.hdmi/rc/rc1/input3
[    1.028170] input: vc4-hdmi-1 HDMI Jack as /devices/platform/soc/107c706400.hdmi/sound/card1/input4
[    1.028238] vc4-drm axi:gpu: bound 107c706400.hdmi (ops vc4_hdmi_ops [vc4])
[    1.028373] vc4-drm axi:gpu: bound 107c500000.mop (ops vc4_txp_ops [vc4])
[    1.028449] vc4-drm axi:gpu: bound 107c501000.moplet (ops vc4_txp_ops [vc4])
[    1.028524] vc4-drm axi:gpu: bound 107c410000.pixelvalve (ops vc4_crtc_ops [vc4])
[    1.028641] vc4-drm axi:gpu: bound 107c411000.pixelvalve (ops vc4_crtc_ops [vc4])
[    1.029168] [drm] Initialized vc4 0.0.0 20140616 for axi:gpu on minor 1
[    1.031194] vc4-drm axi:gpu: [drm] Cannot find any crtc or sizes
[    1.033251] vc4-drm axi:gpu: [drm] Cannot find any crtc or sizes
[    1.035252] vc4-drm axi:gpu: [drm] Cannot find any crtc or sizes
[    1.140289] EXT4-fs (mmcblk0p2): mounted filesystem fc7a1f9e-4967-4f41-a1f5-1b5927e6c5f9 ro with ordered data mode. Quota mode: none.
[    1.379061] systemd[1]: System time before build time, advancing clock.
[    1.439716] NET: Registered PF_INET6 protocol family
[    1.440112] Segment Routing with IPv6
[    1.440120] In-situ OAM (IOAM) with IPv6
[    1.467143] systemd[1]: systemd 252.22-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    1.467153] systemd[1]: Detected architecture arm64.
[    1.469545] systemd[1]: Hostname set to <raspberry>.
[    1.542963] uart-pl011 107d001000.serial: no DMA platform data
[    1.730750] systemd[1]: Queued start job for default target graphical.target.
[    1.754299] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[    1.754612] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[    1.754861] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
[    1.755116] systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck.
… see next post due to message length limit
[    1.755269] systemd[1]: Created slice user.slice - User and Session Slice.
[    1.755352] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[    1.755540] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
[    1.755572] systemd[1]: Expecting device dev-disk-by\x2dpartuuid-e25d61ac\x2d01.device - /dev/disk/by-partuuid/e25d61ac-01...
[    1.755583] systemd[1]: Expecting device dev-ttyAMA10.device - /dev/ttyAMA10...
[    1.755622] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
[    1.755669] systemd[1]: Reached target nss-user-lookup.target - User and Group Name Lookups.
[    1.755703] systemd[1]: Reached target slices.target - Slice Units.
[    1.755731] systemd[1]: Reached target swap.target - Swaps.
[    1.755764] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
[    1.755907] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
[    1.755973] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[    1.756245] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
[    1.756370] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[    1.756496] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
[    1.758379] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[    1.758487] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[    1.758657] systemd[1]: dev-hugepages.mount - Huge Pages File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/mm/hugepages).
[    1.759543] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
[    1.760526] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
[    1.761521] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
[    1.761813] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
[    1.764178] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
[    1.765589] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
[    1.766969] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
[    1.768512] systemd[1]: Starting [email protected] - Load Kernel Module configfs...
[    1.770285] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
[    1.772284] systemd[1]: Starting [email protected] - Load Kernel Module drm...
[    1.774843] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
[    1.776609] systemd[1]: Starting [email protected] - Load Kernel Module fuse...
[    1.778316] systemd[1]: Starting [email protected] - Load Kernel Module loop...
[    1.778584] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
[    1.781212] systemd[1]: Starting systemd-journald.service - Journal Service...
[    1.794816] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: [email protected]
[    1.797518] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
[    1.798763] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
[    1.800037] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[    1.802429] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
[    1.802986] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
[    1.803246] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
[    1.809027] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
[    1.809065] fuse: init (API version 7.39)
[    1.810003] systemd[1]: [email protected]: Deactivated successfully.
[    1.810353] systemd[1]: Finished [email protected] - Load Kernel Module configfs.
[    1.810811] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[    1.810966] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
[    1.811300] systemd[1]: [email protected]: Deactivated successfully.
[    1.811461] systemd[1]: Finished [email protected] - Load Kernel Module drm.
[    1.811830] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[    1.812010] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
[    1.812383] systemd[1]: [email protected]: Deactivated successfully.
[    1.812548] systemd[1]: Finished [email protected] - Load Kernel Module fuse.
[    1.812870] systemd[1]: [email protected]: Deactivated successfully.
[    1.812997] systemd[1]: Finished [email protected] - Load Kernel Module loop.
[    1.814552] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
[    1.815785] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
[    1.816047] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
[    1.817891] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
[    1.820256] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
[    1.823288] i2c_dev: i2c /dev entries driver
[    1.824743] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
[    1.826436] systemd-journald[299]: Oldest entry in /run/log/journal/8512b7df7f184db0b3e6ec94514dc4e0/system.journal is older than the configured file retention duration (1month), suggesting rotation.
[    1.826447] systemd-journald[299]: /run/log/journal/8512b7df7f184db0b3e6ec94514dc4e0/system.journal: Journal header limits reached or header out-of-date, rotating.
[    1.826616] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
[    1.827264] systemd[1]: Finished fake-hwclock.service - Restore / save the current clock.
[    1.848144] systemd[1]: Started systemd-journald.service - Journal Service.
[    1.851795] EXT4-fs (mmcblk0p2): re-mounted fc7a1f9e-4967-4f41-a1f5-1b5927e6c5f9 r/w. Quota mode: none.
[    1.872685] systemd-journald[299]: Received client request to flush runtime journal.
[    1.886104] systemd-journald[299]: File /var/log/journal/8512b7df7f184db0b3e6ec94514dc4e0/system.journal corrupted or uncleanly shut down, renaming and replacing.
[    1.919694] systemd-journald[299]: Oldest entry in /var/log/journal/8512b7df7f184db0b3e6ec94514dc4e0/system.journal is older than the configured file retention duration (1month), suggesting rotation.
[    1.919708] systemd-journald[299]: /var/log/journal/8512b7df7f184db0b3e6ec94514dc4e0/system.journal: Journal header limits reached or header out-of-date, rotating.
[    2.562383] rpi-gpiomem 107d508500.gpiomem: window base 0x107d508500 size 0x00000040
[    2.562675] rpi-gpiomem 107d508500.gpiomem: initialised 1 regions as /dev/gpiomem1
[    2.562800] rpi-gpiomem 107d517c00.gpiomem: window base 0x107d517c00 size 0x00000040
[    2.563423] rpi-gpiomem 107d517c00.gpiomem: initialised 1 regions as /dev/gpiomem2
[    2.563751] rpi-gpiomem 107d504100.gpiomem: window base 0x107d504100 size 0x00000020
[    2.563840] rpi-gpiomem 107d504100.gpiomem: initialised 1 regions as /dev/gpiomem3
[    2.563878] rpi-gpiomem 107d510700.gpiomem: window base 0x107d510700 size 0x00000020
[    2.563938] rpi-gpiomem 107d510700.gpiomem: initialised 1 regions as /dev/gpiomem4
[    2.564216] rpi-gpiomem 1f000d0000.gpiomem: window base 0x1f000d0000 size 0x00030000
[    2.564286] rpi-gpiomem 1f000d0000.gpiomem: initialised 1 regions as /dev/gpiomem0
[    2.579590] mc: Linux media interface: v0.10
[    2.643586] videodev: Linux video capture interface: v2.00
[    2.714914] rp1-cfe 1f00128000.csi: bcm2712_iommu_of_xlate: MMU 1000005280.iommu
[    2.715406] rp1-cfe 1f00128000.csi: DW dphy Host HW v1.20
[    2.715427] rp1-cfe 1f00128000.csi: PiSP FE HW v0.1
[    2.716749] rp1-cfe 1f00128000.csi: found subdevice /axi/pcie@120000/rp1/i2c@80000/arducam_64mp@1a
[    2.720235] pispbe 1000880000.pisp_be: bcm2712_iommu_of_xlate: MMU 1000005100.iommu
[    2.720645] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
[    2.730004] rpivid 1000800000.codec: bcm2712_iommu_of_xlate: MMU 1000005100.iommu
[    2.735248] pispbe 1000880000.pisp_be: pispbe_probe: HW version:  0x02252700
[    2.735257] pispbe 1000880000.pisp_be: pispbe_probe: BatchStatus: 0x00000000
[    2.735260] pispbe 1000880000.pisp_be: pispbe_probe: Status:      0x00000000
[    2.735262] pispbe 1000880000.pisp_be: Register nodes for group 0
[    2.736208] pispbe 1000880000.pisp_be: input device node registered as /dev/video20
[    2.736344] pispbe 1000880000.pisp_be: tdn_input device node registered as /dev/video21
[    2.736909] pispbe 1000880000.pisp_be: stitch_input device node registered as /dev/video22
[    2.741227] pispbe 1000880000.pisp_be: hog_output device node registered as /dev/video23
[    2.742041] pispbe 1000880000.pisp_be: output0 device node registered as /dev/video24
[    2.752222] pispbe 1000880000.pisp_be: output1 device node registered as /dev/video25
[    2.762074] pispbe 1000880000.pisp_be: tdn_output device node registered as /dev/video26
[    2.762204] pispbe 1000880000.pisp_be: stitch_output device node registered as /dev/video27
[    2.762964] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    2.764244] pispbe 1000880000.pisp_be: config device node registered as /dev/video28
[    2.765412] pispbe 1000880000.pisp_be: Register nodes for group 1
[    2.767523] pispbe 1000880000.pisp_be: input device node registered as /dev/video29
[    2.768075] pispbe 1000880000.pisp_be: tdn_input device node registered as /dev/video30
[    2.768635] pispbe 1000880000.pisp_be: stitch_input device node registered as /dev/video31
[    2.769839] pispbe 1000880000.pisp_be: hog_output device node registered as /dev/video32
[    2.771671] pispbe 1000880000.pisp_be: output0 device node registered as /dev/video33
[    2.772503] pispbe 1000880000.pisp_be: output1 device node registered as /dev/video34
[    2.778069] Loaded X.509 cert '[email protected]: 577e021cb980e0e820821ba7b54b4961b8b4fadf'
[    2.778405] Loaded X.509 cert '[email protected]: 3abbc6ec146e09d1b6016ab9d6cf71dd233f0328'
[    2.778714] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    2.779016] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[    2.779227] pispbe 1000880000.pisp_be: tdn_output device node registered as /dev/video35
[    2.779340] pispbe 1000880000.pisp_be: stitch_output device node registered as /dev/video36
[    2.781814] pispbe 1000880000.pisp_be: config device node registered as /dev/video37
[    2.782640] arducam_64mp 4-001a: Device found Arducam 64MP.
[    2.787338] rp1-cfe 1f00128000.csi: Using sensor arducam_64mp 4-001a for capture
[    2.787452] rp1-cfe 1f00128000.csi: Registered [rp1-cfe-csi2_ch0] node id 0 successfully as /dev/video0
[    2.787491] rp1-cfe 1f00128000.csi: Registered [rp1-cfe-embedded] node id 1 successfully as /dev/video1
[    2.787523] rp1-cfe 1f00128000.csi: Registered [rp1-cfe-csi2_ch2] node id 2 successfully as /dev/video2
[    2.787558] rp1-cfe 1f00128000.csi: Registered [rp1-cfe-csi2_ch3] node id 3 successfully as /dev/video3
[    2.787587] rp1-cfe 1f00128000.csi: Registered [rp1-cfe-fe_image0] node id 4 successfully as /dev/video4
[    2.787617] rp1-cfe 1f00128000.csi: Registered [rp1-cfe-fe_image1] node id 5 successfully as /dev/video5
[    2.787645] rp1-cfe 1f00128000.csi: Registered [rp1-cfe-fe_stats] node id 6 successfully as /dev/video6
[    2.787675] rp1-cfe 1f00128000.csi: Registered [rp1-cfe-fe_config] node id 7 successfully as /dev/video7
[    2.804101] Bluetooth: Core ver 2.22
[    2.804129] NET: Registered PF_BLUETOOTH protocol family
[    2.804132] Bluetooth: HCI device and connection manager initialized
[    2.804140] Bluetooth: HCI socket layer initialized
[    2.804143] Bluetooth: L2CAP socket layer initialized
[    2.804148] Bluetooth: SCO socket layer initialized
[    2.832946] Bluetooth: HCI UART driver ver 2.3
[    2.832954] Bluetooth: HCI UART protocol H4 registered
[    2.832988] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    2.833125] hci_uart_bcm serial0-0: supply vbat not found, using dummy regulator
[    2.833173] hci_uart_bcm serial0-0: supply vddio not found, using dummy regulator
[    2.839601] Bluetooth: HCI UART protocol Broadcom registered
[    2.845750] brcmfmac: F1 signature read @0x18000000=0x15264345
[    2.847287] rpivid 1000800000.codec: Device registered as /dev/video19
[    2.849744] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    2.849945] usbcore: registered new interface driver brcmfmac
[    3.014869] alsactl[412]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[    3.070184] brcmfmac_wcc: brcmf_wcc_attach: executing
[    3.076816] brcmfmac: brcmf_c_process_txcap_blob: no txcap_blob available (err=-2)
[    3.077059] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Apr 15 2021 03:03:20 version 7.45.234 (4ca95bb CY) FWID 01-996384e2
[    3.186630] Bluetooth: hci0: BCM: chip id 107
[    3.187036] Bluetooth: hci0: BCM: features 0x2f
[    3.189015] Bluetooth: hci0: BCM4345C0
[    3.189028] Bluetooth: hci0: BCM4345C0 (003.001.025) build 0000
[    3.210735] Bluetooth: hci0: BCM4345C0 'brcm/BCM4345C0.raspberrypi,5-model-b.hcd' Patch
[    3.460367] Adding 102384k swap on /var/swap.  Priority:-2 extents:1 across:102384k SS
[    3.922311] Bluetooth: hci0: BCM: features 0x2f
[    3.923675] Bluetooth: hci0: BCM43455 37.4MHz Raspberry Pi 3+-0190
[    3.923681] Bluetooth: hci0: BCM4345C0 (003.001.025) build 0382
[    3.923973] Bluetooth: hci0: BCM: Using default device address (43:45:c0:00:1f:ac)
[    4.216803] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    4.216813] Bluetooth: BNEP filters: protocol multicast
[    4.216821] Bluetooth: BNEP socket layer initialized
[    4.219502] Bluetooth: MGMT ver 1.22
[    4.233818] NET: Registered PF_ALG protocol family
[    4.403316] macb 1f00100000.ethernet eth0: PHY [1f00100000.ethernet-ffffffff:01] driver [Broadcom BCM54213PE] (irq=POLL)
[    4.403329] macb 1f00100000.ethernet eth0: configuring for phy/rgmii-id link mode
[    4.407396] pps pps0: new PPS source ptp0
[    4.407442] macb 1f00100000.ethernet: gem-ptp-timer ptp clock registered.
[    4.443129] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[    6.248663] Bluetooth: RFCOMM TTY layer initialized
[    6.248676] Bluetooth: RFCOMM socket layer initialized
[    6.248686] Bluetooth: RFCOMM ver 1.11
[    8.515578] macb 1f00100000.ethernet eth0: Link is Up - 1Gbps/Full - flow control tx
[    9.335371] source of link 'rp1-cfe-fe_config':0->'pisp-fe':1 is not a V4L2 sub-device, driver bug!
[    9.335398] rp1-cfe 1f00128000.csi: Using a link rate of 912 Mbps
[   49.746192] rp1-cfe 1f00128000.csi: Using a link rate of 912 Mbps
[   98.657867] rp1-cfe 1f00128000.csi: Using a link rate of 912 Mbps
[  114.650024] rp1-cfe 1f00128000.csi: Using a link rate of 912 Mbps
[ 1467.605870] rp1-cfe 1f00128000.csi: Using a link rate of 912 Mbps
[ 1561.732675] rp1-cfe 1f00128000.csi: Using a link rate of 912 Mbps
    I’ve checked journalctl for log messages. This is what I found right before loosing connection (http & ssh):
Mar 15 15:55:26 raspberry NetworkManager[854]: <info>  [1710518126.1900] device (eth0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed')
Mar 15 15:55:26 raspberry avahi-daemon[723]: Withdrawing address record for fe80::4f51:861d:8c1b:2d93 on eth0.
Mar 15 15:55:26 raspberry NetworkManager[854]: <info>  [1710518126.1903] manager: NetworkManager state is now DISCONNECTED
Mar 15 15:55:26 raspberry avahi-daemon[723]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::4f51:861d:8c1b:2d93.
Mar 15 15:55:26 raspberry NetworkManager[854]: <warn>  [1710518126.1904] device (eth0): Activation: failed for connection 'Wired connection 1'
Mar 15 15:55:26 raspberry avahi-daemon[723]: Interface eth0.IPv6 no longer relevant for mDNS.
Mar 15 15:55:26 raspberry NetworkManager[854]: <info>  [1710518126.1905] device (eth0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Mar 15 15:55:26 raspberry NetworkManager[854]: <info>  [1710518126.2317] dhcp4 (eth0): canceled DHCP transaction
Mar 15 15:55:26 raspberry NetworkManager[854]: <info>  [1710518126.2317] dhcp4 (eth0): activation: beginning transaction (timeout in 45 seconds)
Mar 15 15:55:26 raspberry NetworkManager[854]: <info>  [1710518126.2317] dhcp4 (eth0): state changed no lease
Mar 15 15:55:26 raspberry avahi-daemon[723]: Withdrawing address record for 10.254.10.1 on eth0.
Mar 15 15:55:26 raspberry avahi-daemon[723]: Leaving mDNS multicast group on interface eth0.IPv4 with address 10.254.10.1.
Mar 15 15:55:26 raspberry avahi-daemon[723]: Interface eth0.IPv4 no longer relevant for mDNS.
Mar 15 15:55:26 raspberry NetworkManager[854]: <info>  [1710518126.2580] policy: auto-activating connection 'Wired connection 1' (fe81c0aa-82e2-3620-a4bd-d2a0d943973e)
Mar 15 15:55:26 raspberry NetworkManager[854]: <info>  [1710518126.2588] device (eth0): Activation: starting connection 'Wired connection 1' (fe81c0aa-82e2-3620-a4bd-d2a0d943973e)
Mar 15 15:55:26 raspberry NetworkManager[854]: <info>  [1710518126.2592] device (eth0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 15 15:55:26 raspberry NetworkManager[854]: <info>  [1710518126.2596] manager: NetworkManager state is now CONNECTING
Mar 15 15:55:26 raspberry NetworkManager[854]: <info>  [1710518126.2599] device (eth0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 15 15:55:26 raspberry NetworkManager[854]: <info>  [1710518126.2606] device (eth0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Mar 15 15:55:26 raspberry NetworkManager[854]: <info>  [1710518126.2640] dhcp4 (eth0): activation: beginning transaction (timeout in 45 seconds)
Mar 15 15:55:26 raspberry avahi-daemon[723]: Joining mDNS multicast group on interface eth0.IPv4 with address 10.254.10.1.
Mar 15 15:55:26 raspberry avahi-daemon[723]: New relevant interface eth0.IPv4 for mDNS.
Mar 15 15:55:26 raspberry avahi-daemon[723]: Registering new address record for 10.254.10.1 on eth0.IPv4.
Mar 15 15:55:26 raspberry avahi-daemon[723]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::4f51:861d:8c1b:2d93.
Mar 15 15:55:26 raspberry avahi-daemon[723]: New relevant interface eth0.IPv6 for mDNS.
Mar 15 15:55:26 raspberry avahi-daemon[723]: Registering new address record for fe80::4f51:861d:8c1b:2d93 on eth0.*.
Mar 15 15:56:11 raspberry NetworkManager[854]: <info>  [1710518171.1893] device (eth0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed')
Mar 15 15:56:11 raspberry avahi-daemon[723]: Withdrawing address record for fe80::4f51:861d:8c1b:2d93 on eth0.
Mar 15 15:56:11 raspberry NetworkManager[854]: <info>  [1710518171.1896] manager: NetworkManager state is now DISCONNECTED
Mar 15 15:56:11 raspberry avahi-daemon[723]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::4f51:861d:8c1b:2d93.
Mar 15 15:56:11 raspberry NetworkManager[854]: <warn>  [1710518171.1897] device (eth0): Activation: failed for connection 'Wired connection 1'
Mar 15 15:56:11 raspberry avahi-daemon[723]: Interface eth0.IPv6 no longer relevant for mDNS.
Mar 15 15:56:11 raspberry NetworkManager[854]: <info>  [1710518171.1899] device (eth0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Mar 15 15:56:11 raspberry NetworkManager[854]: <info>  [1710518171.2058] dhcp4 (eth0): canceled DHCP transaction
Mar 15 15:56:11 raspberry NetworkManager[854]: <info>  [1710518171.2058] dhcp4 (eth0): activation: beginning transaction (timeout in 45 seconds)
Mar 15 15:56:11 raspberry NetworkManager[854]: <info>  [1710518171.2058] dhcp4 (eth0): state changed no lease
Mar 15 15:56:11 raspberry avahi-daemon[723]: Withdrawing address record for 10.254.10.1 on eth0.
Mar 15 15:56:11 raspberry avahi-daemon[723]: Leaving mDNS multicast group on interface eth0.IPv4 with address 10.254.10.1.
Mar 15 15:56:11 raspberry avahi-daemon[723]: Interface eth0.IPv4 no longer relevant for mDNS.
Mar 15 15:56:11 raspberry NetworkManager[854]: <info>  [1710518171.2358] policy: auto-activating connection 'Wired connection 1' (fe81c0aa-82e2-3620-a4bd-d2a0d943973e)
Mar 15 15:56:11 raspberry NetworkManager[854]: <info>  [1710518171.2400] device (eth0): Activation: starting connection 'Wired connection 1' (fe81c0aa-82e2-3620-a4bd-d2a0d943973e)
Mar 15 15:56:11 raspberry NetworkManager[854]: <info>  [1710518171.2402] device (eth0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 15 15:56:11 raspberry NetworkManager[854]: <info>  [1710518171.2405] manager: NetworkManager state is now CONNECTING
Mar 15 15:56:11 raspberry NetworkManager[854]: <info>  [1710518171.2408] device (eth0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 15 15:56:11 raspberry NetworkManager[854]: <info>  [1710518171.2415] device (eth0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Mar 15 15:56:11 raspberry NetworkManager[854]: <info>  [1710518171.2423] dhcp4 (eth0): activation: beginning transaction (timeout in 45 seconds)
Mar 15 15:56:11 raspberry avahi-daemon[723]: Joining mDNS multicast group on interface eth0.IPv4 with address 10.254.10.1.
Mar 15 15:56:11 raspberry avahi-daemon[723]: New relevant interface eth0.IPv4 for mDNS.
Mar 15 15:56:11 raspberry avahi-daemon[723]: Registering new address record for 10.254.10.1 on eth0.IPv4.
Mar 15 15:56:11 raspberry avahi-daemon[723]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::4f51:861d:8c1b:2d93.
Mar 15 15:56:11 raspberry avahi-daemon[723]: New relevant interface eth0.IPv6 for mDNS.
Mar 15 15:56:11 raspberry avahi-daemon[723]: Registering new address record for fe80::4f51:861d:8c1b:2d93 on eth0.*.
  1. What help do you need?
    I want to use the Pivistation as described via direct connection with a ethernet cable and a stable connection.
Could you please download the following image to your PC and then flash it onto your Pi via Imager?
https://sourceforge.net/projects/pivistation-5/files/B0513/B0513_arducam-64mp-2025-06-06-2024-11-19-raspios-bookworm-arm64.img.xz/download
You can find more details on how to flash an image here.
https://www.raspberrypi.com/documentation/computers/getting-started.html#installing-the-operating-system
Flashed the (original) SD card with RaspberryPi Imager. Now I can’t connect at all…
Hi @mmoollllee
Let’s break down exactly how to verify whether you flash a correct image onto your SD card.
Can you connect your Pi to a monitor and use the mouse and keyboard to control your Pi?
In the meantime I installed the original Bookworm and set things up manually…
